E-Manage Post your questions about greddy e-manage installation and tuning here.
O2 clamp but car is still running lean help please
Old Nov 4, 2007 | 10:48 PM
musanovic's Avatar
Default O2 clamp but car is still running lean help please
Installed the o2 clamp and the car still leans out on top end. i even get a hesitation around 4000rpm maybe even a detonation after it passes 4000rpm it pulls fine again. what could be the issue here. my log is below with the appropriate file.
log http://www.mediafire.com/?0ygjzlbugxe
file http://www.mediafire.com/?5dz44idiyfx
please help me out and if i need to make any changes let me know .
Old Nov 5, 2007 | 11:15 AM
chico's Avatar
Maybe i have some ideas.
Don´t start an autotune run with "0"´s in the i/j map. You would run lean until the emu correct´s it, and you will get some nice detonations
Use something about "25" instead of "0" in the upper boost and rpm area.
It is going to run very rich, but the emu correct´s them down after some time.
And use an 1sec start time and 0,5% feedback amount in the a/f target setting.
Also i would recommend to disable your unused map´s, only for a clean overview.
Also change the voltage of your o2clamp to something about 0,38V.
An easy way to check the correct setting of the clamp is to activate the clamp in idle, set the tps in the afr target parameter to 1% (to start the autotune) and look at the corrections made by the emu in the i/j map. If the correction factor is about +/- 1 the clamp is set fine.
Which firmware are you using ?
Old Nov 5, 2007 | 01:01 PM
Total Cats: 7,549
+1 on this. The Autotune isn't magic- you are best using it to refine a rough map, rather than generating a new one from scratch. Here's my stab at a starting point for your I/J 1 map:
To generate this I simply put "80" in the leftmost (500) and rightmost (8000) cells of the +10 PSI row, then selected the whole area shown highlighted, and used the "interpolate 4 corners) function. In this setup it will probably run rich initially, but it gives the autotune a much easier job to do.
Later on in the process perhaps. For now I think the 2% feedback is a good place to start. Initially he's going to be making very coarse corrections- once Autotune has had a chance to get most of the cells close, then dial it down to 0.5% to do some fine-tuning.
I'd also suggest that you fill out the portions of the A/F target map below 2,000 RPM, just for kicks.
His clamp was pre-set to 0.37 volts when shipped. Should be good to go.
It's simpler than that. You don't need to tweak the TPS or AFR stuff, just go to the Aux Output map and manually switch all the cells to "ON" while observing the WBO2 sensor. When the clamp engages, the ECU will drive the idle mixture very rich. (It will eventually throw a CEL on an OBD-II system as well.)
Old Nov 5, 2007 | 01:03 PM
musanovic's Avatar
i am using the 2.13 update on the system. thanks for the info really appreciate it.
Old Nov 5, 2007 | 01:24 PM
chico's Avatar
You are absolutly right.
I only recommended my procedure because it shows a little bit the routines of the emu. The benefit is a little learning effect and practice with the emu.
But finally i have to say Joe, there is nothing more to say
I feel so unworthy now
Sometimes i´m angry about my "slow" english, it tooks a lot of time to write something. But it will get better.
Old Nov 5, 2007 | 01:46 PM
musanovic's Avatar
great help guys
How does my ignition map look
i have a decent size front mount and am running 93 octane. no water methanole yet. could that cause my detonation. or should i retard it a bit more. i am running a open wastegate and so i can not hear many pings or anything else. i want to run on the safe side.
for my friend chico vielen danke ich wohnte in deutschland 5 jahren Regensburg bereich.
Old Nov 5, 2007 | 02:03 PM
Zabac's Avatar
alle deutschen, wie gehts? mein deutscht ist sehr schlecht...prost
i love this stuff
Old Nov 5, 2007 | 04:01 PM
Total Cats: 7,549
Please, I did not mean to offend. I realize that I sometimes seem argumentative- it is not my intention to belittle anyone for offering advice. I think you are correct about learning and practice.
Also, you speak English much better than I speak German.
Old Nov 5, 2007 | 04:05 PM
musanovic's Avatar
so i am safe to assume if i retard timing 1.5 deg per psi that i should be on the safe side?
Old Nov 5, 2007 | 04:09 PM
Ich benutze einen ubersetzer aus meinem Deutsch, denn ich kann nicht lesen oder sprechen eine lecken werden.
Old Nov 5, 2007 | 05:14 PM
Zabac's Avatar
das ist sehr gut scott, ich kann dich deutsch unterrichten und do kanst mir MS erklären...
i cheated a bit
Old Nov 5, 2007 | 10:38 PM
musanovic's Avatar
Thumbs up
ok what can i say, you guys are life savers once again. drove the car and everything seamed to be great. A/f is great and the car runs strong. so strong that i don't have a clutch any more. Thanks for making it work i really appreciate everything. :bowd own:: bowdown::bowdo wn:
Old Nov 5, 2007 | 11:54 PM
Total Cats: 7,549
Good to hear that it's working for you.
As an aside, I would suggest rescaling your maps. You don't need all those rows in the non-boosted area (two rows will handle it: one at -14.5, the next at -1) however I would suggest adding more headroom at the bottom. Even if you don't *plan* to ever run at 15 PSI, you should have some data there to cover yourself if the turbo occasionally spikes that high.
Old Nov 6, 2007 | 12:00 AM
musanovic's Avatar
i will do that asap since the turbo does sometimes spike more than i want it to. I am using a super 60 and it just wants to spool, great thing though. thanks for the heads up Joe and should i just put the values for my fuel map you provided earlier in the 15 psi cell the number 80 and do the same i did for 10psi. thanks again.
-jasko
Old Nov 6, 2007 | 12:08 AM
Total Cats: 7,549
Don't forget to rescale your A/F Target and Ignition maps as well.
Old Nov 6, 2007 | 12:10 AM
musanovic's Avatar
it would be a bad idea to forget but i am currently working on it Thanks for the heads up.
Old Nov 6, 2007 | 01:41 AM
chico's Avatar
i cheated a bit
Nicht schummeln, :gay: schummeln ist schwul.
Translate that
Let´s make a german ms guide, yeah, i would like that.
Old Nov 6, 2007 | 01:46 AM
chico's Avatar
Translater from german to english are always funny.
Your translation at the end of the sentence means, that you would lick an chick. Nice
Old Nov 6, 2007 | 04:00 AM
chico's Avatar
Nice, welcome to the dark side.
By the way, which base timing does your car have?
Old Nov 6, 2007 | 09:05 AM
musanovic's Avatar
i am assuming that i am running 10deg BTDC than am pulling 1deg per psi.
