Weird clicking/hitting noise front right side
Old Jan 14, 2012 | 10:38 PM
Enslaved's Avatar
Default Weird clicking/hitting noise front right side
i've heard about the notorious lifter tick but i'm pretty sure its not that, it almost sounds like a stick hitting my front right wheel, as i go faster it gets faster and slower it gets slower, i know its not the motor because i parked it in my garage and gave it some life revs and it wasnt making the sound. it happens like 80% of the time while driving, most other people that ride with me dont notice it too much but it bugs the crap outta me haha, i tried to look to see if anything was in the way but i didnt see anything, probably going to jack the car up tomorrow after work to see if i can diagnose anything, until then, does anybody have any ideas or anything that it might be?
Old Jan 14, 2012 | 11:04 PM
nitrodann's Avatar
Total Cats: 66
Rock stuck in the tyre?
Dann
Old Jan 15, 2012 | 09:32 AM
Enslaved's Avatar
that was the first thing i checked, nothing.
Old Jan 15, 2012 | 10:16 AM
"Life revs" are nguyen. Get us some audio, use the shift key to capitalize a few "me me me" words, and we will fix this problem for you.
Old Jan 15, 2012 | 03:46 PM
fooger03's Avatar
Total Cats: 230
any popping noise while backing up at full steering lock?
Old Jan 15, 2012 | 04:20 PM
rleete's Avatar
Total Cats: 1,342
My first guess would be wheel bearing.
Old Jan 15, 2012 | 04:34 PM
Seefo's Avatar
Total Cats: 48
if its speed related, but not related to the engine engaged to the transmission or the engine speed, then its likely something physically hitting and or spinning with the wheel.
Wheel bearings tend to make clicking noises, so that is a possibility. Other things include rocks or pebbles stuck between the dust shield and the rotor, or the rotor and hub, etc. etc. (i have had the last case happen before).
Old Jan 15, 2012 | 05:31 PM
FRT_Fun's Avatar
I'm a terrible person
Total Cats: 180
Possibly some plastic under panels. Wind may be pushing it into the wheel if you are missing some bolts.
Old Jan 15, 2012 | 08:18 PM
mx594m's Avatar
raise each front tire, shake well in all four directions, listen for clink
check lug nuts
Old Jan 15, 2012 | 08:30 PM
Seefo's Avatar
Total Cats: 48
check lug nuts
about to say this
Old Jan 19, 2012 | 09:40 PM
Enslaved's Avatar
i found the problem dudes! whoever put brakes on the car last put the wrong type,the brake pad has a about an centimeter or two of gap so it just gos up and down and up and down, right around 20-30ish miles an hour. just gonna wait till i need new ones though because they are practically brand new
Old Jan 19, 2012 | 10:09 PM
fooger03's Avatar
Total Cats: 230
When you crash into a bus full of children and kill them all in a fiery explosion because your brakes didn't work, you will get no sympathy from me. The fact that they are "new" doesn't justify driving with incorrect safety parts. If you bought a brand new seatbelt, but the buckle didn't click in because it was the wrong size, would you drive with it like that for 2 years until the "newness" wore off?
Your cheapness does not justify manslaughter - and there is a difference between "cheapness" and "frugality".
Old Jan 19, 2012 | 10:16 PM
dustinb's Avatar
yeah that's uber weak. Incorrect brake pads on the biggest brakes on the car (because the rears are pretty useless) is just asking for trouble. You can get new pads for like $35. Hell go to a wrecker and get used ones for $5.
Old Jan 19, 2012 | 10:22 PM
Miater's Avatar
Total Cats: 27
That will eat into the calipers and wear the disc the wrong way. Not a good idea to wait. Cheap pads are cheap!
Old Jan 19, 2012 | 10:51 PM
mx594m's Avatar
what else on your car is done half assed
Old Jan 19, 2012 | 11:07 PM
Enslaved's Avatar
it is not both sides, just the front right, thanks for the constructive criticism and advice though, not so much for the smartasses. i didnt know having the wrong brakes could instantly make me a murderer, i should definitely be more careful, no seriously though i'll get new brakes asap. i <3 trolls
Old Jan 19, 2012 | 11:41 PM
mx594m's Avatar
not meant as criticism, you got to ask yourself what else was not done correctly, for your safety, the safety of your passengers, and fellow drivers
hey, this is MT.net not M.net; discussions here are very to the point
Old Jan 20, 2012 | 07:32 AM
Enslaved's Avatar
just my opinion, but thanks for the advice.
bigmackloud
Jan 8, 2021 11:24 AM
Aug 30, 2017 09:50 PM
