1993 miata: high or low impedance?
Old Jan 5, 2010 | 06:16 AM
Remzig's Avatar
Default 1993 miata: high or low impedance?
I have a question are 1993 miatainjectors high or low impedance?
i want to turbo my 1993 miata,and i have the following parts:
Subaru impreza wrx turbo.
vortech fmu witch recalibration kit
1:1 rising rate fpr
4agze injectors (365 cc) i think these are low impedance
Aeromotive 11106 700 HP EFI Electric Fuel Pump
3bar gm map sensor
looking for a s-afc (for now planning om a msn pnp)
planning for running 8/10 psi
is this possible with those parts i have?
what els do i need can i use the 4agze injector?
thx you very much for your help
Old Jan 5, 2010 | 07:31 AM
SKMetalworks's Avatar
You should really read the DIY FAQ.
I see no manifold on that list. I would stick with MSpnp and ditch s-afc. The fuel pump is massive overkill if you have MS. I think you will be maxed on those injectors or close to it. I would go with some rx7 460's or 550's, there cheap and work great. You wont need a FPR with megasquirt.
Old Jan 5, 2010 | 07:56 AM
miataspeed2005's Avatar
Miatas are high
Old Jan 5, 2010 | 08:24 AM
I suggest your follow the advice in your signature.
Old Jan 5, 2010 | 09:14 AM
Remzig's Avatar
i will make a custom manifold and intercooler setup,my self
Old Jan 5, 2010 | 09:44 AM
can you make me a Spiderman costume?
Old Jan 5, 2010 | 10:12 AM
dustinb's Avatar
I totally want to dress up as a manifold for Haloween! That would be sick.
I don't see this build happening.
Old Jan 5, 2010 | 12:31 PM
Gotpsi?'s Avatar
Haha I got an engine cover off of a G8 that my friend used for haloween it was awsome
Old Jan 5, 2010 | 02:06 PM
Total Cats: 3,591
^^^ESL
S-AFC will not work properly on a Miata. Read the FAQ.
Zaphod
47
Oct 26, 2018 11:00 PM
LucaCarMods
Feb 14, 2016 06:13 AM
JesseTheNoob
Sep 30, 2015 02:44 PM
DonPlatt
Sep 25, 2015 02:57 AM
