EFR6258 on a VVT W PS/AC
For some reason that picture just screams "BAD IDEA" to me, but i have no evidence to back it up with. In for results.
I had luck with stuffing my catch can with steel wool for the same reason, and from what I've seen of the stuff I'd never put in the valve cover baffels. Not sure on that nylon stuff, it might be fine.
Sounds like a much better idea, that is my main problem with steel wool; that **** flakes off and gets EVERYWHERE. would not put it near any engine internals :P
I want to say I remember reading about JasonCSBB fooling around with something like this on m.net, but a short search I couldn't find it. I want to say that the material in the baffles wicked the oil up and filled his intake/catch can, but I may be 100% wrong. Maybe it was removing the baffles that was the problem.
Not to be negative, but i'd want it rated for at least 300 degs before i'd consider using it. Also, think about the airflow past it, the oil and gasoline(or e85) contamination, and the heat altogether over thousands of miles.
Total Cats: 9
Notice something? It has the same reaction to heat as my pecker does to the cold..... the more extreme, the smaller it gets! While I am no longer worried about a molten puddle of plastic resting perfectly under a valve shim and thus f*cking up my rather expensive head, I do believe the copper is a much better way to go.
YAY DATA! This is why I love MT.net. Any other car forum would have 5 pages of people arguing about why it would work or wouldn't work. Here we just throw that **** in the oven and melt it.
Total Cats: 9
Well ****! I turned the oven off after I took the last picture of over 400 degrees and was considering leaving this in until I get around to powder coating the valve cover. Then I opened the oven and found this......
Guess I am looking for a copper scrubby!
Yeah I didn't think about the time factor. A real test would be to put it in a bowl of oil, leave it in the oven on 250°F for a few hours, then turn the oven off and leave it until it cools. Then see what it looks like.
Total Cats: 1,091
