A question about my odd BOV
Old Nov 2, 2007 | 10:59 AM
PAT!'s Avatar
Crap. I missed that too. Now your valve will probably leak boost on tip-in or maybe even longer what with the spring being cut.
Old Nov 2, 2007 | 11:00 AM
PAT!'s Avatar
...but then again thats like someone wondering why their car isn't starting after its run out of gas.
Old Nov 2, 2007 | 11:24 AM
Ben's Avatar
Ben
Total Cats: 134
Yeah hopefully your BOV won't leak boost. Leave the boost gauge hooked up where it is so you can watch for any pressure loss compared to what you're used to seeing. You should be able to hear it leak if it does, too.
Old Nov 2, 2007 | 12:09 PM
PAT!'s Avatar
Well its not the peak boost that is a concern, it takes a pretty crap valve to leak once peak boost is reached. Its boost onset that is the problem.
Look at the dyno below. Independent 3rd party dyno test on a stock 06 STi and with our recirc valve installed. Valve install done on the dyno in between runs and the car was brought to the same temp for both runs.
The weak spring in the factory valve is being blown open due to latency and pressure drop. Once this happens there is a far greater surface area available to the charge air to act upon than normal, keeping the valve open even if the intake manifold side of the valve and the charge pipe side reach equilibrium. When this happens the only thing that will close it is the difference between the two coming from the spring.
Being that your valve is compressor mounted it will be seeing the highest possible pressure on the bottom of its diaphragm, so the problem will likely be magnified.
Old Nov 2, 2007 | 09:39 PM
cardriverx's Avatar
Total Cats: 12
Ok guys, I put a spacer behind the spring (to lengthen it alittle), changed the line to over at the TB, and it works perfect! It has a cool whistle to it, ill take a vid sometime (its acually pretty darn loud!). Nor does it leak.
Also, I relocated the boost gauge to the TB, and found out im acually boosting only 3 to 4 psi with the intercooler drop factored in! so..
thanks to my school's auto lab having an account with grainger, I made a "grainger MBC" for $10 =). Turned the boost up so it just kisses 5 psi, and it runs beautiful!
QUESTION - I hooked the boost gauge where the charchol chanister was, and took off the line to the charchol canister. I ran it for a lil like that.. is that ok? Do I need to hook it up ASAP?
Old Nov 2, 2007 | 10:11 PM
cjernigan's Avatar
Total Cats: 7
You don't really need the charcoal cannister. Pretty sure it just catches gasoline vapors so they don't get into the atmosphere.
Old Nov 2, 2007 | 10:56 PM
cardriverx's Avatar
Total Cats: 12
I know it does that, im just wondering if haveing it unhooked will mess with fuel vapor in the tank or anything.
Old Nov 2, 2007 | 11:50 PM
cjernigan's Avatar
Total Cats: 7
You should be fine. I would get my signal from somewhere else though. You have the fitting on the back of the mani and the ones at the TB. Or you could put a T into your brake booster line and get it from there, that would work well. Either way I don't see you having your CC unhooked being a problem. rmmcelwe and mxv don't run one.
Old Nov 2, 2007 | 11:52 PM
cardriverx's Avatar
Total Cats: 12
Where exactly is the one on the back of the mani? I cannot seem to find it.
Old Nov 2, 2007 | 11:54 PM
cjernigan's Avatar
Total Cats: 7
What year is your car. You might not have one. Most cars have a fitting between on the backside near the firewall. I have a '99, hard to relate to NAs.
Old Nov 3, 2007 | 12:06 AM
cardriverx's Avatar
Total Cats: 12
Old Nov 3, 2007 | 01:07 AM
cjernigan's Avatar
Total Cats: 7
Do you have this?
Old Nov 3, 2007 | 12:06 PM
cardriverx's Avatar
Total Cats: 12
yes I do. I was wondering if it was ok to tee into the FPR, thanks =)
bigmackloud
Jan 8, 2021 11:24 AM
JesseTheNoob
Sep 30, 2015 02:44 PM
itsMikey
MSPNP
Sep 28, 2015 06:40 AM
