Where did you buy your turbo oil feed line??
Old Dec 29, 2009 | 01:57 PM
miatauser884's Avatar
Total Cats: 11
Default Where did you buy your turbo oil feed line??
I was planning on using Artech's oil feed kit, but my block does not have the oild feed line on the driver side. I will have to source my oil from the pressure sender location.
Where did you buy your line that goes from the turbo to the pressure sender, and what was the length of your line.
I know this will be turbo setup dependent so if you have a begi or fm setup that would be great. If not, still post so that way I can get an estimate.
The wiki site says no less than 42" iirc, but that is pretty vague
Old Dec 29, 2009 | 02:02 PM
buffon01's Avatar
Total Cats: 13
JGS Precision Turbo
Old Dec 29, 2009 | 02:08 PM
Total Cats: 11
Originally Posted by buffon01
You the man That's exactly what I was looking for. Thanks
Old Dec 29, 2009 | 02:18 PM
webby459's Avatar
That is helpful. Thanks from me for the info, too. I am in for info regarding length, as well, although I may use diy fittings so I can cut the hose to length at home.
Old Dec 29, 2009 | 02:25 PM
buffon01's Avatar
Total Cats: 13
Wow you guys didnt read the "All your ans. in one post" did you??
Old Dec 29, 2009 | 02:35 PM
webby459's Avatar
Only the parts that applied at the time. Thanks for pointing it out, lots of oil feed info there.
Old Dec 29, 2009 | 02:47 PM
ARTech's Avatar
Total Cats: 10
That kit looks like a winner.
Quick question. Are you 96+ guys really using a 42"-48" line? 4 feet of line seems awful long. Djp, don't forget to prime the turbo.
Old Dec 29, 2009 | 03:26 PM
FRT_Fun's Avatar
I'm a terrible person
Total Cats: 180
Yes, mine is pretty damn huge. Although I don't think mine is quite 42" (From FM). I think it is shown in one of the pictures in my build thread.
Old Dec 29, 2009 | 03:40 PM
y8s's Avatar
y8s
DEI liberal femininity
Total Cats: 574
yup. oil pressure sender is under the middle of the intake mani.
i sure hope nobody is boosting before they have oil pressure... but it probably doesn't matter on ball bearing turbos. journal bearing might be an issue. maybe that's why there's all those failures? a second or two of dry bearing at startup...?
Old Dec 29, 2009 | 04:10 PM
Stein's Avatar
Total Cats: 166
Yes. Mine was just shy of 48. IIRC, 46". Was perfect by the time I routed it around the back and tied it off to the brake booster hard line.
Old Dec 29, 2009 | 04:39 PM
Total Cats: 11
I know this will probably sound stupid, but it probably is a good question?
How do you go about priming a turbo???? Can you just turn the engine over with no spark???
Old Dec 29, 2009 | 04:41 PM
Stein's Avatar
Total Cats: 166
I just squirted some in with a syringe and screwed on the line before the first startup. It holds enough to get it wet until the line pressure fills. It isn't going to be turning any RPM.
buffon01's Avatar
Total Cats: 13
nvm
Old Dec 29, 2009 | 05:16 PM
Stephanie Turner's Avatar
Total Cats: -100
BEGI has an oil supply kit for all years. We can adjust fittings or line length if needed.
96+ cars: 1996-2005 Miata Oil Supply Line Kit BEGi
90-94 cars: 1990-1995 Miata Oil Supply Line Kit BEGi
Stephanie
Old Dec 29, 2009 | 06:17 PM
thymer's Avatar
Total Cats: -2
really easy to make your own and then you know it is the exact right size. I'm doing fuel lines now and it's actually kinda fun to work with.
Old Dec 29, 2009 | 07:29 PM
clay's Avatar
http://www.---------------------------/oil-feed.shtml
I found that that 4 feet is a bit long, but it works.
Old Dec 30, 2009 | 04:01 PM
shlammed's Avatar
Total Cats: 51
summit racing. order some fittings, some stainless line and your good to go.
-4an is a pain to assemble though.
Old Jan 29, 2010 | 02:02 PM
Total Cats: 11
After researching building one myself, this is the best price $42 since it includes the proper adapters for NPT and BSPT.
stealthmode//performance
I will using this and ARtech's water line kit
Old Sep 17, 2011 | 03:44 AM
v01canic's Avatar
Total Cats: -2
not to revive a super old thread, but can some one tell me what length line i should be using for a 1.6L
Thanks
Old Sep 17, 2011 | 03:48 AM
MD323's Avatar
Thanks
as much as you need and shorter than excessive...
