15x10 - 15x11 6UL @ 949 Racing
Old Mar 6, 2016 | 10:54 PM
  #121
paNX2K&SE-R's Avatar
Total Cats: 24
Any rubbing on the front fender/bumper mount tab with the 15x9?
Old Mar 7, 2016 | 09:05 AM
  #122
Mazdaspeeder's Avatar
Total Cats: 70
I never had an issue, but my liners were eaten away anyway
Old Mar 8, 2016 | 10:13 AM
  #123
OGRacing's Avatar
Total Cats: 33
i did have that issue, but i just bent the tab with a pair of pliers and the issue went away.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Originally Posted by Mobius
Old Mar 9, 2016 | 12:12 AM
  #124
ZX-Tex's Avatar
Total Cats: 27
Gratuitous wheel ****. NSFP (not safe for pansies).
275 A7s mounted on 15x11s. Thanks to Emilio for producing these, as they are very sweet indeed. I'll be race testing them this weekend at Motorsports Ranch Cresson for the NASA event. It's a smaller, tighter track so grip will be particularly important.
Notice the yellow marks at the valve stems in the third picture. I am going to see if the tires stay stationary on the wheels with the new bead teeth/notches. I saw lots of rotation with the standard 15x10s without the 'teeth', so much so I never bothered balancing the tires.
Attached Thumbnails 15x10 - 15x11 6UL @ 949 Racing-80-20160308_203402_8a8264974802412a98dac3ab7ba49e19eae0ba25.jpg   15x10 - 15x11 6UL @ 949 Racing-80-20160308_203427_36916163812b39d0a5d6d6d37d93b318442e8e40.jpg   15x10 - 15x11 6UL @ 949 Racing-80-20160308_220522_fe6c8681fa3b6fee7ac800f459d0fefad08fc0ad.jpg
Old Mar 9, 2016 | 01:00 PM
  #125
bbundy's Avatar
Total Cats: 146
I've had good luck with keeping the tires from rotating if I have the tire and the rim cleaned well and have the tire guy use WD40 for lube to install them. The WD40 is slippery before it dries but in a minute or two under pressure it Vulcanizes the rubber and practically bonds it to any metal or paint surface.
Anything done with regular tire install lube would rotate completely around the rim during the process of a day at the track making balancing pointless.
Old Mar 9, 2016 | 01:13 PM
  #126
jpreston's Avatar
Total Cats: 182
Old Mar 9, 2016 | 01:22 PM
  #127
Total Cats: 2,621
Yup WD40 works
.33 SNR
Old Mar 9, 2016 | 01:29 PM
  #128
d k's Avatar
d k
Hairspray works very well also.
Old Mar 9, 2016 | 01:46 PM
  #129
bbundy's Avatar
Total Cats: 146
hairspray sucks compared to WD40 for this purpose. hairspray is just sticky more like a glue and becomes contaminated easily and degrades with moister heat and time. WD40 makes the molecular structure of the rubber interact with the surface it contacts.
I learned this behavior well as a kid putting A'ME hand grips on BMX bikes that were used for launching off jumps set up on the end of boat docks into the river. One jump and hairspray was worthless as was Gorilla Glue or anything else. WD40 would not let go without an air compressor or a screw driver and more wd40 sprayed underneath.
Old Mar 9, 2016 | 01:52 PM
  #130
Total Cats: 2,621
Funny, I learned the WD40 thing trying to get rubber exhaust hangers off of systems in junkyards back in the 80's. It became my go to for getting rubber parts onto steel parts and making them stick. The carrier evaporates very quickly.
.33 SNR
Old Mar 9, 2016 | 05:38 PM
  #131
ZX-Tex's Avatar
Total Cats: 27
WD40. I'll try that next time I mount a set. For the set shown in the picture above, yep, we used the usual tire bead lube stuff during mounting.
As an interesting anecdote, we had some trouble mounting these, because with a 12" tall wheel, and then the 275 tire on top of that, my buddy's tire machine ran out of arm clearance (swingarm style) and made mounting a little tricky. A real tire store would have a larger pro grade machine at their disposal and clearance would not be a problem.
Old Mar 9, 2016 | 05:58 PM
  #132
Total Cats: 70
One more snap for anyone wondering, NB rolled and pulled fender, 15x10 with a 245 Maxxis. Definitely doable!
Attached Thumbnails 15x10 - 15x11 6UL @ 949 Racing-80-6023014a_d7e8_46f3_8512_64f73a338b20_zpsmgfywfpa_d936c444047d058401de991216da1601cd4ae04e.png
Old Mar 10, 2016 | 10:14 AM
  #133
Girth Brooks's Avatar
New 15x10/245's are in and on the car. Tons of room and clearance with AK flares.
Old Mar 10, 2016 | 02:05 PM
  #134
d k's Avatar
d k
Maybe wd40 works better? I dont know..
I personally never had an issue with hairspray on 4x4s when airing down etc.
Old Mar 10, 2016 | 03:53 PM
  #135
RHD_Tarzan's Avatar
More pics of different angles please
Old Mar 17, 2016 | 08:18 PM
  #136
ZX-Tex's Avatar
Total Cats: 27
Here are the 15x11 6ULs on the car, sitting at grid waiting for the race to start. These are not stock fenders. The only stock panels on this car are the doors.
Attached Thumbnails 15x10 - 15x11 6UL @ 949 Racing-80-nasa_msrc_2016_a1b7fde6e118f58108f570c80cc2df00c62c5035.jpg
Old Mar 28, 2016 | 04:00 PM
  #137
Total Cats: 2,621
Our shop NB2 getting detailed. Maxxis 245/40 VR-1
Attached Thumbnails 15x10 - 15x11 6UL @ 949 Racing-80-20160328_124342_001_44a685484333b6c4274cadfd903afc7c0b5e9285.jpg
.33 SNR
Old Mar 28, 2016 | 04:21 PM
  #138
ot81to's Avatar
Total Cats: 15
Looks mean. Now I want an NB!
Old Mar 31, 2016 | 08:59 PM
  #139
ctdrftna's Avatar
Total Cats: 56
God do i want a NB
Old Apr 5, 2016 | 01:52 PM
  #140
kmvguy's Avatar
Thank you 949
Slightly pulled and flat rolled fender.
It wasn't my intention to pull the fenders but while I was flat rolling the fenders, it just happen to pull a bit.
I'm also on 2.5" spring coilovers and no problem on clearing the suspension.
15x10s 6UL + 245 Maxxis
Once again thanks for the great setup, LOVE the new wheels
Attached Thumbnails 15x10 - 15x11 6UL @ 949 Racing-img_4218.jpg   15x10 - 15x11 6UL @ 949 Racing-img_4221.jpg   15x10 - 15x11 6UL @ 949 Racing-img_4223.jpg
