alpha romeo lust
Old Nov 26, 2009 | 12:09 PM
  #41
Rennkafer's Avatar
Originally Posted by hustler
Injector placement is fine, if you're a man.
How God intended a mans car to be injected...
Old Nov 26, 2009 | 03:50 PM
  #42
Efini~FC3S's Avatar
Total Cats: 99
look at the wastegate.
I said note the lack of v-bands, not the absence of them. I saw the one on each wastegate (as well as the others) but it's interesting the manifold to turbine connection has simple nuts and bolts.
Old Nov 26, 2009 | 07:37 PM
  #43
Syntax fail.
Old Nov 26, 2009 | 07:51 PM
Rennkafer's Avatar
The turbo is well supported on a single turbo 962 and doesn't put a big load on the bolts (and apparently doesn't heat them up enough to cause the problems evidenced here regularly). The 962 we have at the shop has the same crappy mismatched nuts it showed up with and they don't come loose. I did my best to convince the PTB we ought to change them out regardless, but to no avail.
Old Nov 26, 2009 | 08:37 PM
  #45
DreadedRed's Avatar
Uh, Hustler, it's ALFA Romeo, not Alpha. Unless you're getting it Greek style, which you probably are.
Old Nov 26, 2009 | 09:12 PM
  #46
Full_Tilt_Boogie's Avatar
Total Cats: 409
Mechanical fuel injection FTW
Old Nov 26, 2009 | 09:16 PM
  #47
Efini~FC3S's Avatar
Total Cats: 99
Maybe we can learn something from the 962
Old Nov 27, 2009 | 12:24 AM
  #48
the_man's Avatar
Your reading comprehension skills are **** because you have AIDS, n00b ------.
Old Nov 27, 2009 | 01:44 AM
  #49
thanks, now I can jack-off with a cheese grader and sleep in peace.
Old Nov 27, 2009 | 03:09 AM
  #50
NA6C-Guy's Avatar
Total Cats: 44
Jeez Hustler, its grater, not grader...
Old Nov 27, 2009 | 11:20 AM
  #51
spoolin2bars's Avatar
Total Cats: 10
alfa engines are sick! widebody porsche's are alway's the ****, especially older 911's.
i think it's established that the reason the bolts fail is they're exposed to the direct exhaust gas/heat inside the manifold. the bolts that aren't exposed don't fail. you know they're exposed if when the bolt is out - exhaust gas shoots out the hole. i only have one exposed, so only one has ever broken. (top left - many times). confirmed by a few others including snowboarder.
Old Dec 12, 2009 | 11:48 AM
  #52
Old Dec 12, 2009 | 11:50 AM
  #53
I'll call every F1 team and let them know about their inferior design:
Old Dec 12, 2009 | 07:47 PM
  #54
Miatamaniac92's Avatar
How's the lawsuit/litigation going?
Chris
Old Dec 13, 2009 | 12:38 AM
  #55
Chris
The glove did not fit.
mx5autoxer
Insert BS here
10
Jan 10, 2010 08:24 PM
the_man
Insert BS here
Dec 1, 2009 01:50 PM
sup gurl
Dec 26, 2007 07:31 PM
sup gurl
Dec 18, 2007 06:56 PM
miatanutz
Jun 2, 2007 11:37 PM
