Stoptech STR brake fitment w/ tie rod end
Old Feb 9, 2019 | 10:19 AM
MuchoBoosto's Avatar
Total Cats: 11
Default Stoptech STR brake fitment w/ tie rod end
So i'm finally getting around to assembling the car and just put on the forged tie rod ends from Supermiata w/ the Stoptech BBK (floating rotors) and i've got like maybe 2mm clearance between the tie rod end and rotor on the passenger side. This is without the brake duct/shield on. Driver side has maybe 3-4mm clearance. Anyone else dealt with this? Any other tie rods that will give me better clearance?
Old Feb 9, 2019 | 10:32 AM
Total Cats: 1,410
Pretty typical. If you run a brake duct, you’ll wanna cut that part off. You can grind a bit of the tie rod casting off with a flapper wheel too.
Old Feb 10, 2019 | 07:15 AM
Total Cats: 3,573
Wow, that's tight.
Old Feb 10, 2019 | 11:40 AM
Total Cats: 2,619
What magical tie rod ends from "949" do you speak of? I say magical because there are no Miata Parts on 949racing.com nor any 949 racing branded Miata parts. Haven't been for about 10 years. Perhaps you mean the ones that are branded supermiata that you purchased from supermiata.com
As you were.
.33 SNR
Leave a poscat -15 Leave a negcat
Old Feb 10, 2019 | 11:54 AM
tomrev's Avatar
Total Cats: 41
I'd be concerned about heat soaking the grease in the joint with that tight fit.
Old Feb 10, 2019 | 12:35 PM
Total Cats: 2,619
It's a genuine concern. We have seen partially melted boots on our race and track cars with aftermarket BBK's. Our upcoming brake systems will increase clearance here for this reason.
.33 SNR
Old Feb 10, 2019 | 12:57 PM
afm's Avatar
afm
Total Cats: 510
I knew 2018 felt really long for me, but it's impressive packing 10 whole years in there. I had plenty of DPE buying Miata parts from 949Racing.com in 2017.
Old Feb 10, 2019 | 01:09 PM
Total Cats: 2,619
No "949 Racing branded Miata parts". The 1st and last 949 Racing branded Miata part was our end link, around 2010. After that they, and all other Miata parts were branded Supermiata, logos right on the part. We always referred to the parts as "Supermiata" even though you purchased them on 949racing.com.
That the 949 Racing legacy still stays in peoples minds is a good problem though. But yeah, there has been no such thing as a 949 Miata part in about a decade. That's our failure to assign the brand to the product line/
.33 SNR
Old Feb 10, 2019 | 04:30 PM
Total Cats: 11
Wondering if i could make some ~3-5 mm offset spacers for the hub and caliper bracket? I'd really like to keep the heat shield on and functional to prevent premature tie rod end failure.
Old Feb 11, 2019 | 01:35 AM
ITOzann's Avatar
Mucho close
Old Feb 13, 2019 | 06:57 PM
brainzata's Avatar
Total Cats: 17
I'd wrap some silicone self fusing high heat tape around the boot or coat the boot with high temp rtv for at least somewhat of a heat barrier.
Stein
Jan 23, 2014 08:53 AM
Seefo
Nov 10, 2011 12:06 PM
patsmx5
23
Mar 4, 2009 10:48 AM
Delhole94
Engine Performance
Nov 23, 2008 01:16 PM
Atlanta93LE
11
Jan 22, 2007 11:58 PM
