How a "Block Style" cylinder head is measured for thickness.
Old May 18, 2012 | 05:19 PM
BogusSVO's Avatar
Total Cats: 205
Default How a "Block Style" cylinder head is measured for thickness.
This is a fairly simple thing to do.
This will also help in setting the timing belt and calculate combustion chamber size.
New head thickness is 5.200
The Mitsubishi factory manual says a combined total of .008 may be removed from the block and head.
AERA (Automotive Engine Rebuilders Association) says .015 can be milled from the head.
So by AERA specs the Min thickness will be 5.185
The tools needed will be few.
Something to use to clean the head gasket surface
And a set of venier calipers,
Paper and pen.
The first thing to do is remove the head from the engine.
Remove both the exhaust and intake manifolds.
Now on the work bench, remove the cam caps
The cams and followers.
Next roll the head over so the head gasket surface is up.
Now the head gasket surface needs to be cleaned of any old gasket material.
I use a stiff backed long body board.
Now roll the head so one port side is up,
I will start on the exhaust side.
Measure from the valve cover rail to the head gasket surface.
I will also use the cam cap mating surface on the top, it will help keep the calipers square.
Make a note of the measurement.
This is Exhaust Front
On this head it was 5.193
Next I will move to the rear of the head.
Make note of this measurement.
This is Exhaust Rear
Here I measured 5.190
Next roll the head over to the Intake side.
This is the Intake Front
The measurement is 5.191
Now to take the forth and final measurement.
This is the Intake Rear
This measured 5.188
So now with the 4 measurements.
EF=5.193 IF=5.191
ER=5.190 IR=5.188
We see the head is not parallel to the valve cover rail.
We can see that from side to side there is .003 difference
And the same .003 from front to back.
Note also this head was belt surfaced before.
This is not a badly surfaced head for being belt surfaced.
The combustion camber volumes will still not be equal.
This procedure will hold true for any "box style" cylinder head.
Other related links
Attached Thumbnails How a "Block Style" cylinder head is measured for thickness.-003.jpg   How a "Block Style" cylinder head is measured for thickness.-005.jpg   How a "Block Style" cylinder head is measured for thickness.-019.jpg   How a "Block Style" cylinder head is measured for thickness.-017.jpg   How a "Block Style" cylinder head is measured for thickness.-020.jpg
How a "Block Style" cylinder head is measured for thickness.-021.jpg   How a "Block Style" cylinder head is measured for thickness.-022.jpg   How a "Block Style" cylinder head is measured for thickness.-024.jpg
Old May 18, 2012 | 05:26 PM
BogusSVO's Avatar
Total Cats: 205
Mazda info
1.8 NB 97-04
New thickness 5.276
Min thickness 5.267
Mazda 1.8 BP 90-97
New thickness 5.276
Min thickness 5.267
Mazda 1.6 90-95
New Thickness 5.276
Min thickness 5.267
Specs are from AERA Head and block 2009-2010
Old May 18, 2012 | 05:44 PM
Oscar's Avatar
Total Cats: 120
Good stuff. When cleaning the gasket surface with that board, is there sandpaper on it? (what grit?) or is it more like a paintscraper thingy?
Old May 18, 2012 | 06:48 PM
BogusSVO's Avatar
Total Cats: 205
Oscar... Do you mean this method?
https://www.miataturbo.net/showthrea...665#post862665
You may like this one too..
https://www.miataturbo.net/engine-performance-56/head-gasket-repair-how-clean-block-surface-w-pistons-installed-65074/
Old May 18, 2012 | 09:47 PM
Faeflora's Avatar
Total Cats: 130
Ohhh so this is how you tell if a head has been milled?
Old May 19, 2012 | 12:05 AM
BogusSVO's Avatar
Total Cats: 205
Fae, yes it is and how much.
Old May 27, 2013 | 06:03 PM
Radiuz's Avatar
Any reason at all why you don't use a micrometer as opposed to a vernier? I'm not making any criticism I just get a bollocking at work whenever I'm spotted using a vernier haha
Old May 27, 2013 | 06:07 PM
supercooper's Avatar
Total Cats: 35
HAH! almost responded... the month on this thread had me fooled.... necromancy is EVIL!!!!
Old May 28, 2013 | 02:01 AM
triple88a's Avatar
Total Cats: 1,830
Vernier, you mean a caliper?
When measuring straight surfaces a caliper is more versatile. To use a micrometer you have to have straight surfaces on each side that you're measuring. In a case where you have a head that is dug up for the piston chamber you just cant use it.
Now of course there are very very precise calipers just like there are micrometers. The shop i used to work had one that was almost half an inch thick to ensure it doesnt bend.
Old May 28, 2013 | 10:19 AM
They used to be called vernier calipers, vernier in latin means very near. I never call a digital or dial caliper a vernier, just the really old style that only uses the slide for its increments.
Corky Bell
Prefabbed Turbo Kits
Nov 22, 2016 09:01 PM
shooterschmidty
Engine Performance
8
Sep 30, 2015 10:28 PM
JesseTheNoob
Sep 30, 2015 02:44 PM
btabor
ECUs and Tuning
10
Sep 28, 2015 05:33 PM
