Garage cleanout - MSM stock and aftermarket parts
Old 06-24-2015, 01:31 PM
midpack's Avatar
Total Cats: 24
Default Garage cleanout - MSM stock and aftermarket parts
All parts are located in St Peters, MO (63376). Discounts available for local pickup in the greater St Louis area.
Lots of stock parts left. Need something but don't like the price? Make an offer. I want it all gone!
MSM wastegate actuator and housing clamp. I forgot what is in the bag, misc turbo hardware I think. If you need any MSM turbo and related bolts, I probably have them
$10 + shipping
MSM cold side piping with bonus 2.5" silicone coupler. Some wear where it rubbed against the fan shroud, no leaks when removed.
$20 + shipping
MSM power steering pump, ~50k miles
$10 + shipping
MSM power steering cooling loop. Some slight bends to clearance larger intercooler.
$free + shipping
MSM sway endlinks, ~59k miles.
$30 + shipping
MSM AC condenser, ~55k miles. Lines will be removed for shipping but are included.
$30 + shipping
MSM AC Compressor, ~55k miles
$50 + shipping
MSM AC lines and a sensor or whatever that is.
$20 + shipping
MSM AC compressor mounting bracket. Supposedly lighter than stock.
$20 + shipping
MSM radiator and fans, ~45k miles. FM says it is better than some aluminum aftermarket rads. Tanks are still black.
$100 + shipping
MSM sun visors, ~1k miles. wrapped in plastic wrap and stored in a box basically since I got the car
$50 + shipping
FM VMAXX, the oiginal ones. Classic or whatever they call them now. Not adjustable. NB top hats included
~35k miles on the shocks, 60k on the top hats
SOLD
Stock MSM steering rack, ~55k miles. Includes everything pictured. Tie rods and some lines will be removed prior to shipping to save costs. Needs new boots on the outer tie rod.
SOLD
FM MSM downpipe, ~40k miles. Removed after turbo destroyed itself and dumped 2qts of oil into the exhaust Cat does not appear to be plugged. More pics available upon request.
SOLD
ARTech oil feed line for ball bearing GT2560. Includes restrictor. Installed but never used (did not work with my turbo orientation). Expect some slight wrench marks on the fittings.
SOLD
Misc fittings, SOLD
1/2" NPT 2560 flange
2x 1/2" NPT - AN10
2x AN10 straight braided hose fitting
45* AN10 push-lock hose fitting
FM intake kit with Turbosmart bypass valve, ~40k miles. Includes everything pictured. Also have an older style O2 signal modifier (not pictured) if you want it.
SOLD
Corksport MSM 3" cat-back exhaust, ~35k miles. Removed after turbo destroyed itself and dumped 2qts of oil into the exhaust
SOLD
Also have the stock cloth MSM seats still sitting in the basement after a few years. ~40-45k miles. Convince me to unwrap them and take pictures.
SOLD
MSM manifold, turbo outlet, water and oil lines, and heat shields. Everything as pictured
SOLD
MSM oil separator pictured one-way drain valve is not included.
SOLD
Attached Thumbnails Garage cleanout - MSM stock and aftermarket parts-80-20150508_153717_c1af97402f2b095b625d18d89cab2f6412fac5f7.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_155515_8fcce640db0b774296bf918997faf7b998b2f65d.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_162945_383b02ab50435d09f5cf41232f1e6c2999ea05d1.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_163003_0a0efae5019abe81b1e018375c17d78e481d4d21.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_163233_e92449d01e131df8d525876cac26e610767e6ab6.jpg
Garage cleanout - MSM stock and aftermarket parts-80-20150508_163350_7018a4e72c8fb43f365102248455a1757ac2871d.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_163346_0fa2547cb5434ecee4d7f7dc7e0ce1bd587bc3a5.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_163926_6a00d429e399f5ef9774ded0c56b3e71e04c5953.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_163938_f66a445c5740669b287ec7ae9439877e30767521.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_164026_23f5c1a6d11e8e2daf4e7fd8eef0cb5381bb2fb0.jpg
Garage cleanout - MSM stock and aftermarket parts-80-20150508_164045_456c7d669266c1490b5cb283f54d4ee25ec8a070.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_164513_65066d88b9bd1ff8afdc9e1d29f76756617ed3cf.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_165750_27949deb3fbe61c4e79d7e63c9320a2426e88cba.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150508_165809_d2a2ea62e2286d0b52c6c842f6af85110ad2dfbd.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150510_130853_066a55f60bfe90d2a0d29db437f9a8ffe8bb8153.jpg
Garage cleanout - MSM stock and aftermarket parts-80-20150510_130613_1fa348303bd3ec93f8bc978808f46626039d1767.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150510_131008_ffe8e4892838831566a7ded6d4228d0cb7ed8e42.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150510_130219_7ce62cab1fcc1a65a1b9c4fb1f7a2835a7b8c63d.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150510_130202_54be7de23ab94a472e48408a4287d69d80afb8ab.jpg   Garage cleanout - MSM stock and aftermarket parts-80-20150510_131712_dcda036a532761262d517e77988c13919a01353e.jpg
Garage cleanout - MSM stock and aftermarket parts-80-20150510_131727_c18b1682035344015503921972e756148c6fb075.jpg   Garage cleanout - MSM stock and aftermarket parts-80-img_20150405_125116_de5f55c34c48dcb2bd9ff4d831b43002f3445bb9.jpg   Garage cleanout - MSM stock and aftermarket parts-80-img_20150405_125132_f408cc6065f1fec668f7474ab83bb03f73174031.jpg
midpack is offline
Old 06-24-2015, 01:43 PM
Danschutz's Avatar
I'll take the fm downpipe please!
Danschutz is offline
Old 06-24-2015, 02:03 PM
midpack's Avatar
Total Cats: 24
It's yours. I'll find a box and get you a shipping quote.
midpack is offline
Old 06-24-2015, 09:19 PM
dscsk8er55's Avatar
Would you mind selling just o2 modifier and the turbosmart BPV? If so I will take either or both
dscsk8er55 is offline
Old 06-24-2015, 11:14 PM
midpack's Avatar
Total Cats: 24
Sure. PM me an offer and I'll dig the O2 mod out tomorrow.
midpack is offline
Old 06-25-2015, 08:48 AM
OneTwo's Avatar
Total Cats: 36
PM incoming for remaining FM intake parts.
OneTwo is offline
Old 06-25-2015, 08:54 AM
concealer404's Avatar
Total Cats: 2,201
I'll take the steering rack. PM me with total cost to 46237. Thanks!
concealer404 is offline
Old 06-25-2015, 01:14 PM
zoneorigins's Avatar
Total Cats: -4
Ill take the msm manifold with lines shoot me a pm with a quote on shipping to 12570
zoneorigins is offline
Old 06-25-2015, 03:04 PM
slammed200's Avatar
Total Cats: 29
Hey Andrew I may missed the boat on some things but I'm interested in the FM intake and oil separator with drain back valve. Also the corksport exhaust
slammed200 is offline
Old 06-25-2015, 11:07 PM
midpack's Avatar
Total Cats: 24
PM sent.
PM sent.
I am not Andrew, PM sent anyway. One-way drain back valve is already sold, sorry.
midpack is offline
Old 06-25-2015, 11:08 PM
midpack's Avatar
Total Cats: 24
First post updated, now with more VMAXXXXXXXXX
midpack is offline
Old 06-26-2015, 08:29 AM
slammed200's Avatar
Total Cats: 29
You are indeed Kevin, not andrew, Midpack and not Midtenn. PM replied
Old 06-26-2015, 09:37 AM
midpack's Avatar
Total Cats: 24
replied
midpack is offline
Old 06-26-2015, 12:24 PM
calteg's Avatar
Total Cats: 40
Any idea on the OD of the Vmaxxxxxx springs?
calteg is offline
Old 06-26-2015, 04:58 PM
Go Blues's Avatar
May be interested in the seats, can you pm me what you are asking?
I am in O'Fallon and am a big time newb with no PM-ability
Thanks!
Go Blues is offline
Old 06-26-2015, 06:33 PM
midpack's Avatar
Total Cats: 24
Turbosmart valve and o2 mod are sold and shipping this weekend.
3.1" according to my measurements. I can email FM and get an official dimension if you would like.
Thanks!
PM incoming
midpack is offline
Old 06-27-2015, 08:00 PM
calteg's Avatar
Total Cats: 40
PM incoming
Yeah, gotta be 2.5" or less to clear the 15x9 6ULs
calteg is offline
Old 06-28-2015, 09:14 AM
slammed200's Avatar
Total Cats: 29
Did the FM intake sell with them?
Old 06-28-2015, 02:41 PM
midpack's Avatar
Total Cats: 24
FM downpipe, VMAXX, and steering rack are sold and shipping tomorrow. Thanks guys!
Not with them but the intake is sold pending payment on Tuesday.
midpack is offline
Old 06-29-2015, 07:12 PM
midpack's Avatar
Total Cats: 24
Oil line and AN fittings are sold and shipped today
midpack is offline
Quick Reply: Garage cleanout - MSM stock and aftermarket parts
