Time to figure out a new exhaust... Suggestions?
Old Feb 29, 2016 | 05:23 PM
viriiguy's Avatar
Default Time to figure out a new exhaust... Suggestions?
Well, I currently have the Flyin Miata Duals and before the turbo I LOVED their sound. I would like to replicate that type of sound with the turbo.
I am having a new 2.5" exhaust made from the turbo to the tips This will likely start next week. So I have to hurry the heck up and figure out what I am going to put under there.
There will be no cat. And nothing of the stock system reused. I do however, want to stay with a dual exhaust look, as the bumper is already cut for it... and I just like how it looks.
Any thoughts or suggestions? I know Exhaust sound is subjective.. But I don't want it to be loud, but would love a growl and burble like the FM exhaust had.
Old Feb 29, 2016 | 05:29 PM
Honestly why 2.5" instead of 3"? Cost difference when diying is marginal, it will help spool, and with a good muffler would not be much louder then 2.5".
Old Feb 29, 2016 | 05:34 PM
viriiguy's Avatar
Because from everything I have read the last few weeks, it would suggest that at my targeted power levels a 3 inch exhaust is not only a waste, but a hindrance.
Old Feb 29, 2016 | 05:38 PM
deezums's Avatar
Total Cats: 206
You suck at reading something terrible then. Try again.
Old Feb 29, 2016 | 05:41 PM
viriiguy's Avatar
It wouldn't be the first time.
Old Feb 29, 2016 | 05:43 PM
Total Cats: 1,870
3" is better. Ignore power goals, you gain a significant amount of spool.
bottom line - unless you have a really good/compelling reason not to go 3" (like, you already have a 2.5 or can get one for super duper cheap), you always want 3"
Old Feb 29, 2016 | 05:45 PM
viriiguy's Avatar
alright, then, 3" it is.
Old Feb 29, 2016 | 05:46 PM
you werent reading on this site then...
you want a 3" exhaust with the largest straight through muffler you can fit.
Old Feb 29, 2016 | 05:47 PM
viriiguy's Avatar
Admittedly, most of my exhaust ideas, came from a few M.net threads and various google results.
*Bad Randy* Bad Bad!!
Old Feb 29, 2016 | 05:49 PM
reading m.net is a 100% guarantee for failure and aidz
Old Feb 29, 2016 | 06:46 PM
viriiguy's Avatar
Ok, so 3 inch to the axle. Then maybe a magnaflow or vibrant with dual exits
Old Feb 29, 2016 | 07:49 PM
Charmin89's Avatar
Total Cats: 7
3" all day.
As far as sound, magnaflow/or knockoff (xlerator) will get you a similar sound as the flying miata kit as well as piece of mind that you are getting the least amount of restriction possible.
However, i enjoy the sound of the 40 series flowmaster better. it has more tonal quality over the magnaflow. i would recommend using a resonator with it as it tends to drone.
in your particular case if you were interested in running a flowmaster and still keep your duals the 80 series is a transverse muffler will work.
the flowmaster is a baffled muffler and does restrict the exhaust a bit but not much, i do notice a difference when running between the two.
Old Feb 29, 2016 | 08:53 PM
there's no point in doing 3" if youre going to run a redneck muffler.
Old Feb 29, 2016 | 09:02 PM
Charmin89's Avatar
Total Cats: 7
There is if you want to "feel the thunder" in your loins...
Old Mar 1, 2016 | 04:27 AM
viriiguy's Avatar
And what muffler would you suggest?
Old Mar 1, 2016 | 04:47 AM
deezums's Avatar
Total Cats: 206
Magnaflow 5x11x22 is miataturbo recommended muff
I run the center/offset one, it's a single chamber straight thru. The center/center is a dual chamber, supposed to be quieter.
You could do duals still, maybe. This is ARtech stuff, not manly 3" though.
Old Mar 1, 2016 | 05:31 AM
viriiguy's Avatar
It looks like the Magnaflow 12198 will work. And I will add a resonator to take away some of the highway drone.
Old Mar 1, 2016 | 07:32 AM
psyber_0ptix's Avatar
I love my Artech stuff
3"
Old Mar 1, 2016 | 07:36 AM
Corky Bell's Avatar
Total Cats: 11
My favorite is:
leave the turbo at the same ID as the turbine outlet
either cone shape, a 5 to 7 degree, or use a series of shallow swages to reach a dia of 3.0
put the 3.0 end about 10 inches aft of the engine/tranny joint
create a 1 into 2 joint (Y) with the two legs of 2.25 each. two 2.25's are bigger than 3.
two parallel 2.25 tubes back to the diff, then turn one left and one right. This is the only time in modern society one can turn left in an acceptable manner.
add a foot long 2.5 id glass pack to each leg and then out the back. If a drilled core is not available use a punched core and run it backwards.
Add a nice pair of ****.
