90-2005 parts clearance revisited and updated
Old 04-21-2011, 10:27 AM
gdnimr0d's Avatar
Default 90-2005 parts clearance revisited and updated
Miata parts FS:
99-05
Exterior
-99-00 Silver Passenger door shell -$75
-99-00 Silver Trunk decklid - $50
-x2 Power antennae - $50
Interior
-Bose cd player and tape deck combo -$30
-Right and left manual window regulators (both) - $50
-Right and left POWER window regulators (both) - $100
-01-05 Power door locks with wiring harnesses (both) - $50
-01-05 power window switch Black - $50
-99-00 all factory relays - $5 per relay
-99-00 dimmer switch -$5
-99-00 Power mirror controller - $5
-99-00 Gauge cluster -$20
-Gauges cluster hood - $15
Drivetrain
-99-00 Automatic Transmission 30,000 miles on it Mint condition with torque converter and flex plate and flywheel bolts -$350
-99-00 Automatic Driveshaft - $50
-Complete 1.8 Brake caliper set with soft lines miles on them - $125
-99-00 Brake master cylinder and booster and proportion valve -$50
-Right and left front spindles with abs sensors -$30 per side
-Right and left rear uprights with abs sensors - $30 per side
-P/S rack with inner and outer tie rods - $35
-Complete P/S system with pump, all hoses and pressure lines, reservoir, and rack -$100
-Complete 99-00 Open diff with housing and r&p - $150
-Open differential no housing, individual unit - $30
-Used starter - $40
Engine Parts
-ARP 1.8 head studs - SOLD
-01-05 complete head with 40K on it perfect condition with intake manifold - $400
-99-05 brand new radiator with fans complete -$125
-Driver side radiator fan - $35
-x7 crank pulleys with crank trigger wheels - $10
-99-00 Coil Pack - $50
-99-00 Vacuum and map sensor rack- $35
-99-00 Automatic Ecu - $50
-x7 Water pump Pulleys - $5 per
-99-00 Oil pan - $30
-99-00 Damaged head complete with camshafts - $100
-99-00 thermostat housing and various other cooling hard tubes and outlets - $5 per
-99-00 Miata 3 inch straight pipe exhaust (was on a turbocharged 99 Miata) - $75
-99-00 Cam gears (Both) - $10
-99-00 Valve cover - $35
-Various A/C hoses - $5 per hose
90-97 Parts
Exterior
-Passenger headlight mechanism
Interior
-Driver airbags - $5 per
-94-97 Passenger airbag Mint - SOLD
-Passenger seat black leather custom wrapped no tears or rips - $15
-Passenger seat fabric no tears or rips -$10
-94-97 stereo surround - $15
Engine Parts
-NON-P/S Idler pulley and bracket -$75
-94-97 Vacuum solenoids - $5
- 1.6 coil packs - $50 per
-x5 90-97 A/c Radiator fans -$25 per
-1 driver side Radiator fan - $35
-90-93 Crank and water pump V belt pulleys - $15
-90-93 alternator - $20
-Starter - $20
-90-93 Intake tube - $10
call me at 754 244 1755
thanks or email me Ryanckaufman@gmail.com
some of the parts photos can be found here
http://s224.photobucket.com/albums/d...rts/?start=all
gdnimr0d is offline
Old 04-21-2011, 11:05 AM
lsc224's Avatar
PMd you
lsc224 is offline
Old 04-21-2011, 12:31 PM
yellowihss's Avatar
Email sent for head studs.
yellowihss is offline
Old 04-21-2011, 06:01 PM
gdnimr0d's Avatar
everyone has been responded to
gdnimr0d is offline
Old 04-21-2011, 09:55 PM
yellowihss's Avatar
Payment sent for head studs.
Old 04-22-2011, 12:32 AM
lsc224's Avatar
Payment sent for AC relay, thanks.
lsc224 is offline
Old 04-22-2011, 08:56 AM
gdnimr0d's Avatar
Arp head studs are sold along with some relays
gdnimr0d is offline
Old 04-22-2011, 09:21 AM
gdnimr0d's Avatar
passenger and 1 driver airbag sold
gdnimr0d is offline
Old 04-23-2011, 03:01 PM
gjenks's Avatar
pm sent for 99-00 coil pack.
gjenks is offline
Old 04-23-2011, 04:49 PM
skou's Avatar
Total Cats: 21
Is the damaged '99-'00 head reparable? Can you post some photos and more details? Thanks.
skou is offline
Old 04-23-2011, 08:30 PM
MD323's Avatar
In for damaged head pics too
MD323 is offline
Old 04-24-2011, 11:12 AM
gdnimr0d's Avatar
somone dropped a bolt in cylinder number 4 and it bent the valves and scarred the combustion chamber surface pretty much good for parts or if you are a really good head guy ...u could prolly fix it
gdnimr0d is offline
Old 04-24-2011, 11:32 AM
skou's Avatar
Total Cats: 21
What condition are the cam shafts in?
skou is offline
Old 04-24-2011, 11:58 PM
marcoSTEEZ's Avatar
It isn't listed, but by any chance do you have a NB rear passenger fender or rear bumper
marcoSTEEZ is offline
Old 04-27-2011, 09:01 AM
gdnimr0d's Avatar
camshafts appear to be in good conidition...selling as a pair $100 bucks plus shipping
nope no rear fender or bumper
gdnimr0d is offline
Old 04-30-2011, 11:57 AM
gdnimr0d's Avatar
bumpity bump bump
gdnimr0d is offline
Old 05-02-2011, 09:56 AM
astroboy's Avatar
Have any wiring for a 99? I need an iacv plug and tps plug if you do.
astroboy is offline
Old 05-09-2011, 09:25 AM
gdnimr0d's Avatar
bump
gdnimr0d is offline
Old 05-09-2011, 10:10 AM
Faeflora's Avatar
Total Cats: 130
Got the factory undertrays?
Faeflora is offline
Old 05-10-2011, 09:05 AM
gdnimr0d's Avatar
i have the one that fits in the front of the bumper...but not the main big one that connects to the subframe
gdnimr0d is offline
Quick Reply: 90-2005 parts clearance revisited and updated
