2001 Miata Part Out
Total Cats: 267
2001 Miata Part Out
Parting out a 2001 base with an automatic transmission. 101,000 miles on the clock. The car was wrecked in front. No radiator, but the motor still starts up and runs smoothly with no check engine codes (only ran for short time by me). The soft top is new. Interior is complete minus the driver’s door and radio. The front suspension looks to be damaged. Big ticket item pricing listed below but if you need anything else, let me know. I’ve also got some parts left over from another 2001 Miata I parted out a few weeks ago which are listed below. Prices below are at buyer’s expense. PM or email me at ishroadkill[at]hotmail.com
VVT motor: SOLD!
Soft top w/ frame: SOLD!
Black cloth seats: SOLD!
Black carpet set: $125. Also in perfect shape
Brakes (Caliper, brackets, and rotors): $150.
Axles: $125 per set
Parts left over from previously parted out 2001 Miata:
Black carpet set: $50. No padding under the front carpet
Control arms: Front uppers: $100 per set, Front lower: $100 per set, Rear upper: $20 per set, and Rear lower: $40 per set
Gauge hood: $15
VTSC manifolds (2 available): $50 each (perfect for a Honda manifold build)
NB Power steering rack and tie rods (2 available): $50
Power window regulators: $50ea
Soft top frame (from NA): $75
Radiator: $50
Wheels and tires (1 sets available): $150 per set
AC system: $150
Alternator: SOLD!
Coil packs: SOLD!
VVT motor: SOLD!
Axles: $125 per set
Gauge hood: $15
Radiator: $50
AC system: $150
Alternator: SOLD!
Coil packs: SOLD!
Yeah, wait, what DOES the secondary throttle cable do? Cruise on my NB1 is vacuum actuated from the pedal, but the throttle body still has mounting position for the second cable.
Edit: only automatic miatas have the other cable, which explains why I haven't seen one before.
