Garage clean-out! Lots of aftermarket stuff
Old 01-03-2015, 09:56 PM
EO2K's Avatar
Total Cats: 1,899
Default Garage clean-out! Lots of aftermarket stuff, always adding more.
I've been trying desperately to get my garage cleaned up so I figured I'd sell of the stuff I'm not using.
I'm going to continue to update this thread as I find more stuff to sell, so check back often. I'll start a new thread when I can no longer edit this post.
Prices DO NOT include shipping. Prices listed are OBO, but remember this is not Craigslist. Most things will ship in USPS flatrate boxes, larger things will be somewhat more expensive. If its a $5 or $10 item, don't cry when its $5 to ship it. I accept payment via Paypal. Everything is being sold as-is with no warranty implied. What you see is what you get. If you have questions, please ask. Your assumptions are not my problem.
Here is the deal: the last time I did one of these threads, I had 4~5 people message me and say they wanted something and were ready to pay as soon as I got them a total with shipping. I marked the items as sold and told other perspective buyers that the items had been claimed. As soon as I got them the total, they either backed out or never replied. I was stuck for weeks with parts packaged and ready for shipping while people never paid and never replied. As you can imagine, this left me holding the bag and caused chaos and bruised feelings with other buyers.
If you tell me you are going to buy something, then ******* buy it. If you leave me hanging I will leave you negative iTrader feedback.
On to the parts!
Flyin' Miata NB Swaybar Set - $150 SOLD
Flyin' Miata : Chassis : Suspension components : Flyin` Miata sway bars
Front and rear bars for an NB. Bushings included but you will have to supply your own grease. I ran these on the car for a couple years and they were great, but I've changed things around since then. No, I will not sell you just the front bar.
949Racing Adjustable End Links - $45 SOLD
SuperMiata End Links
Installed at the same time as the above swaybars. They need some cleaning but are still quite serviceable. I don't think 949 sells these with the little rubber dust boots anymore, so i wouldn't worry about them being all dried out and cracked.
Precision 600 Intercooler - $250 OBO
http://www.precisionturbo.net/heat-e...er---600HP/394
This thing is mind-bendingly massive. I bought this earlier in the year from Andrew at Trackspeed from the Theseus part out. As you can see it needs some cleanup but its completely serviceable. I assume the mount tabs work for an NA but I'm happy to cut them off to make shipping easier if you don't need/want them. The thing measures out to be 31.5x8x3.5, the core itself is I believe 28x8x3.5. I/O are 2.75". I was a great deal when I bought it but I've come to the conclusion that this is way more intercooler than I need.
Continental Contitech Timing Belt - $15 SOLD
Quality belt that I would not hesitate to use. I ended up with this as an extra from a timing belt kit.
BANDO belt! - $5 OBO
This has been in my "track spares" box for a while. Check PN to verify fitment before purchasing.
Gates Belt! - $5 OBO
This has also been in my "track spares" box for a while. Check PN to verify fitment before purchasing.
Racing Beat Sway Bar Brace Kit - $65 OBO
Sway Bar Brace Kit for 90-05 (Ex 90-95 w/PS & MS) - Racing Beat
Brace with blocks, new never installed.
Fab9 DIY COPs Kit - $220 OBO
Fab9 Coil On Plug PNP Conversion Kit
This is obviously NOT a plug and play kit. I ordered it from Fab9 without the wiring harness so I could roll my own. All the connectors, pins, weather seals are there so you won't need to run around trying to find parts. This is intended to be hardwired in to the factor harness so NO plug and play harness connector is included. It DOES include 1 set of 4 spark plugs. I've got IK16 (N/A) IK22 (>16psi) and IK24 (<16psi) so pick your temp and I'll include them with the kit.
Nissan SR20 compressor inlet/outlet flanges - $25 OBO
OEM Nissan parts. The inlet has been modified with some sort of tube, probably for a PCV or something. Not willing to separate unless we can find buyers for both halves.
Boomslang Fabrication ECU Extension Harness - $80 SOLD
Boomslang Fabrication | ECU Wire Harness Extensions
Don't butcher your factory wiring! Cut up this instead and make proper god tier solder connections on your workbench rather than using peasant spec vampire taps on your precious factory harness.
ARTech Stainless Braided coolant lines - $50 SOLD
A symphony of AN connectors, stainless braid hose and bulkhead fittings. This won't quite work with my EFR but should be just fine for use with Garrett based turbos. Includes steel AN fittings that I believe screw directly into the turbo itself. Obviously new and never installed so I cannot speak to fitment, but no one really complains about ARTech fitment now do they?
NB1 to NB2 headlight adapter pigtails - $10 SOLD
Built by me to adapt my new headlights. Salvaged NB2 connectors used for correct fitment on the bulbs. Spade connectors plug right in to the NB1 harness, or you can cut them off and hardwire it directly. Could also use some loom to make it less ugly
S2000 Engine Start Button DIY "kit" - $50 SOLD
revlimiter.net - S2000 Starter Button (90-97 Version)
revlimiter.net - S2000 Starter Button (98-05 Version)
Includes a GENUINE Honda S2000 button purchased at great expense from a Honda dealer, rather than a cheap eBay knockoff. Follow along with RevLimiter and build your own pushbutton starter.
Reinforced Sway Bar Mounts - $100 SOLD
AWR Reinforced Sway Bar Mounts 90-05
I picked these up here on MT from someone who had used them for a V8 swap, so the holes were elongated to move the sway bar forward to clear the engine. The braces are designed for left/right reinforcement rather than front/rear so the elongated holes should not make a difference (other than they look a little ugly.) These are the final solution in sway bar mount reinforcement.
Flyin' Miata Throttle Body Inlet Elbow - $20 OBO
Flyin' Miata : Turbochargers : Parts and upgrades : Throttle body inlet elbow
This is a very high quality custom made reinforced tight radius elbow that is included in the FM2 turbo kits. Its 2.5" I/O and thus works with the factory throttle body. Unfortunately it does NOT work with my Skunk2 TB so I'm selling it off.
Turbosmart IWG75 Wastegate Actuator - $125 OBO
Amazon.com: Turbosmart TS-0610-2072 Black 7 PSI Internal Wastegate for Mazda Protege: Automotive Amazon.com: Turbosmart TS-0610-2072 Black 7 PSI Internal Wastegate for Mazda Protege: Automotive
Now includes bonus 5psi spring!
Brand new in the box IWG75 with 7psi spring. I bought this to adapt to my EFR but its just not going to fit. Pushrod should be long enough to work fine with Garrett turbos, provided you create some sort of bracket. The spring is replaceable giving you a lot of tuning options. Turbosmart makes fabulous, high quality products. Definitely worth the cash.
Mazda Competition Motor Mount - $30 SOLD
Mazda Comp Motor Mounts 90-05 Miata
Somehow I ended up with an extra one of these. Save yourself a couple bucks and get one here.
Racing Beat 1.25" OD Swaybar PN 54106 - $125 OBO
Sway Bar - Tubular - Front for 01-05 Miata - Racing Beat
This is the "big bar" from Racing Beat. Its obviously not pretty but still completely functional. RB has fitment is listed as 01-05 but with the right end links I believe it will work with any NA/NB Miata (I recommend you look this up if you plan on installing it in an NA chassis.) Shipping will probably be about $25-30 due to box size.
BP4W valve cover - $50
Dirty on the outside, surprisingly clean on the inside. Includes oil filler cap as pictured.
DIYAutoTune EBC - $32
EBC Electronic Boost Control Solenoid Kit DIYAutoTune.com
Brand new, never installed.
NB1 Cluster - $40
Cluster works, but its missing the 3 screws that hold the OPG to the back of the PCB (easily replaced) and the lens is cracked, see bottom left of image. Other than that, everything works AFAIK. It would be perfect for a custom project or as parts to repair your damaged 99/00 cluster.
NB2 (01) Cluster - $60
Cluster works just fine, no problems. Lens could use a good cleaning.
Mazdaspeed Cluster - $120
This came from Leatherface's MSM part out. It's perfect, no issues.
PLEASE NOTE: None of these clusters include odometers. They are interchangeable between all NB clusters so you'll have to use your old one. If you don't have a cluster to pull an odometer out of, we can discuss that separately. I'm not comfortable helping someone with an odometer rollback.
Thanks for looking!
EO2K is offline
Old 01-03-2015, 10:02 PM
Total Cats: 3,481
Legit parts from an even more legit seller.
Seriously. No one better even dare lowball or flake
18psi is offline
Leave a poscat 1 Leave a negcat
Old 01-03-2015, 10:13 PM
TurboTim's Avatar
Total Cats: 399
Too bad he's not a legit buyer. Never installed the stuff he bought from me, let alone all that's in this thread :(
TurboTim is offline
Leave a poscat 2 Leave a negcat
Old 01-03-2015, 10:23 PM
EO2K's Avatar
Total Cats: 1,899
Thanks 18
I deserve that. But 18psi sold it again after I sold it to him after you built it for me. I'm still incredibly sad no one has run that thing yet, its damn glorious. On a more personal note: Your package would have gone back in the mail today had I not been hungover
EO2K is offline
Old 01-03-2015, 11:04 PM
TurboTim's Avatar
Total Cats: 399
Ahh that's nice. I got all excited when the big black mail lady delivered two large packages this morning. ******* talbots and pottery barn. Thanks G.
TurboTim is offline
Old 01-04-2015, 01:01 AM
JerryMouse4U's Avatar
PM sent for the headlight adapter pigtails
JerryMouse4U is offline
Old 01-04-2015, 02:13 AM
Hot_Wheels's Avatar
Total Cats: -34
I'll take the start button
Hot_Wheels is offline
Old 01-04-2015, 02:34 AM
EO2K's Avatar
Total Cats: 1,899
I saw the PM, will respond in a sec.
That was actually the first thing to sell, sorry man. I need to update the OP.
Thanks all.
EO2K is offline
Old 01-04-2015, 09:55 AM
rwyatt365's Avatar
Total Cats: 128
PM sent for the AWR Mounts
rwyatt365 is offline
Old 01-04-2015, 10:13 AM
hornetball's Avatar
Total Cats: 696
PM'd on timing belt and alternate for AWR sway bar mounts.
hornetball is offline
Old 01-04-2015, 02:23 PM
EO2K's Avatar
Total Cats: 1,899
I have 12 new PMs in my inbox this morning. First come, first serve ladies and gentlemen. I'll reply to everyone and update the OP.
Thanks all!
Edit: Replies sent
EO2K is offline
Old 01-04-2015, 02:35 PM
I understand about the first come first serve thing. I just need your paypal Brah.
Old 01-04-2015, 05:35 PM
EO2K's Avatar
Total Cats: 1,899
Got the payment, thanks Vong
EO2K is offline
Old 01-05-2015, 10:43 PM
EO2K's Avatar
Total Cats: 1,899
YOU get a tracking number! and YOU get a tracking number! and YOU get a tracking number!
If you sent me money your parts shipped today and you should have a PM in your inbox with a tracking number. Hopefully I sent everyone the correct tracking numbers Please let me know when stuff arrives safely. I'll try to get everyone iTrader feedback either tonight or tomorrow morning.
OP is updated. For those who inquired, none of the purchasers backed out so no alternates were required.
Thanks all!
Attached Thumbnails Garage clean-out! Lots of aftermarket stuff-oprah-free-car.gif
EO2K is offline
Old 01-09-2015, 04:52 PM
chilidip's Avatar
You got pm.
chilidip is offline
Old 01-09-2015, 05:00 PM
EO2K's Avatar
Total Cats: 1,899
Oh crap I do. Sorry about that, I'll respond here in a sec.
EO2K is offline
Old 01-14-2015, 12:42 AM
EO2K's Avatar
Total Cats: 1,899
Swaybars sold and OP updated. Bump and such.
Pretty much everything is OBO. Don't be afraid to make me offers, I don't bite
...hard.
Attached Thumbnails Garage clean-out! Lots of aftermarket stuff-mike-myers-austin-powers-1-.jpg
EO2K is offline
Old 01-17-2015, 03:02 PM
EO2K's Avatar
Total Cats: 1,899
Bump because weekend, and added more stuff.
Hornet: I issued you a refund last night, sorry for the stupidity :(
EO2K is offline
Old 01-17-2015, 03:56 PM
bahurd's Avatar
Total Cats: 314
You have PM on the EBC.
bahurd is offline
Old 01-17-2015, 06:11 PM
calimiata's Avatar
I'm interested in the Racing Beat Sway Bar Brace Kit. My post count is too low to PM you. Please shoot me an email if you don't mind:
jdm91integ@hotmail.com
Thanks!
calimiata is offline
Quick Reply: Garage clean-out! Lots of aftermarket stuff
