Massive Part Out
Old 09-29-2012, 05:11 PM
cyotani's Avatar
Total Cats: 116
Default Massive Part Out
Located in Philips Ranch (Pomona, CA 91766)
ALL PRICES OBO- Shoot me an offer on anything
Willing to ship smaller items at buyer expense
TEXT ME AT (808)561-8206 (my PM box gets full to fast)
no trade please (as you can see, I have enough stuff)
unless you have an t25 turbo i may be interested (sr20 turbo is ideal)
SOLD- 1.8 axels with ABS
SOLD- 1.6 diff (not sure if open or VLSD)
SOLD- 1.6 drive shaft
SOLD- new energy suspension bushing set (all control arms only)
$50 a corner- upper and lower control arm pair
$160- complete control arm set (all 8 control arms)
$20- broken carrier with ploy diff bushing that can be pressed out
$300- RX7 LSD clutch type differential (no carrier)
$90- Daisy set of four with good tires but one has a flat (comes with all 4 center caps
SOLD- for assembled front sub frame with control arms
$20- radiator with no leaks
SOLD- radiator fan
$40 for pair- wheel spacer (0.75 in thick) thicker spacers sold
$10 each- front caliper ($15 for pair)
$30 each- Rear caliper ($50 for pair)
$5- heat shield (I have 3 1.6 and 1 1.8)
$80- fully assembled NA suspension (none blown but unknown mileage)
$20- front upright hub with good bearing
$20- Rear upright hub
Free- 1.6 rotor with caliper purchase
$5 each- NA top hat (2 available)
SOLD- power steering rack with rod ends (needs new boots)
SOLD- slightly used manual steering rack with new tie rod ends
$10- sway bar (front or rear)
$15- sway bar with end links (front or rear)
$10- ppf
SOLD- rear sub frame brace (oem msm brace??)
$10- misc frame bracing bars
$50- steering column with ignition and key
$90- steering column with ignition and key + 2 door lock + trunk lock (new lock set kit)
$120- grey front hood in flawless condition
$40 each- front BRG fender with bad roll
$30- blue passenger side fender (slightly damaged)
$80- 1.6 exhaust + cat + down pipe assembly (welded together) no leaks
$450- xxr 522 15x8 0 offset with flaken tires over 90% thread left (slightly curb rash)
OR trade for polished xxr 002 same size with good tires
$30- toneau cover (spelling?) has small rips
SOLD- soft top cover
SOLD- Barely used soft top with plastic window with frame(no tears damages of any sort)
$120- soft top with one small hole in leather and needs a new zip plastic window
$10- Rear black carpet piece
$5- black carpet that goes behind the seat
$50- great condition black main carpet piece
$10- trunk carpet
$5- trunk latch area piece
$15- passenger side black floor mat in great shape
SOLD- RX7 460cc injectors
SOLD- greddy knock off bov
$30 each- cluster with slightly over 200k miles no cracks or damges
$35- cluster with about 70k miles no cracks of damages
SOLD- 1.6 5spd ECU
$40- 1.8 5 spd ECU
$15- Wire harness from battery to fuse box (includes fuse box)
$10- clock spring
$10- turn signal assembly
$20- Driver side air bad in good condition
$30- Aftermarket antena
$5-10- misc relays, fuses, airbag module, etc.
$5 each- turn signal pigtail with bulb
SOLD- unknown brand steering wheel with horn
SOLD- Nardi steering wheel- horn button is missing the spring (text me for size)
$20- rear tow hook
SOLD- unknown brand quick release
SOLD- ebay intercooler
$5 each or $20 for set- daisy center cap
$15- 1.8 flywheel
$40- used f1 stage 3 1.6 clutch + pressure plate (still has good life left)
SOLD- 1.6 timing belt
SOLD- 1.6 GMB water pump (brand new with gaskets)
$40- OEM Mazda 1.6 head gasket
$60- 1.8 CAS
$5- gas lid (one red one grey)
SOLD- Seat braket (set of 4 for 1 seat)
SOLD- valve cover gasket set
$90- timing belt + water pump+ seals + tensioners, etc. (complete kit)
exact same as (Mazda Miata Complete Timing Belt & Water Pump Kit 1990 91 92 1993 EXACT-FIT 1.6L | eBay)
$80- 1.6 dash in great condition
$20- door car complete
$10- door card missing top section
$30 for pair- under cover diffuser thingy made of sheet metal. I removed it but dont remember exactly how it was mounted. shoot an offer on it if your interested
$60- 1.6 CAS
$30- 1.6 coil pack
$30- 1.6 coil pack
$20- 1.6 alternator
$90- 5 spd transmission
$80- seized engine for rebuild (complete from oil pan the valve cover with no accessories)
$20- 1.6 header
$250- for everything above completely assembled
$200- Sold spokes with new tires (90% thread left on all tires)
$30- good driver side tail light
$5- cracked passenger side tail light (still usable)
$10- oem steering wheel
$20- oem air bag
$5- dummy air bag cover
$10- shifter
$20- passenger side turn signal in good shape
$5- cracked driver side turn signal
$30 each- complete headlight assembly (lid + bracket + motor + bulb, etc.)
$40- red complete headlight assembly with hella light
$20 each or $30 pair- non power side view mirror
$20-frankeinstien bolts pair with plates
$10- striker plate pair with bolts
$20- glove box in great condition
$20- center console
SOLD- pair of door sills (diy made? but pretty nice)
SOLD- 1.8 tomb stone
$5- rear view mirror
$5 each- eyeball vent
$5- dead pedal foot rest
$5-$10- misc plastic interior pieces
$5- clutch pedal
$5- clutch master cylinder
$5- brake + gas Pedal
$10- brake booster
$10- brake master cylinder
$10- cruise control assembly
$10- windshield wiper motor
$10- speedo cable
$25- black seat belt set pair with retainer (1.6)
$10- 1.8 cross over tube
$20- 1.8 AFM
$20- 1.6 Air box wit AFM
$30- Power steeirng pump with resivor and lines
$5- heater box
$5- AC blower fan
$10- HVAC controller assembly
$20- 1.6 alternator
$20- 1.6 starter
$20- seat with no rails (no tares)
$10- pair of 1.8 seat belt retainers (part that attaches to seat)
text me at (808)561-8206
Attached Thumbnails Massive Part Out-eastsangabrielvalley-20120927-00324.jpg   Massive Part Out-img_20120910_192835.jpg   Massive Part Out-eastsangabrielvalley-20120927-00323.jpg   Massive Part Out-eastsangabrielvalley-20120927-00322.jpg   Massive Part Out-eastsangabrielvalley-20120927-00321.jpg
Massive Part Out-eastsangabrielvalley-20120927-00320.jpg   Massive Part Out-eastsangabrielvalley-20120927-00318.jpg   Massive Part Out-eastsangabrielvalley-20120927-00317.jpg   Massive Part Out-eastsangabrielvalley-20120927-00314.jpg   Massive Part Out-eastsangabrielvalley-20120927-00313.jpg
Massive Part Out-img_20120909_183937.jpg   Massive Part Out-img_20120909_183954.jpg   Massive Part Out-eastsangabrielvalley-20120927-00312.jpg   Massive Part Out-eastsangabrielvalley-20120927-00309.jpg   Massive Part Out-eastsangabrielvalley-20120927-00311.jpg
Massive Part Out-eastsangabrielvalley-20120927-00307.jpg   Massive Part Out-eastsangabrielvalley-20120927-00308.jpg   Massive Part Out-img-20120927-00353.jpg   Massive Part Out-img-20120927-00348.jpg   Massive Part Out-img-20120927-00347.jpg
Massive Part Out-eastsangabrielvalley-20120927-00338.jpg   Massive Part Out-eastsangabrielvalley-20120927-00339.jpg   Massive Part Out-eastsangabrielvalley-20120927-00337.jpg   Massive Part Out-eastsangabrielvalley-20120927-00335.jpg   Massive Part Out-eastsangabrielvalley-20120927-00334.jpg
Massive Part Out-eastsangabrielvalley-20120927-00333.jpg   Massive Part Out-eastsangabrielvalley-20120927-00331.jpg   Massive Part Out-eastsangabrielvalley-20120927-00332.jpg   Massive Part Out-eastsangabrielvalley-20120927-00330.jpg   Massive Part Out-eastsangabrielvalley-20120927-00329.jpg
Massive Part Out-eastsangabrielvalley-20120927-00328.jpg   Massive Part Out-eastsangabrielvalley-20120927-00327.jpg   Massive Part Out-eastsangabrielvalley-20120927-00326.jpg
cyotani is offline
Old 09-29-2012, 06:50 PM
Twibs415's Avatar
Total Cats: 112
how much for the 1.8 axles shipped to 94112?
Twibs415 is offline
Old 09-30-2012, 12:05 AM
marc-111's Avatar
Texted you for various parts thanks
marc-111 is offline
Old 09-30-2012, 09:22 AM
petrolmed's Avatar
Total Cats: 53
Texted you yesterday about the drivers side arm rest.
petrolmed is offline
Old 10-02-2012, 07:48 PM
Young Blood's Avatar
need 5 speed tranny and also alternar shipped to 32771 let me kno
Young Blood is offline
Old 10-04-2012, 01:48 AM
blazues's Avatar
Thumbs up very interested in diff
Hi I'm new! I've had my '90 miata for a few months now and my diff blew yesterday and I need a diff asap! 1.8 preferably. Interested in your diff if its still up sale
blazues is offline
Old 10-04-2012, 12:52 PM
ozzie84's Avatar
Total Cats: -2
how much for the f1 clutch to 75040?
ozzie84 is offline
Old 10-04-2012, 12:57 PM
rleete's Avatar
Total Cats: 1,263
Looking for the top of door trim (outside), both sides. Got any of those?
rleete is offline
Old 10-04-2012, 01:01 PM
RyanRaduechel's Avatar
Total Cats: 123
Do you have an upper control arm bolt?
RyanRaduechel is offline
Old 10-04-2012, 01:46 PM
Are you willing to ship the axles to 75067?
Old 10-04-2012, 01:53 PM
Is the rad fan for the driver or passenger side? I need the passenger side fan.
Old 10-05-2012, 09:56 AM
Dangeruss64's Avatar
do u have a ignition pulse module? how much shipped to nw florida?
Dangeruss64 is offline
Old 10-06-2012, 02:23 PM
cyotani's Avatar
Total Cats: 116
can you send me a pic of the exact part you need. Text me for quickest response please
It was driver side and just sold. Sorry.
axels sold
Sorry, It will be sold with the control arm.
Sorry I don't
PM'd
sorry, to large to ship the trans. If you need the alternator shipped send me a text please.
cyotani is offline
Old 10-07-2012, 01:16 PM
cyotani's Avatar
Total Cats: 116
A bunch of items sold.
Parts list updated.
cyotani is offline
Old 10-07-2012, 02:34 PM
SpuDz's Avatar
Any pics of the 522s on the car? and do you still have the center console? mine never came with one haha
SpuDz is offline
Old 10-07-2012, 02:49 PM
cyotani's Avatar
Total Cats: 116
center console is available.
here's a pic of the car they came off of. The car has a wide body kit.
Attached Thumbnails Massive Part Out-eastsangabrielvalley-20120813-00118-1.jpg
cyotani is offline
Old 10-08-2012, 02:07 PM
bandit mx5's Avatar
i want the starter..how much to ship? is it in pretty good shape?
bandit mx5 is offline
Old 10-08-2012, 07:26 PM
a222133's Avatar
Hi will take OEM head gasket. please email me payment details . maxspring@aapt.net.au
a222133 is offline
Old 10-11-2012, 11:21 AM
Yanballs's Avatar
still have the 1.6 clutch and pressure plate and the 1.8 flywheel?? can't pm so email at yanni_papadopoulos@hotmail.ca, thanks!
Yanballs is offline
Old 10-12-2012, 03:53 PM
Cvobdn's Avatar
Are the strikers for the front or side? If they are sides, I'll take them if you wouldn't mind shipping to 97701.
Cvobdn is offline
Quick Reply: Massive Part Out
