1.6 oil supply tap
Old Jul 19, 2006 | 05:35 PM
Kirby's Avatar
Default 1.6 oil supply tap
Can someone tell me the what the thread is on the Oil supply tap on the 1.6?
Thank you!
Old Jul 19, 2006 | 05:54 PM
Loki047's Avatar
Total Cats: -5
on the block it is 10 x 1.5
Old Jul 21, 2006 | 03:52 AM
Kirby's Avatar
Do you know what that would equate to in NPT?
Old Jul 21, 2006 | 07:58 AM
bripab007's Avatar
It doesn't equate to anything in NPT. NPT threads are different than std. metric threads.
Old Jul 21, 2006 | 09:06 AM
Kirby's Avatar
Hmm okay thanks for the help, does anyone know where you can find this fitting?
Old Jul 21, 2006 | 09:11 AM
Sirnixalot's Avatar
Total Cats: 17
you want a straight 10 x 1.5 to -4an or you feel like a banjo bolt?
summit has em both
the straight -4an to 10mm x 1.5's part number is EAR-9919BFDERL
the banjo has 2 part numbers,
the bolt - EAR-977520ERL
the banjo fitting - EAR-997641ERL
Old Jul 21, 2006 | 09:22 AM
Total Cats: 7,549
See these two threads on the subject:
http://tinyurl.com/zjfxy
http://tinyurl.com/fgaue
I went down a similar path to Jayc72 in the first thread with the brake banjos. Very elegant. Unfortunately, -4 banjos in the 90* configuration are hard to come by, so I suggest using a -3 to -4 coupler just after.
http://www.summitracing.com/ is your friend. Go to "Online Store" and hit the plumbing section. More hose ends and adaptors than you can shake a wastegate rod at. You'll have to be somewhat creative in how you search, but if someone makes it, they've got it.
Often times, using the search engine near the top of these pages (on the blue bar) will produce a wealth of knowledge. For example, entering greddy oil lines turned up those two threads I linked to near the top, and a wealth of other data.
Old Jul 21, 2006 | 09:43 AM
bripab007's Avatar
I've know I've personally been involved with at least half-a-dozen oil line threads in which I've posted direct links to the parts needed on Summit's site.
Old Jul 21, 2006 | 10:03 AM
-3AN is closer to the stock greddy line than -4AN. Which is a bonus since that's more common in brake lines/fittings.
And you don't need a 90* fitting, I did it with a 90* built into the line. I have the 90* coming up to the turbo.
Old Jul 21, 2006 | 12:17 PM
Loki047's Avatar
Total Cats: -5
I welded a metric stud to a NPT coupler, now its NPT and for $1.35
Old Jul 21, 2006 | 01:00 PM
Total Cats: 7,549
No ****? That's more or less what I'd consider the perfect solution. Any pix?
Sadly, the only M10x1.5 to -(x)AN adaptor that Summit sells is aluminum.
Old Jul 21, 2006 | 01:08 PM
Loki047's Avatar
Total Cats: -5
yeah give me a minute. just got stung by a wasp ( you can get all the parts from fastnal)
Old Jul 21, 2006 | 01:24 PM
Loki047's Avatar
Total Cats: -5
Here ya go.. if you make it, be sure to weld everything straight! not much space.
Attached Thumbnails 1.6 oil supply tap-photo_072106_001.jpg   1.6 oil supply tap-photo_072106_002.jpg
Old Jul 21, 2006 | 04:59 PM
Total Cats: 7,549
Ok, I'm impressed. Somehow I doubt I could weld something that small, keep it straight, and get good penetration, without burning a hole through the damn thing and filling the passage with slag.
Old Jul 21, 2006 | 05:10 PM
Loki047's Avatar
Total Cats: -5
if its too hard I can send you one. only thing you would have to do is lathe a hole in the bolt
Old Jul 21, 2006 | 05:11 PM
drftem's Avatar
ok sorry to thread jack. on the stock greddy setup to bolt the oil feed line to the turbo and to the block is that just a regular bolt? or a special bolt. i need that piece and the washer. i have the oil line but i need those bolts. so im just trying to find out were i can get those.
Old Jul 21, 2006 | 05:59 PM
Total Cats: 7,549
Ok, I gotta step out of character for a moment here...
<SOAPBOX>
Drftem the Bagger,
Look at messages numbered Six and Seven of This Very Thread.
Click The Links.
Read The Threads Which Are Referenced Therein.
</SOAPBOX>
Ahem. Sorry, folks.
Old Jul 21, 2006 | 06:05 PM
Total Cats: 7,549
All I gotta do is lathe a hole in the bolt. Hmmm. Gotta buy me a lathe first, though. <grin>
In all seriousness, I appreciate the offer, but I'll stick with the Banjo fitting for now- no sense changing what works. Just wish I'd have thought of your idea first.
Old Jul 22, 2006 | 12:29 PM
Kirby's Avatar
Okay thanks for all the help guys, i really appreciate the help. I got one more question though. What fitting do I use on the Oil supply side of my Turbo? I have a Garret T25 off a DSM. I will be using a -4an Hose.
Thank You!
Zaphod
47
Oct 26, 2018 11:00 PM
Apr 21, 2016 03:00 PM
Aroundcorner
Oct 1, 2015 03:20 PM
Trent
Oct 1, 2015 12:15 PM
