Mega Coilpack Test and Comparison R35, LS1, LQ9, Audi R8 and more
Old Mar 27, 2019 | 12:34 PM
Joseph Conley's Avatar
Default Mega Coilpack Test and Comparison R35, LS1, LQ9, Audi R8 and more
Motive video recently posted a video testing a number of different coil packs. Figured it would be something worth sharing with the community.
Old Mar 27, 2019 | 01:45 PM
Went ahead and pulled their overall rankings out of the video. The video does include more information on each coil than just these results.
IGN-1A (AEM/Haltech) - 102.7 mJ
Nissan R35 (Hitachi) - 54.0 mJ
370Z (Hanshin) - 54.0 mJ
Nissan R35 (Hanshin) - 54.0 mJ
Splitfire R35 (Hanshin) - 54.0 mJ
R35 Clone - 48.2 mJ
Audi R8 - 45.1 mJ
Bosch Toyota Yaris - 34 mJ
Splitfire RB26 - 33.6 mJ
LS1 (ACDelco) - 30.5 mJ
LQ9/D595 - 29.3 mJ
Denso Yaris (Genuine) - 25.6 mJ
Denso Yaris Coil (Fake) - 23.7 mJ
R35 Clone(China) - 23.1 mJ
Nissan RB25 Series 2(used) - 15.6 mJ
Splitfire S15 Silvia - 15.3 mJ
This info can be found at 11:29 in the video.
Old Mar 27, 2019 | 04:18 PM
DaWaN's Avatar
Total Cats: 29
Really cool video, as an electrical engineer I can also approve their testing method. Just testing the primary current is just a small part of the equation.
I asked them if they want to share the dwell settings for each coil, would be cool if they could share that (but at the same time I understand if they would not).
Old Mar 27, 2019 | 05:27 PM
skylinecalvin's Avatar
Total Cats: 89
I've been hearing the IGN-1A coils are the golden coils but at $71 a coil, it's hard to bite the bullet.
Old Mar 28, 2019 | 06:14 AM
TNTUBA's Avatar
Total Cats: 283
I upgraded from the GM D585 coils to the ING 1a coils over the winter. It was well worth it in my application. Fixed all the spark blow out issues we were having and I'm not having to put freshly gapped plugs in the car ever couple events. Also found repeatable power in the higher RPM range over the D585s. Amazing coilpack.
Old Mar 28, 2019 | 08:09 AM
der_vierte's Avatar
Total Cats: 116
Here in Europe the Audi R8/VAG Coils are very popular.
You can buy a set of new ones for like 80€. A new set of plugs and wires is around 25€, hard to beat for the performance.
The big PLUS is, that they fit amazing without any kind of holding bracket or screws, just click in like stock, if you cut the rubber just a bit.
Old Mar 28, 2019 | 10:02 AM
HarryB's Avatar
Total Cats: 155
Indeed, they are cheap and genuine R8 ones are dead reliable. They also grab on the spark plug, so no need to machine a bracket, but a cylindrical spacer might be nice to keep them snug in the VC and avoid water ingress (I like washing my engine). However there are no wiring diagrams for these on a Miata as far as I could tell.
Old Mar 29, 2019 | 04:51 PM
der_vierte's Avatar
Total Cats: 116
ExtraEFI
Page 2.
I'm scared of wiring jobs, but i got it all working on my first try. Really easy to setup, no pull up needed. (Euro 95.5, 1.6 stock harness)
Old Mar 29, 2019 | 05:37 PM
Schroedinger's Avatar
Total Cats: 188
Der vierte: what plugs are you using, something normal like BK7RE? Did you get the connectors that plug into the coils and make a harness? Do you have a part number or spec for the connector?
A pic of your setup would be great. I like this idea a lot more than dealing with mounting the 585's.
Old Mar 29, 2019 | 06:00 PM
HarryB's Avatar
Total Cats: 155
AFAIK OEM connector part no. is 1j0973724
They will clip on BKR7Es no problem.
Old Mar 30, 2019 | 04:47 AM
Reverant's Avatar
Total Cats: 369
No S2000/K20 coils in that test, I wonder why.
Old Mar 30, 2019 | 06:21 AM
der_vierte's Avatar
Total Cats: 116
Yes, I use normal BKR7E.
The connectors for the coils: Search "1J0973724" on e*** or just type in "ignition coil connector audi", 5-10 dollars from china
I can look after the exact part number for the coils i have, but every 06E905115 coil should work.
There is a rubber part under the casing that you can cut down a bit, that gives you a good sealing and solid connection to the plug. At least mine were like this, they can differ!
IB Nolan
Media
35
Sep 14, 2021 09:01 AM
blackandblown
Engine Performance
Dec 6, 2016 11:06 AM
JesseTheNoob
14
Dec 18, 2014 01:35 AM
Joe Perez
Media
19
Jan 27, 2009 05:12 PM
m2cupcar
Apr 23, 2007 06:49 PM
