ARP hear stud question
Old Aug 15, 2014 | 01:18 PM
jandjracing_58's Avatar
Total Cats: -42
First off, please don't give me **** about repeat threads, it takes 10 second to reply this post.
I know what I'm going to torque my head stud nuts to.
I'm looking for specs on what to torque the stud into the block.
Much obliged
Leave a poscat -11 Leave a negcat
Old Aug 15, 2014 | 01:58 PM
glade's Avatar
Total Cats: 17
I'd say 190-200 ftlb....since it takes like ten seconds
Old Aug 15, 2014 | 02:30 PM
pdexta's Avatar
Total Cats: 184
I believe "finger tight" is the spec you're looking for. There's a allen key fitting on the end of the stud, I always just snugged it down with that, but my **** always blows up so maybe don't do that.
Old Aug 15, 2014 | 02:33 PM
soviet's Avatar
Total Cats: 269
a few kilograms
Old Aug 15, 2014 | 02:41 PM
99Racer's Avatar
Total Cats: 21
go to the product source...
ARP | The Official Web Site
Old Aug 15, 2014 | 03:25 PM
williams805's Avatar
Total Cats: 27
Finger tight.
There is a video somewhere with an ARP rep saying why exactly.
Basically don't want and side load on the stud. Just a staight pull. By only going finger tight in the block the stud still has fredom to move around allowing the nut and washer to determin the "straight pull".
Something like that.
Old Aug 15, 2014 | 05:10 PM
Total Cats: -42
Your were correct, thank you. But I'm wondering why they want 80ft lbs? I'm not going past 60, nope nope nope
Old Aug 15, 2014 | 05:11 PM
Total Cats: -42
Thanks for the link
Old Aug 15, 2014 | 05:25 PM
You're going to use an ARP product because they're superior, but choose to ignore their instructions?
Curious choice.
Old Aug 15, 2014 | 06:12 PM
Total Cats: -42
Curious choice.
Not so much ignore just weary of cracking my head, I did it to my 99 headed following those instructions. I think this time I'll split from factory to the ARP suggestion and just do 60
Old Aug 15, 2014 | 06:24 PM
There's no way possible that torquing those studs to ARP's specs in the proper manner will cause your head to crack.
On the contrary, torquing ARPs to factory specs can and will probably make your head gasket leak.
If you're going to use factory torque specs, then use factory hardware.
Old Aug 15, 2014 | 06:49 PM
bbundy's Avatar
Total Cats: 146
ARP torque spec of 80 for a 7/16 bolt with moly is just rediculus. and I can say it can and did crack a head. The Miata aluminum head under their tiny washers squishes with permanent deformation with that much clamp load. 20 to 30% increase in effective clamp load over stock is probably Ok more than double is silly.
Old Aug 15, 2014 | 07:04 PM
Weird. I took the set on the f2 to 100ftlbs, miata to 80. No issues.
Old Aug 15, 2014 | 07:15 PM
asmasm's Avatar
This thread:
https://www.miataturbo.net/engine-pe...e-miata-54746/
Old Aug 15, 2014 | 07:21 PM
it takes 10 seconds to search
you just think you're special
Old Aug 15, 2014 | 08:01 PM
Total Cats: -42
Wow, I might as well close my eyes and turn the wrench based on all this confusion. There's too much bullshit on most of these threads.
I'll go 70 and just trust my intuition
Old Aug 15, 2014 | 08:17 PM
Total Cats: 1,924
Torque spec? ALLOFIT
Old Aug 15, 2014 | 08:26 PM
so let me get this straight:
-you ask a question that has been discussed and easily found
-you tell everyone to spoon feed you the info cause you're too special to adhere to the rules everyone else does
-you call people out
-you conclude the thread with calling everyone a bs'er
Congrats. I don't think you coulda been more of a douche if you actually tried.
Old Aug 15, 2014 | 08:27 PM
By the way: to all those that spoon fed him - this is the direct result of your spoon feeding, self entitled douchenozzles that will never actually learn
Old Aug 15, 2014 | 10:14 PM
Total Cats: 27
I did 78 ft lbs. I thought I read from either Emilio or Andrew about not going over 85 or something like that. Don't quote me on that but it's what I recall. I figured that was close enough to 80. + The lube on thread and nut and washer I figured that was plenty.
