Electronic failure I am.......
Total Cats: 58
Summery of the issue.
Car started and idles ok. Quick look at the Kenwood screen and it reads to me "PROTECTED". I feel that grounds might be the cause and do a search on google for proper grounding recommendations. I learn that having multiple items grounded to the same point, is not good. I had the ECU, LC1 wideband and gauge, and the Kenwood unit all grounded at the ECU ground location on the block. I changed the ground for the Kenwood and it works fine now, as well as the car idles smooth.
Now, when I hit the throttle I can hear a "click....lick hick click" sound from under the dash. Like a fuse, relay, something that clicks? The idle dive bombs and the car stalls. Or I can blip the gas a couple times, hear some more clicks (not every time) and then take my foot off the gas and let it stall. Since I had the car started last the only thing I really have fucked with is the electronics.
After reading more on grounding, I am almost certain this is my problem. However .01% of my brain is capable of working with electronics. Sometimes I'm lucky and I zone out while working with wires and when I'm done things work, but not always 100% all the time.
Any ideas?
Vash-
Any ideas?
Vash-
Multi ground theortically should not be a problem - although i had the same prob with my AEM UGEO - it did not like sharing a ground with my boost gauge.... Although I just added 3 new gauges and they are fine sharing grounds ?? Strange...
Total Cats: 7,549
Strange...
In theory, it is best for all devices which are part of a system (such as the ECU, WBO2, sensors, and displays) to use the same ground, so long as it is a very good ground.
When multiple devices which interact use different grounds, there is a real potential for the various grounds to have slightly different resistances, thus causing an imbalance in the voltage potential across these devices. This can cause sensors to be misread and such.
If you had a problem with everything connected to one ground, then that ground was insufficient. Either dirty or bad connections, inadequate wire, etc.
Now I'm not saying they all need to go down the exact same wire. The MS, the WBO2, and the sensors can all have their own ground wires. In fact, it's preferable for big noisy high current stuff like coils and injectors to have their own separate ground connections. This is one shortcoming of the MS- even in the current 3.0 PCA, the injectors use the same ground as all the sensors and logic circuits. OEM ECUs provide separate ground paths for the high-current stuff, to prevent them from putting noise on the analog circuits.
Regardless, they all should ideally terminate at exactly the same place. In my case, I have two big ring terminals at the back of the head where all the ECU-related ground wires end up.
On the EGT is was a power ground that shared the same anchor point as the AF and Oil temp gauges. On the LC1 it was the signal sharing the same ground with power grounds. Once those were moved, everything worked ok so I classified it as fixed.
Zaphod
47
Oct 26, 2018 11:00 PM
Der_Idiot
12
Sep 3, 2015 03:31 PM
