1990-2005 parts clearance ...clearing out once again
Old 10-08-2012, 02:38 PM
gdnimr0d's Avatar
Default 1990-2005 parts clearance ...clearing out once again
Once again these are all the parts I still have in my shop that i am trying to sell or get rid of...first come first serve
call 754 244 1755
ask for Ryan ...everything is able to be shipped
or email me at ryanckaufman@gmail.com
thanks
Miata parts FS:
99-05
Exterior
-99-05 hood latch - $15
Interior
-Right (passenger) and left (driver) manual window regulators (both) - $50
-Right POWER window regulator - $50
-01-05 power window switch Black - $50
-99-00 all factory relays - $5 per relay
-99-00 dimmer switch -$5
-99-00 Power mirror controller - $5
-x2 99-05 a/c control unit - $5
-x2 99-05 turn signal and light combination switch - $30
-99-00 automatic shifter selector - $10
Drivetrain
-99-00 Automatic Transmission 30,000 miles on it Mint condition with torque converter and flex plate and flywheel bolts -$350
-99-00 Automatic Driveshaft 30,000 miles on it - $50
-Complete 1.8 brake caliper set with brackets and soft lines -$125
-1.8 5spd driveshaft with bolts - $75
-Right and left rear abs sensors - $5 per
-Complete set of all four front and rear hubs with ARP extended studs in the rear hubs only – $100 for complete set
-driver side rear hubs 1 non abs - $25 per
-99-05 Remanufactured starter - $40
Engine Parts
-Driver side radiator fan - $35
-x3 crank pulleys with crank trigger wheels - $10
-99-00 Vacuum and map sensor rack- $35
-x3 Water pump Pulleys - $5 per
-99-00 thermostat housing and various other cooling hard tubes and outlets - $5 per
-99-00 Miata 3 inch straight pipe exhaust (was on a turbocharged 99 Miata) - $50
-x 3 99-00 Cam gears (Both) - $10
- 99-00 Alternator - $25
-Various A/C hoses - $5 per hose
-x2 99-00 complete a/c lines with condenser - $40
-99-05 Fuel feed line quick disconnect factory - $5
99-05 vacuum solenoid rack and map sensor - $10
99-05 fuel distribution block with short quick disconnect hose - $5
90-97 Parts
Interior
-x2 90-93 turn signal and light combination switch - $10
- 90-97 A/c controls -$5
-90-93 automatic shift selector - $5
Engine Parts
-90-93 fuel injector harness - $5
-94-97 Vacuum solenoids - $5
-1.6 90-93 vacuum solenoid - $5
-90-93 5 spd TPS sensor - $5
-90-93 Automatic 4 pin sensor $40
-90-93 Crank and water pump V belt pulleys - $10
-Starter - $20
-x2 90-97 power steering pump - $20
gdnimr0d is offline
Old 10-31-2012, 11:19 AM
slammed200's Avatar
Total Cats: 29
I'm interested in these
"-Complete set of all four front and rear hubs with ARP extended studs in the rear hubs only – $100 for complete set"
Will they fit a '94 M Edition and how many miles are on them? What is the part number on the extended ARP studs?
slammed200 is offline
emilio700
Wheels and Tires
151
06-02-2017 02:36 PM
Aroundcorner
10-01-2015 03:20 PM
Quick Reply: 1990-2005 parts clearance ...clearing out once again
