FMIC Installed
Old May 20, 2007 | 07:31 PM
ray_sir_6's Avatar
Guest
Default FMIC Installed
It only took 2 days to do, and alot of fab work by Brice @ Alamo. We mocked up the passenger side Saturday, then put back the stock stuff so I could drive home. Then went out there today (Sunday) and mocked up the driver's side and then installed it. It uses 2" on the DS and 2.5" on the PS.
The PS is probably pretty typical of most FMIC installs. It just goes up between the radiator and the pulleys, straight to the throttle body. No BOV right now due to the supplied bung being steel, not aluminum. Should get that installed soon.
Old May 20, 2007 | 07:34 PM
ray_sir_6's Avatar
Guest
The DS took alot more tiem and fab work. We clocked the turbo, then went down thru the gap in the sub-frame and between the suspension control-arms to the IC.
Old May 20, 2007 | 08:26 PM
rappadan's Avatar
daymmm, thats a lot of pipe! I like the slight "v" mount ness of the IC...
Old May 20, 2007 | 09:25 PM
ray_sir_6's Avatar
Guest
Really had no other way to do it, with all the power steering and AC lines on that side.
Old May 20, 2007 | 09:29 PM
strangest WI resevior ever
Old May 20, 2007 | 10:27 PM
ray_sir_6's Avatar
Guest
Still considering a WI setup as well. Of course, still considering installing my Zex Nitrous kit, too.
Old May 21, 2007 | 08:51 AM
Total Cats: 4,368
do you have your breather port blocked off??
Old May 21, 2007 | 10:00 AM
Pitlab77's Avatar
i dont see any pictures
Old May 21, 2007 | 10:11 AM
jwarriner's Avatar
Old May 21, 2007 | 10:15 AM
Total Cats: 4,368
no ****...i can see....
let me rephrase....why do you have your breather port blocked off??
Old May 21, 2007 | 10:27 AM
jwarriner's Avatar
I was showing PitLab.
Old May 21, 2007 | 10:37 AM
Total Cats: 4,368
wouldn't we assume pitlab is talking about all the pictures in general?
Old May 21, 2007 | 10:55 AM
jwarriner's Avatar
"We" might, but I actually assumed he didn't see any pictures of the breather port.
Old May 21, 2007 | 12:04 PM
you weld better than I do. there's a reason why I didn't post up pics of the exhaust I put together.
don't think i would have welded up a charge pipe to the compressor, but your work does look nice. you might want to invest in a real water temp gauge, just in case that big *** fmic at the funky angle doesn't let air get to the rad.
Old May 21, 2007 | 01:58 PM
Pitlab77's Avatar
filter at work is being really lame today :(
They blocked half the site I go to and now my University E-mail which I need to check to look up my Grad school grades :(. this is lame
Old May 21, 2007 | 03:43 PM
Also wondering about airflow to rad.. asking a lot of the air to make it turn from parallel to ground, ~30*, then back to parallel to go to rad. I think the only thing I'd change is that. And I'd give the bay a good scrub, haha.
pitlab: www.cantbustme.com
Old May 21, 2007 | 03:49 PM
Total Cats: 4,368
my only problem with the design is that you've basically sealed the mouth with the intercooler, so no air can go around the i/c and make it's way directly into the radiator.
even with most "big" ic setups, they don't plug the top and sides of the opening of airflow and the radiator still gets plently of airflow even at the north most edge of it. (radiator is something like 25" wide x 17" tall)
but if you dont have cooling systems problems, then it'll work.
Old May 21, 2007 | 07:05 PM
Pitlab77's Avatar
thats blocked too. I'm guessing its a proxy. Every proxy I have tired is blocked
Old May 21, 2007 | 08:12 PM
ray_sir_6's Avatar
Guest
Kinda forgot about it till I got home, and then did the only thing I could, stuck a bolt in it. Was gonna do a catch can, but didn't.
Old May 21, 2007 | 08:14 PM
ray_sir_6's Avatar
Guest
No cooling issues at all. Still reads the same as before the FMIC.
