97 partout, turbo kit, coils, wheels, ecu, stock parts
Old 04-30-2012, 11:09 PM
ttmiata's Avatar
Default UPDATED: 97 partout, turbo kit, coils, wheels, ecu, stock parts
Parts still available have been moved to the top. Items sold are listed at the bottom.
4 RC 550cc low impedance injectors, comes with two sets of wire ends, 140.00
8 94-97 1.8 Stock tan top injectors, 60.00
94-97 Flyin Miata dual feed rail, stainless braided lines, A/N fittings, JEGS pressure gauge mounted inline, 220.00
Spec Stage 3+ clutch kit, 6 puck sprung disc, approx 15k, 220.00
17.5 lb stock 1.8 flywheel, 40.00
4 XXR 513, 15x8, 0 offset, 4lug universal. Tires currently mounted are brand new dunlop direzza 205/50 on front, kumho ecsta ast 225/50 on rears with 40%. 600.00
3 Panasport 14x7, +20 offset, 4x108/4.25, no tires, MAKE AN OFFER
Absurdflow twin turbo setup, for 1.8L, comes with everything you'll need to do weekend install (oil lines, fittings, coolant lines with banjo fittings, filters, hardware) except for the oil drain fittings that go into the oil pan they are already installed. I will sell the pan for another 40. Kit includes manifold, two Garrett 1548 turbos with approximately 20k on them, downpipe with bung for wideband sensor, 3" exhaust out. Kit cost 60 bucks to ship from Texas to NC in fall of 2010. 1000.00
97 1.8 head with 120k, setup for spacerless coolant reroute through the rear of the head, freeze plug installed in the stock front exit location, heater hose fitting drilled and tapped in the rear, cam seals replaced 5k ago, complete underneath valve cover, 100.00
95 1.8 head with unknown miles, complete underneath valve cover, 80.00
94 1.8 head with 104k, complete underneath valve cover, 80.00
3 1.8 shortblocks, assume they are needing full bebuild. Have cranks for each, I know one of them is good to go with stock size journals, the other two need to go to a machine shop. I have some pistons and rods, some of the rods got ruined from bearing failure. Message me if you want the oil pump(s) specifically or not. I will consider separating pieces but would like to sell them with the block and crank paired, and maybe with the oil pan if you want it. 160.00 apiece
1990 Dash w/clear title, MAKE AN OFFER
Prices are listed in bold. They are not negotiable for now, I am in no hurry to sell. Besides, they are already cheap as hell. Everything is located in Raleigh, NC 27603. If you are interested in multiple items just message me. I am willing to ship just about anything within reason, and at the buyer's expense. I will post pics of everything tomorrow when it is daylight out. All parts are in used working condition, unless otherwise specified. Some of these parts have very little use.
I am not afraid to completely disassemble this car piece by piece if there seems to be an interest for a lot of parts. The only reason I am hesitant to do this is because there is another gentleman in the triangle area who regularly parts wrecked miatas and sells the parts at reasonable prices and he has a lot so I would rather not compete with his business.
The car is basically in full part-out mode. Let me know what you want.
Evo 8 intercooler kit, 2.5" tig welded piping, powdercoated black, black silicone joints, currently best configured on hotside for bottom or side mount setups. Pre-intercooler side has bung in place for turboxs bov, SOLD
TurboXS RFL blow off valve, SOLD
Found a package of Viton valve seals I forgot I had, SOLD
Forgot I had a red NRG quick release hub mounted to a momo hub. It's the one in the picture with the driver's door open. SOLD
Sparco shift ****, SOLD
Crown Royal bag/boot, I made it...hand sewn , SOLD
96-97 MSPNP, comes with IAT sensor but no bung, grounds added to run low imp injectors, SOLD
Innovate LC-1 WBo2, blue gauge, bosch sensor, SOLD
Autometer "Boost by Flyin Miata" gauge, SOLD
99 1.8 head with 100k, with intake, valve shim adjustment done 4k miles ago, complete underneath valve cover, SOLD
Boundary Engineering oil pump gears, barely used, SOLD
NA Flyin Miata Vmaxx coilovers, less than 5k miles, SOLD
NA R-package front lip, repainted satin black. This is an oem part. SOLD
Attached Thumbnails 97 partout, turbo kit, coils, wheels, ecu, stock parts-5e5f8a1b.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-2169bd34.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-ef9f12af.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-39f7a56d.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-bcbc57d1.jpg
97 partout, turbo kit, coils, wheels, ecu, stock parts-99840758.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-2d136cf8.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-86be4186.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-cfc43016.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-d8c8a9d1.jpg
97 partout, turbo kit, coils, wheels, ecu, stock parts-f80eaecc.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-beeff62a.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-57ef60a8.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-4e61d36d.jpg
ttmiata is offline
Old 04-30-2012, 11:51 PM
miatauser884's Avatar
Total Cats: 11
Can I get a pic of the intercooler and piping setup? Could be a good upgrade from my old fm ic.
Ill be in Raleigh next week. Maybe ill pack an extra suitcase and fly it back with me.
miatauser884 is offline
Old 04-30-2012, 11:52 PM
ttmiata's Avatar
I now know what it feels like to sell 12,000 dollars worth for half that.
ttmiata is offline
Old 05-01-2012, 12:18 AM
viperormiata's Avatar
Total Cats: 283
If you do decide to part out the chassis, I will immediately send you money for all the black carpet.
viperormiata is offline
Old 05-01-2012, 12:46 AM
Slowest Progress Ever
Total Cats: 304
Omg, is that Tim's old Twin Turbo setup? If so, That thing gets cheaper and cheaper everytime it gets advertised!!
thirdgen is offline
Old 05-01-2012, 08:37 AM
Oskinosmee's Avatar
Total Cats: -8
Interested in ic pm me
Oskinosmee is offline
Old 05-01-2012, 09:03 AM
ttmiata's Avatar
Attached Thumbnails 97 partout, turbo kit, coils, wheels, ecu, stock parts-1308faac.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-ad6a6ebb.jpg
ttmiata is offline
Old 05-01-2012, 09:04 AM
f1luva92's Avatar
i'll take the wideband. just pm me paypal info and shipping costs to 22903.
f1luva92 is offline
Old 05-01-2012, 09:06 AM
ttmiata's Avatar
tell me about it. when he first put it up for sale i think it was something like 1800 bucks. i listed it a couple months ago for 1200 and didn't get any hits.
ttmiata is offline
Old 05-01-2012, 09:08 AM
ttmiata's Avatar
dully noted sir. that may be a possibility without too much wait, since the overall condition of this car won't really be sacrificed without it's carpet.
ttmiata is offline
Old 05-01-2012, 09:20 AM
ihmcguinness's Avatar
interested in Vmaxxes. PM'ed.
ihmcguinness is offline
Old 05-01-2012, 11:55 AM
Tyler01's Avatar
I would like the 99 head and oil pump gears, I am only about an hour from your location. Let me know when I can come pick them up.
Tyler01 is offline
Old 05-01-2012, 12:45 PM
ttmiata's Avatar
They are both off the car already and ready to go. You can come anytime. call/text 919.943.6867 for my address.
ttmiata is offline
Old 05-01-2012, 03:30 PM
f1luva92's Avatar
so did someone get the wideband before me or what?
f1luva92 is offline
Old 05-01-2012, 04:10 PM
ttmiata's Avatar
that is correct.
ttmiata is offline
Old 05-01-2012, 04:13 PM
ttmiata's Avatar
buyer for coilovers backed out. they are back up for sale. in the process of getting/uploading photos.
ttmiata is offline
Old 05-01-2012, 04:39 PM
ttmiata's Avatar
Attached Thumbnails 97 partout, turbo kit, coils, wheels, ecu, stock parts-0a6e3352.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-c38c8994.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-61d1aed5.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-50e5aa16.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-c856de7d.jpg
97 partout, turbo kit, coils, wheels, ecu, stock parts-5e5f8a1b.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-6708dcc0.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-2169bd34.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-ef9f12af.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-a9cf2a6c.jpg
97 partout, turbo kit, coils, wheels, ecu, stock parts-f94b0dd4.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-39f7a56d.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-57ef60a8.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-4e61d36d.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-f80eaecc.jpg
97 partout, turbo kit, coils, wheels, ecu, stock parts-beeff62a.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-cfc43016.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-d8c8a9d1.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-86be4186.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-99840758.jpg
97 partout, turbo kit, coils, wheels, ecu, stock parts-2d136cf8.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-14d764ab.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-5b9af96f.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-8a4be576.jpg   97 partout, turbo kit, coils, wheels, ecu, stock parts-39d05343.jpg
ttmiata is offline
Old 05-01-2012, 11:47 PM
ttmiata's Avatar
added a few things I forgot about/failed to list previously.
ttmiata is offline
Old 05-02-2012, 12:16 AM
Legal_go_kart's Avatar
I tried to PM you, but not sure if it went through due to my lack of posts. I'm interested in the NRG Quick Release, hub, and steering wheel if you you still have them.
Legal_go_kart is offline
Old 05-02-2012, 12:47 AM
Dolsiac's Avatar
Im a huge crown fan so ill snag the Sparco shift **** and crown boot from you, Pm me your paypal info and ill send money out asap. Id PM you but like ^ I still am too low to do that haha. Let me know thanks!
Dolsiac is offline
Quick Reply: 97 partout, turbo kit, coils, wheels, ecu, stock parts
