Front Desk Questions, suggestions, site problems? Put all your site related threads in here.
How To: Post on Miata Turbo - Tips and Tricks
Old Mar 7, 2011 | 12:38 PM
Quality Control Bot's Avatar
"Quality" is my first name.
Total Cats: 77
Exclamation How To: Post on Miata Turbo - Tips and Tricks
HOW TO EDIT / UPDATE YOUR SIGNATURE
Creating a signature helps others know about you and your vehicle.
We ask that all members insert a signature, please read here for specifics.
You will see in the footer of this post my personal signature.
HOW TO POST
It is always important when posting to use very specific Titles and messages and if applicable, tags in the message.
New threads with the subject: Help
and a message of 'I broke down' will never yield the results you are looking for.
A descriptive title such as:
Subject: My 1984 Ford Mustang 5L won't crank
Message: Tried starting my car this morning but it wouldnt crank, any ideas?
Tags: 1984 mustang, wont crank
Will yield you some great answers.
HOW TO POST A REPLY (respond to a thread)
There are 2 ways to reply to a thread as outlined in the attached image below. Regardless of which method you use, the important thing is to enter as much key information relating to the topic being discussed. 1 word replies generally serve no purpose.
UPLOADING AN IMAGE FILE TO YOUR POST
There are a few things to consider when attaching an image. The actual file of your file and if it is an image file, the dimensions.
Below is the attachment box that pops open. You can see the image sizing.
The site being demonstrated allows files 1mb in size with a max width and height of 1000x1000 pixels.
Below is how the page will look when you click Manage Attachments.
The procedure while in a reply or creating a new thread is:
Manage Attachments
Browse (browse your computer for the image, click it and it should add to the field)
Click upload
Click close this window in the attachment box *your attachment should be added and should be seen in the new post / reply box as an attachment
You still need to submit your thread or reply for it to become active.
Your image if successfully upload will appear as seen in the image below.
HOW TO PUT A LARGE IMAGE IN YOUR POST
There are 2 ways of doing this. 1, if via your attached images. First you must master uploading images as discussed above. Once you have done that you can use the sites max width which in this case is 1000x1000. The site will always create the smaller 'thumbnails' which are clickable to a larger image.
If you click the image and it opens in its own window, it may have a url like:
Code:
http://www.forumediainc.com/attachment.php?attachmentid=29&d=1299514136
You can then use the [IMG] open and [/IMG] close codes on the site. Between those IMG tags you would place the url above.
Code:
[IM G]http://www.forumediainc.com/attachment.php?attachmentid=29&d=1299514136[/ IMG]
* the img tags above are purposely spaced so you can see how the url should look with img codes.
**in some cases, people who are NOT logged in may not see the image if you are linking it on another site. It really depends on the Forums permissions.
HOW TO DELETE / TERMINATE YOUR ACCOUNT
We outline account deletion in our Forum Rule set here.
There is currently no specific end user way to DELETE an account but you can disable it as to not get emails, subscription updates etc.
To disable your account goto: USERCO -> EDIT OPTION (scroll down) -> Enter a reason and CONFIRM DELETION (an email will be dispatched to your email on file). Confirm DELETION via email. Process complete.
Old Oct 29, 2011 | 02:04 PM
Total Cats: 77
HOW TO RETRIEVE A FORGOTTEN PASSWORD
Have you tried to login and just can't seem to remember your password?
This is the process of how to retrieve your password using the automated system.
Step 1: you have entered the wrong password and you see this screen:
Click the retrieve password link
Step 2:Now enter your email associated with the account on this website. If you enter an email that is not in use it will fail so it must be the email attached to the account.
Enter or answer the question. If the box says to type 123, you enter 123, not 123abc. If you do not follow the instructions, it will fail.
Step 3: Check your email for the automated email from the site. It may take a few minutes for it to arrive. If you do not see the email check your spam box. Generally the email will come from webmaster@thesitename. It is very important to check the spam box and or your email filters. If you find it in the spam box you need to add that email addy to your friends list (may be called white list). The site does send out emails from time to time. If you want to participate these emails will assist you in that.
Step 4: Open the email. There is a link that you can click or cut and paste. There is also the login name that is attached to the email address you entered in Step 2.
Click the link & the site will randomly create and email you a new password.
Step 5: The system has now confirmed the mail out of your new password. You can either click the form link or goto log in.
The email will provide you with your login and new temp password. Change the password once you are in your USERCP of the site.
You should now be able to start surfing the site, utilizing the pms and have full access. If you are still having issues after following the above procedure it may be due to a few reasons.
1) are you entering a valid email that is attach to an account and used on this site?
If the system does not recognize your email create a new account. If you are certain you already have an account and need it back you will need to prove that it was your account.
2) have you checked your spam box and added the webmaster@thesite details in your friends list or white list? Every email service is a bit different but for gmail if you find the email in spam, you open it and click the button that says NOT SPAM.
You dont have access to that email anymore
This gets a bit tricky here. If you no longer have access to the email associated with your account and you forgot your password you will need to prove that the account belonged to you. This can be done in a few different ways.
First, contact us at the contact us link at the bottom of this page. Include the following:
Your first name:
A link to your profile on the site:
Your old email addy:
A contact number where the site owner can reach you if need be to confirm.
*other directions may follow in a response email to confirm account ownership.
We go to great lengths to ensure the privacy and safety of all members. It is because of our concern that we must utilize a procedure that protects everyone, including you.
Old Oct 29, 2011 | 11:19 PM
pusha's Avatar
Total Cats: -29
Thank you, Rick!
Old Nov 7, 2011 | 01:58 PM
Total Cats: 77
HOW TO PROPS A POST
Props is a system we came up with where you as a user can give feedback on those posts you find helpful and the ones you feel bring a thread down. You have 3 options when considering props.
a) Give a + . That will bump a user up with props plus one.
b) Give a -. This will drop a user one props.
c) Don't do anything. Props are to be used for those posts that stand out amongst all the other chatter posts. A good how to post deserves a + or a good response to a question deserves a +. Posts getting a - would be the posts that add no value to our community and or bring the thread / site down (racism, spam etc).
It is a use at your own discretion system. You cannot Props yourself and you do not need to props every post (though there is nothing stopping you.)
How to use.
Read over the post, like what you see you can give a + props. They are located under the quote button (see image below).
Its very simple, once you click the negative or the positive, the users count will go up. You can only go up or down one from their initial Props count. We opted to give this post a + (positive).
A users total props are always shown in their post area. A refresh of page is always required to update this area. Initial Props is updated immediately where as this area requires an f5.
All users Props given and received are show in their profile, as is yours.
Goto any profile on the site and click the props tab.
All profiles will show the top posts that have received props. It also shows how many props you have given and how many total you have received.
The concept is to reward those who make our site awesome and to let those others know that their not so great post could be improved upon. There is no science to this, everyone will have a different idea of what is valuable to a community and what isn't. Staff CANNOT edit Props (not even I the admin).
Leave a poscat 22 Leave a negcat
Old Nov 7, 2011 | 09:36 PM
samnavy's Avatar
Total Cats: 327
ADDITIONAL IMAGE UPLOADING ADVICE:
1. Nobody needs to see a 5mb image taken with a 12mb camera of your polished shifter **** or brake caliper. It is almost never necessary to post an image larger than can fit on the average 20" monitor.
2. When using Photobucket, the smaller your photos are, the less bandwidth each download takes, and the longer your free bandwidth lasts. Of course there are reasons to post large images, but probably not.
3. The forum will only let you upload an image XXX large because it's smarter than you and knows that a 5mb image EATS the **** out of bandwidth, takes forever to upload, forever to download, and it knows that nobody needs to see every last spec of dust stuck behind the plastic on your instrument cluster.
4. Believe it or not, Microsoft has the simplest, easiest, fastest, most user friendly image resizer there is. It is always on (no program to open). It resizes images perfectly for forum uploading. Sorry Mac douches, not for you.
For XP:
Look about halfway down the right side of this page:
http://www.microsoft.com/windowsxp/d...powertoys.mspx
Download IMAGE RESIZER.exe. It'll put an icon on your desktop. Install the icon. After installed, you can delete the icon. Now go to any photo-type file and RIGHT CLICK. A new selection will be RESIZE IMAGES. It doesn't simply resize the current image, it creates a new photo right next to the original only much smaller. You can resize as more than one at a time. Look in the advanced menu for more options. You never have to turn this program ON. It's there all the time. Just RIGHT CLICK, select a size (medium is always big enough for 99.9% of forum posting).
Windows Vista/7 link here (not Microsoft, but works exactly same way):
http://imageresizer.codeplex.com/releases/view/30247
Old Nov 25, 2011 | 10:36 AM
Total Cats: 77
Prefix Sorting & Searching (applies to sections using Prefix)
Prefixes are criteria the administrators and staff can enable in the back end of the forum.
Prefixes can be anything you like. Generally we see prefixes used in the classifieds for such terms as 'FS' (forsale), 'WTB' (want to buy) 'LF' (looking for) and or in the case of the example MiataForumz.com, they are using prefix criteria for their how tos.
Below is an image of their live site. The arrow points to the prefix in use.
Sorting Prefixes
Prefixes can be searched and sorted. This becomes very useful on very active sites with prefixes. MiataForumz.com can be sorted to show only the prefix you are interested in. For instance I have sorted by the prefix interior, here are the results.
Searching Prefixes
Searching prefixes requires you to enter into the Advanced Search area. Essentially, not much changes as you only add a Prefix to search in, the keywords and submit. There are also other options as well but you can do a basic Prefix search. Prefix searching is extremely useful if the site has many prefixes.
Old Dec 4, 2011 | 02:15 PM
Total Cats: 77
PROPS - HOW TO DISABLE IT & GLOBAL STATS
Update on December 04 2011
First off, we have made some changes to the Props system with the help of our members. First let me start by pointing out the new added restrictions.
Registered users can now only Props 25 times per day.
Site Supporters have 100 Props on tap to give out.
Remember, Props the posts you enjoy and like.
Props Global Stats
You can now see some various stats for the Props system. The following stats are being covered:
Total site wide props,
User who has given the most props on the site,
User who has received the most props,
Top 5 posts with the most props,
Top 5 posts with the most negative props.
To get the the Props global stats page head to the Quick Link drop down, see attached image.
How To: Disable the Props system
There are a number of people who dislike the subjective nature of the Props system and have no interest in participating in it or even viewing it. We have gone the distance and have added a feature for any user to simply shut it off. While the system will still be 100% active for everyone else you can opt to not see any of it. You can always re-enable later if you have a change of heart.
To disable the Props system goto the navigation bar and click User CP followed by click Edit Options on the side bar (see attached image)
Next, scroll down till you see the Props options.
Old Dec 30, 2011 | 09:41 PM
Total Cats: 77
FEEDBACK - iTrader - User Rating
An eBay style feedback system may be installed on the site. This is the general idea on how to use it IF it is up and running. If it is, the images provided below will give you an idea on how to leave feedback after a transaction.
** feedback is not the same as props. feedback is for transactions from the classifieds and props is towards posts.
How To: Leave Feedback
If the system is installed a first look at the quick links may bring up the global feedback system.
The global system shows all transactions over the course of the last 12 months. Though the history only goes back 12 months feedback left to your account remains forever.
This is a good example of a busy site utilizing the feedback system to the fullest. You will see both good sellers and poor sellers.
Remember, feedback alone does not mean you let your guard down when doing a transaction. If low posting members are leaving each other feedback, it may be an example of someone trying to 'cheat' the system. Look for members who have high post counts, high feedback who have participated in the feedback system so that you have greater the chances of a successful deal.
Feedback can also be seen in the post area (referred to as postbit). It generally shows how many transactions have taken place & the % of successful deals. In this example there has been 3 deals for 100% success / positive feedback.
Had I clicked the 3 in this example it would take me to the users profile feed where the Feedback tab would be presented to me. (see image below of another user)
In the users profile tab you now will see multiple tabs covering an array of items. If you click View all of the users feedback this will also open the window where you can now submit your own feedback by clicking Submit Feedback For (username)
Below is the page that opens when you want to submit feedback for a user.
The key is being thorough about all transactions. Remember, if everyone is thorough then when you go to utilize the feedback system and check up on a user you too will have more information on the person to make an informed decision.
Fill out the form, submit. Once you click Submit, Feedback has been left for the user and a PM has been dispatched to them letting them know.
Feedback Notes
- if you leave multiple fast feedbacks the system reports your IP and the user you are leaving the feedback for to staff. Staff are able to review all feedback, edit, delete etc.
- just because you leave 10 feedbacks for one person does not mean the persons total goes up by 10 Globally. Each user can only leave 1 unique feedback that is counted towards a users global feedback count, though the total count is still viewable in their profile. An example is as such
I buy 10 items from Joe
3 other people buy items from Joe
Joes global feedback is 4 / 100%
But his total feedback is 13 in his profile at 100%
* i didnt code the system to work like that. its that way out of the box
The system CAN be abused, cheated, etc. Its not a sure proof way to protect yourself but used in conjunction with your own diligence then it may make a difference. It will always be buyer beware on all sites. Do your homework.
If two users engage in negative feedbacking we will not police it. You are adults. If someone is unfairly feedbacking you then contact the staff to look into it before you go and do the same back to them. If you do the same back, dont bother us with it. While we read every PM you send we may or may not edit a feedback, its our discretion. The general rule we go by is we do not manage the feedback.
We will always remove negative feedback that is of opinion and not fact.
ie:
example 1) do not buy from joe because i think he tried to scam me because he didnt include a box. do not buy from joe
**this feedback could possibly be deleted by staff.
example 2) purchased an item from joe, description said new in box but upon inspection at home it was the wrong box, item was cracked and missing parts. do not buy from joe
**this feedback is well within reason and would not be subject to deleting.
Old Aug 27, 2014 | 03:16 AM
yank's Avatar
Total Cats: 32
How to change thread title..
(As to warn others never to try this build method and if they want more powers then they just need to build a 1.8 or swap in a big kid engine like an LSX)
Old Feb 14, 2016 | 10:51 AM
hornetball's Avatar
Total Cats: 697
How do you tag someone in a post? Others have done this to me and it gives me a notification when I sign on. I'd like to do it sometimes, but don't know how. ???
Old Feb 15, 2016 | 12:08 PM
Girz0r's Avatar
Total Cats: 323
[utag]username[utag] - add the / to close, like [/img]
Old Feb 15, 2016 | 03:39 PM
Total Cats: 4,370
on the list of threads, you can double click in the area of the thread title within the time limit of editing a thread title.
spec1sef
28
May 9, 2017 07:03 AM
Sirnixalot
Engine Performance
Sep 20, 2015 09:45 PM
