1.8 VHT High Heat Wrinkle Red Valve Cover
Old Nov 16, 2009 | 02:05 PM
Pharo_X's Avatar
Default 1.8 VHT High Heat Wrinkle Red Valve Cover
:SALE PENDING:
Valve cover is off a 1.8 Protege.
- 3 Coats of VHT High Heat Wrinkle Red fully dried and cured under 200F Oven degree for about 20 minutes.
- Raised Letters Polished
- Back Hole Plugged tight
- Tapped side for vent
- Will include everything as pictured here along with a good condition gasket and the center plug wire holder brackets.
Have not been put of to use. All the work is done, you just need to buy it and put it on.
Price Shipped and Paypal'd is $100 Flat.
Local SoCal Long Beach area pickup is $90 Flat.
Finished engine look would be similar to below with Cam Gears exposed.
Attached Thumbnails 1.8 VHT High Heat Wrinkle Red Valve Cover-wrinkle_red_vc.jpg
Old Nov 16, 2009 | 03:21 PM
zoomin's Avatar
I can't recall, but does the Protege valve cover have the provision for the Miata coil bracket?
Old Nov 17, 2009 | 02:49 AM
JerryMouse4U's Avatar
Man Im surprise this isn't sold yet, too bad its not for a 1.6.
Old Nov 17, 2009 | 01:04 PM
Pharo_X's Avatar
Not sure what I was thinking of, prepping it up thinking it would fit my 1.6 "BIG FAIL".
Maybe someone else can make better use of it.
"Zoomin" - it does have enough clearance for the back coil area if that's what you meant.
Thanks for looking.
Shoot me some PM if anyone's interested.
Old Nov 17, 2009 | 03:26 PM
zoomin's Avatar
I want it, but don't need it. Any parts you are in need of for a trade?
Old Nov 17, 2009 | 04:47 PM
jtothawhat's Avatar
Great looking manifold....GLWS I just made the same mistake as you...
Old Nov 20, 2009 | 10:54 AM
Pharo_X's Avatar
Trade is ok, but not sure how we can go forth with such, unless it's a local trade.
Looking for wideband 02 sensor/gauge, 1.6 valve cover with raised letter, aftermarket Cam Gears, interior dress up, rear strut brace...
I can always add on my end.
Old Nov 20, 2009 | 11:05 AM
FRT_Fun's Avatar
I'm a terrible person
Total Cats: 180
So just to be clear.. this would fit my 97 1.8L no problem?
If so... and pending your possible trade with other buyer, I would like it.
Old Nov 20, 2009 | 12:44 PM
Pharo_X's Avatar
It should fit the 1.8 fine.
It DOES NOT fit the 1.6 because of the back loop (as illustrated below). The 1.6 is on passenger side, and 1.8 is on driver side as the valve cover I'm selling.
Hope that clears it for anyone else trying to do the Protege valve cover.
Zaphod
47
Oct 26, 2018 11:00 PM
russian
Oct 8, 2015 03:01 PM
JesseTheNoob
Sep 30, 2015 02:44 PM
