MS-1 PCB 3.0, assembled unit - $200 shipped
Old Jan 30, 2012 | 09:32 AM
devin mac's Avatar
Default MS-1 PCB 3.0, assembled unit - $200 shipped
This was running my greddy based setup in parallel with the factory 1993 ecu. all I needed was to build a new harness for it, but it did the job so I never got around to it. only things it wasn't running were idle or the A/C that I no longer had.
It's a 3.0 PCB unit, running whatever the last non hi-res firmware there was. it's been so long that I don't recall what version that actually was. Either way, flashing new firmware to it would be a good idea.
assembled by k1ng0fl33t, if anyone remembers him. He wasn't known for his craftsmanship, so giving it a once over for iffy soldering might not be the worst idea ever, but by the same token, it ran my car just fine for a long while before i blew cyl4 and my turbo and parked it. :-)
ready to ship.
Old Jan 30, 2012 | 10:02 PM
DROPBTM's Avatar
What all does it come with..?? Any pics of it. I will take it if its plug and play on my 93 1.6T
Old Jan 31, 2012 | 07:45 AM
devin mac's Avatar
It's JUST the megasquirt itself, the same as if you bought an assembled unit from somewhere else.
You'll need an iat sensor and a harness that connects the MS to your factory harness. It's not pnp, unfortunately. But its not far off either.
Old Feb 3, 2012 | 08:50 AM
devin mac's Avatar
ninja-bump. nobody needs an inexpensive MS?
Old Feb 17, 2012 | 08:28 AM
devin mac's Avatar
maybe a pic will encourage someone?
Attached Thumbnails MS-1 PCB 3.0, assembled unit - 0 shipped-img_20120131_074546-1.jpg
Old Feb 19, 2012 | 10:07 AM
skullzaflare's Avatar
so i assume all i need is the iat and harness adaptor? does it not come with a harness pigtail?
i also have a 93t lol, what is this ecu tuned for right now in terms of what motor, injection setup, ignition setup, and boost amount/injector size
im very interested. also, is it ready to eliminate the stock ecu if wired up properly or still to be ran as a piggy back?
Apr 21, 2016 03:00 PM
russian
Oct 8, 2015 03:01 PM
Aroundcorner
Oct 1, 2015 03:20 PM
lsc224
Oct 1, 2015 09:17 AM
