Forged pistons for daily driving
Old Oct 5, 2014 | 03:44 PM
Vincentmiata's Avatar
Total Cats: 19
Default Forged pistons for daily driving
At the moment i have a 10th for my daily driving and the red NA sitting still to fix the engine. Soon going to install a 2560 or 2860 and i need some oversize pistons. Maybe as the NA driving again the 10th will be sold
Are forged pistons good for daily short driving? will be less than 5 mile driving
Old Oct 5, 2014 | 04:56 PM
turbofan's Avatar
Total Cats: 1,092
No.
Ed@949Racing/Supermiata
www.949racing.com
Old Oct 5, 2014 | 04:57 PM
This is a completely new topic.
Never before have we discussed forged pistons and daily driving.
You just started a revolution.
The world is not ready for you yet.
You are the hero we all deserve, but don't need.
Old Oct 5, 2014 | 05:18 PM
Total Cats: 19
Well i had to ask. There are indeed tons off threads like this.
But at first there is the main question.. some answers that has no relations with question itself. and then there are all the gay answers like you suck and this is total new. And so there are tons of threads with no answer.
Old Oct 5, 2014 | 05:22 PM
turbofan's Avatar
Total Cats: 1,092
Here's a spoon. I typed "forged daily" into the search box. This thread was on the first page of search results.
https://www.miataturbo.net/engine-pe...-driver-77340/
www.949racing.com
Old Oct 5, 2014 | 05:38 PM
Stealth97's Avatar
What yall talkin bout? Cant i use forged if i live my life a quarta mile at a time?
Old Oct 5, 2014 | 05:46 PM
Total Cats: 19
Thats my bad. I only searched trough google.
Engine has been rebuild 1000km ago but broke down again because of some problems with a gasket at the oil pickup
But then again. That thread says it should be no problem. Others says it is not good. Wisecos are strong but needs good warm up and therefor not a good choice?
Old Oct 5, 2014 | 05:52 PM
Erat's Avatar
Total Cats: 830
This is just my opinion and i have no scientific research to back it up. But in my mind, it doesn't matter if you drive the car 3 miles or 30 miles to work. The pistons are still going to be cold for the same amount of time, thus wearing down the same amount. Obviously speed, rpm, outside air temp, and just generally how hard you drive it all plays a factor.
I daily my car a little bit. But i'm a good 30 miles from work, plus it gets a good thrashing. I'm not one to let my engine sit and idle warming up for a long time either. High idle and enriched fuel ratio for warmup does just as much if not more damage than driving it normally until it gets to operating temperature.
If you build the engine, you should expect it not to last as long as an OEM engine. Always remember, it's just a machine.
Old Oct 5, 2014 | 05:57 PM
The more you cold start a car the more wear it will have. Most of the wear happens when its below operating temp. This slightly intensifies with forged pistons depending on what alloys they use and how they thermally expand, etc.
Your question is silly cause it's totally vague.
"guys, are forged pistons good for short daily driving?"
what kind of stupid question is that? do you need forged pistons? if yes, get them. If not, don't. Nothing is "good" for daily driving that's not OEM. So by that logic don't turbo your car. Don't make it faster. Don't do anything. Go buy a bus pass.
Please re-think your question, and then either post a better one, or just look at the many threads we had regarding this topic and you'll probably find an answer either way.
Total Cats: 19
I agree with your opinion
My choice would be wiseco's. And most of the time on my way back home i drive around and not going directly to home
Old Oct 5, 2014 | 06:35 PM
Miater's Avatar
Total Cats: 27
There are larger cast pistons.
Old Oct 5, 2014 | 07:59 PM
hornetball's Avatar
Total Cats: 697
Hmmmm . . . .
I'm putting together a DD 1.6 now, but it needs a bore past +.020" (+.5mm). Haven't found pistons of that size other than forged. I'd prefer cast on a DD. Do you have a link?
Old Oct 5, 2014 | 08:03 PM
ebay
but honestly I'm not sure something that much over is even possible
Old Oct 5, 2014 | 08:07 PM
hornetball's Avatar
Total Cats: 697
Most of the forged pistons have a +1.0mm (+.040") size (79mm).
But, yeah, might be time to toss this block.
Old Oct 5, 2014 | 08:09 PM
they offer +3 which I'm guessing is +.060 and say to contact them if you need bigger.
but yes absolutely, that block is done.
Old Oct 5, 2014 | 08:19 PM
hornetball's Avatar
Total Cats: 697
Yeah, 1.6 sizing I've seen so far:
78.00mm (STD) Cast and Forged (Mazda OEM B6Z211SA0C)
78.25mm (+.010") Cast and Forged (Mazda OEM B6Z211SB0C)
78.50mm (+.020") Cast and Forged (Mazda OEM B6Z211SBXC)
79.00mm (+.040") Forged Only
79.50mm (+.060") Forged Only
I'm hearing this little voice . . . it's saying "1.8 ... 1.8 ... 1.8." I think it might be Brain.
Old Oct 6, 2014 | 04:07 AM
Total Cats: 19
Maybe i will look for oversize cast pistons. But i need 1.8
Old Oct 6, 2014 | 06:32 AM
NiklasFalk's Avatar
Total Cats: 63
IL lists these:
Kolben Original fr Turbo Umbau 0,50 berma
If you want to run GTX pistons.
I have no idea which CR these are (8.8 or 9.0, "NA")
Kolbensatz NA 1,9 - 0,50 berma
Old Oct 6, 2014 | 06:49 AM
Total Cats: 19
Looks good. Ill give them a call later on the day. I already have good connections with IL motorsports.
Old Oct 6, 2014 | 09:36 AM
Why run GTX pistons?
<--- daily drives a built bottom end Miata.
