Oil cooler tech
Old Aug 18, 2020 | 12:44 AM
  #521
Cory M's Avatar
Total Cats: 16
Thanks for the response. The Fab9 kit comes with the Mocal sandwich plate (180 deg), -10AN hose and fittings, and the 25 row Setrab cooler. Seems like a good kit and I believe it sells for less than I can buy the parts for separately. Looks more track focused than the other Miata coolers I've seen.
Old Aug 18, 2020 | 09:40 AM
  #522
Total Cats: 3,591
Buy it from a reputable Setrab dealer, buy the sandwich plate, and have some hoses made by a local hydraulic shop. Fab9 doesn't stock anything and just orders and drop ships when you order. And they have crappy customer service.
Old Aug 18, 2020 | 12:27 PM
  #523
Ted75zcar's Avatar
Tweaking Enginerd
Total Cats: 384
Buy it from a reputable Setrab dealer, buy the sandwich plate, and have some hoses made by a local hydraulic shop. Fab9 doesn't stock anything and just orders and drop ships when you order. And they have crappy customer service after you give them money.
FTFY
Old Aug 18, 2020 | 12:45 PM
  #524
Total Cats: 2,621
Just looked at the Fab9 kit. Appears to be 100% OTS parts.
IOW, you can replicate it on your own.
.33 SNR
Old Aug 18, 2020 | 01:00 PM
  #525
Cory M's Avatar
Total Cats: 16
Thanks for the info on Fab9. I'll likely end up building my own. I've got a few spare oil coolers in the garage I may try to adapt, although they might be too big. Pretty surprising that there aren't more options for quality kits considering how many Miatas see track time.
Old Aug 20, 2020 | 12:50 PM
  #526
Total Cats: 2,621
Tend to agree with Josh. Bespoke is the best plan for oil coolers. Too many variables in routing for an OTS kit to be optimum for everyone.
-Only use -10AN. -8 too small
-Must have a tstat
-Pay attention not just to air intake but also exiting the core
-Try to route hoses so they have only one gradual change in elevation between core and adapter. No roller coaster.
- If you feed core from bottom, you can drain core and lines during oil changes. Not absolutely necessary, but it helps replace all old oil.
- Setrab >*
.33 SNR
Old Aug 20, 2020 | 01:04 PM
  #527
b3d3g1's Avatar
Total Cats: 24
Can you elaborate on the "exiting the core" considerations that you are aware of?
I plan to have a dedicated air path to the oil core but only ~1" gap to the coolant radiator. Maybe you mean more about exit air management rather than temperature considerations?
I'm in the midst of mounting now and my constraints are more based on my lack of fabrication skills.
Old Aug 20, 2020 | 01:40 PM
  #528
Total Cats: 2,621
Just that big pressure differentials are handy at getting good air mass through a heat exchanger. Blasting air in, with no place for it to exit or pressure differential negates some of its potential efficiency. Personally, I wouldn't exit an O/C into the rad.
O/C airmass might be 240-280° and radiator wants to see <150° air to do its job. Exacerbated by your downflow rad where the hottest coolant is fed in from the top. It will all work better than no O/C but it can be improved. I think William has his mounted horizontally behind the rad.
Bullet was under headlight with ducting. Vegas is horizontal below radiator with some ducting. In each case, O/C exit is not feeding radiator.
my .02
.33 SNR
Old Aug 20, 2020 | 02:05 PM
  #529
Arca_ex's Avatar
Total Cats: 431
If you've got no headlights because racecar, put the cooler where the old headlight bucket used to be and duct the turn signal opening into it and let it exhaust into the engine bay. Having hood vents will help this a lot.
Old Aug 20, 2020 | 02:22 PM
  #530
Midtenn's Avatar
Total Cats: 311
I'm hoping this works out with the need for additional ducting to the lid (mostly for aesthetic reasons), but I already have a plan for a version 2 if need be that seals to the lid with a vent. The tube from the turn signal will be sealed off to the duct.
Old Aug 20, 2020 | 04:14 PM
  #531
b3d3g1's Avatar
Total Cats: 24
I think I might have to go back to the drawing board with my mounting. This was my old setup and sounds like it was probably more effective. Need the figure out how to repackage the with a different core but I'm digging that upward facing concept.
Fun fact: this core started as a FM steering rack mounted core.
Old Aug 20, 2020 | 04:26 PM
  #532
Total Cats: 2,621
I like that better, for all the reasons mentioned earlier. In Bullet and I think, one other build, we mounted it under the headlight bucket. Air ducted in from main rad inlet, through core and out into wheel well. Screen to keep rocks from wheel out of it. If lower half of bumper skin is cut off, a bunch more room to build and service ducting and O/C core.
.33 SNR
Old Aug 20, 2020 | 10:57 PM
  #533
LeoNA's Avatar
Total Cats: 107
Are -10 lines any benefit if the oe heat exchanger is retained? I’m not sure a thermostat plate is really required for turbo applications with a limited oil sump volume. Mine seems to heat the oil up fairly fast. FWIW I personally prefer to mount all oil related components low to prevent air accumulation.
Old Aug 20, 2020 | 11:29 PM
  #534
Ted75zcar's Avatar
Tweaking Enginerd
Total Cats: 384
-10 are definitely beneficial, you can see substantial pressure drop across -8, especially if you are running the core in front of the radiator.
I am surprized people haven't gravitated more towards the series 1. The flow characteristics are much better, as are the port locations IMO.
Old Aug 21, 2020 | 04:57 AM
  #535
Tran's Avatar
Total Cats: 49
Have you seen any issues with drainback and time-to-prime with a bottom fed core? A bottom fed oil cooler usually allows for a slightly larger one given that most of the time the lines from a BP will come from below, but I am concerned with time-to-prime if left for any significant period of time.
On a side note, it seems like an opportunity for setrab or someone to install a drain plug at the bottom of one of the end tanks and temp sensor bosses in both end tanks to get temp delta info, I'm surprised that doesn't exist on the market.
Old Aug 23, 2020 | 06:05 PM
  #536
Eunos91's Avatar
Total Cats: 94
Here's my current setup, similar to the one found on the BMW M5 (F10). However, on the Beemer the air exits through the undertray, while on the Miatini the air exits above my Dibond undertray (not pictured) into the engine bay, just like the water radiator. Works so far and runs a lot cooler than my previous setup (behind the water radiator with a sealed 15 mm gap)
Old Aug 27, 2020 | 06:48 AM
  #537
I may be completely wrong, but that seems like a horrible mounting location. Any sort of off track trip or hitting some rough curbing looks like the oil cooler is being hit first. Then no oil pressure for motor. I know a compplaint I have heard over the years is the FM mounting location and it being hit with rocks and such. This just looks so much worse to me.
Old Aug 29, 2020 | 10:12 AM
  #538
Eunos91's Avatar
Total Cats: 94
Except that it is completely shielded from below with a 4 mm Dibond plate and sits higher than the subframe etc
Old Nov 8, 2020 | 04:27 PM
  #539
Cory M's Avatar
Total Cats: 16
Originally Posted by Cory M
Oil temp hit 300F at California Speedway this weekend. It was crazy hot, 108 air temp. My car is a stock engine 1.8 NB. Has aluminum Koyo radiator that's properly ducted but no oil cooler. That oil temp was measured at the filter sandwich plate. With the Trackspeed kit no longer available what is the best off the shelf solution for a track only car? I am considering the Fab9 25 row Setrab kit. Any others I should look at? I'd rather not piece it together unless it's going to be significantly better and/or cheaper. Probably going to mount it in the fender well, have a full undertray so the steering rack location won't work. I could put it in front of the radiator if needed.
Update: I took the advice given here and assembled my own using a Setrab Series1 25 row cooler (part# SET-125-7612), a Setrab sandwich plate, and fittings. Went with -10AN fittings, push lock style with Oetiker clamps. Mounted in front of radiator.
Just got back from a practice day where I hammered on it for 6 sessions in 90F weather and it never exceeded 240F.
Big improvement, thanks for sharing your set ups and ideas
Old Jan 13, 2021 | 02:06 PM
  #540
Eunos91's Avatar
Total Cats: 94
Here's the new BMW M5 and its radiator design. Interesting to see the horizontal oil cooler with a flap, like they already did with the F10 M5
