biodiesel
Old Apr 11, 2007 | 02:39 AM
rockdoc's Avatar
Default biodiesel
can biodiesel ethanol/methanol be used in place of pure methanol for injecting?
Old Apr 11, 2007 | 02:43 AM
You'd be better off injecting straight water.
No need for pure methanol.
Old Apr 11, 2007 | 02:44 AM
rockdoc's Avatar
ah!-ok thanks- just struggling to find a local supplier of methanol
Old Apr 11, 2007 | 02:50 AM
Run distilled water. You can get it at the grocery store. It will suffice for now.
If you can't find large sums of methanol to mix your own then you can always run windshield washer fluid from walmart as well. As long as it is the -20 mixture it should have a good % of meth in it. Cans of Heet are also methanol. Research using alcohol as well, it's not as good, but I might have read that it works.
Distilled will still show you impressive gains. Atleast from what i've seen.
Old Apr 11, 2007 | 03:06 AM
akaryrye's Avatar
so cj, are you planning to control the water injection with megasquirt?
Old Apr 11, 2007 | 08:11 AM
Any fuel or oil dealer should be able to get you methanol by the 55 gallon drum. as there are probably people who run it on there automobiles and industrys that use it in Ireland somewhere the government regs on procurement are another story i have no idea on that one.
Old Apr 11, 2007 | 08:36 AM
Arkmage's Avatar
biodiesel != methanol.
edit* for those who have never programmed in C++ "!=" means "not equal to"
Old Apr 11, 2007 | 03:23 PM
Total Cats: 7,549
Methanol is used in the production of biodiesel, but the two are not the same. Further, biodiesel is non-miscible in water.
Rocdoc- see if there are any race shops in your area. Kart racing, drag racing, even some forms of motorcycle racing all use meth. I buy mine in 5 gallon jugs from a local hotrod shop which specializes in aircooled Volkswagens for drag and desert use.
Old Apr 11, 2007 | 04:45 PM
rockdoc's Avatar
i can get some delivered /posted believe it or not!- they are a bit strict on this stuff over here (uk)unsurprisingly .
wanted it for the weekend - but it,ll have to wait till next weekend now
Old Apr 11, 2007 | 05:47 PM
wow we cant get it delivered like that good deal
Old Apr 11, 2007 | 09:28 PM
Total Cats: 7,549
Doh! Must read fully and carefully before responding. A pox on your highly portable object-oriented language. Real Men(tm) write 680x0 Assembly.
Landscaper
Dec 29, 2010 02:53 PM
mgeoffriau
Current Events, News, Politics
19
Nov 21, 2010 01:15 AM
Dange
Insert BS here
14
Nov 18, 2006 01:01 PM
