FS: MSM diff and cut BP valve cover
Old 05-10-2011, 10:41 AM
astroboy's Avatar
Default FS: MSM diff and cut BP valve cover
Got this diff off a fellow MT user (spd579) and decided I would like the lesser quality obx unit. You get the torsen unit only for $200 or would trade for an OBX helical with the bolt and shim kit.
Also selling my old valve cover. Exposed the gears, cuts could use some dremel work to clean up. Valve cover was also degreased up some but it is still a little dirty and can be had with an blue anodized oil cap. $35
astroboy is offline
Old 05-10-2011, 11:40 AM
wittyworks's Avatar
Total Cats: 23
Thats the diff that needs the special MSM axles right?
wittyworks is offline
Old 05-10-2011, 01:15 PM
astroboy's Avatar
Yes it needs msm axels.
astroboy is offline
Old 05-10-2011, 02:42 PM
Originally Posted by astroboy
Yes it needs msm axels or, I think, you can also use 03+ axles but don't quote me on it.
All NB axles are the same (abs vs non-abs aside) except for MSM axles.
Old 05-10-2011, 03:08 PM
astroboy's Avatar
Thanks Ben!
astroboy is offline
Old 05-11-2011, 02:21 PM
astroboy's Avatar
Bumpski!
astroboy is offline
Old 05-11-2011, 09:45 PM
supersuk's Avatar
Is this Martin from Hawaii?
supersuk is offline
Old 05-11-2011, 10:02 PM
astroboy's Avatar
Yesir!
astroboy is offline
Old 05-12-2011, 04:19 PM
astroboy's Avatar
Are my prices too high or is the MSM diff that undesirable?
astroboy is offline
Old 05-12-2011, 06:26 PM
JayL's Avatar
The MSM diff is very desirable, but completely useless without the axles that go with it.
JayL is offline
Old 05-13-2011, 10:15 AM
I'm a terrible person
FRT_Fun's Avatar
Total Cats: 180
I would take everything except for the actual diff... aka R/P + pinion housing... if you are willinlg to part it.
FRT_Fun is offline
Old 05-15-2011, 04:10 PM
astroboy's Avatar
Still have both and have yet to receive any offers :(
astroboy is offline
Old 05-16-2011, 11:17 AM
astroboy's Avatar
Anybody want to make an offer?
astroboy is offline
Old 05-16-2011, 11:24 AM
FRT_Fun's Avatar
Total Cats: 180
To verify, and maybe someone else can answer if you do not know. Will I be able to use your Ring and Pinion with my 88 RX7 differential and bolt it all to your pinion housing and install on my 97' Miata?
If yes then let me know what you want for that stuff and I can PP.
FRT_Fun is offline
Old 05-16-2011, 11:36 AM
if you are just swapping the lsd then yes it will work but you will need a cover for the back of the diff. and i believe you need to use different c clips to retain the halfshafts as well. Why are you bothering though its just a 4.1 the same as you have in your 97 currently.
Old 05-16-2011, 11:47 AM
FRT_Fun's Avatar
Total Cats: 180
I currently have no differential at all since I had a kaaz which I sold. I have the RX7 cover for the back of the differential which works, I just need Miata diff mounts. As for c-clips the FAQ says I need RX7 ones, but brain said I don't, so I'm going to try without and see what happens.
FRT_Fun is offline
Old 05-16-2011, 01:16 PM
astroboy's Avatar
Just want to make sure you know it is only the front part, ie there are no tabs for mounting it to the subframe.
astroboy is offline
Old 05-16-2011, 01:18 PM
FRT_Fun's Avatar
Total Cats: 180
^I would be using the Aluminum housing from the RX7 differential.
FRT_Fun is offline
Old 05-16-2011, 04:35 PM
astroboy's Avatar
Diff and housing/r&p are pending separation.
astroboy is offline
Old 05-17-2011, 11:09 PM
astroboy's Avatar
Diff housing with r&p sold. Torsen up for grabs for 200,000¢
astroboy is offline
10-03-2015 11:04 AM
ihiryu
General Miata Chat
09-28-2015 10:22 AM
Quick Reply: FS: MSM diff and cut BP valve cover
