FM Intercooler Pipe, NB Enthuza Muffler, BOV, & AIC
Old Jan 26, 2013 | 08:20 PM
RotorNutFD3S's Avatar
Total Cats: 36
Default FM Intercooler Pipe, NB Enthuza Muffler, BOV, & AIC
Clearing out some things from the garage. I'd prefer local pickup, but I'm willing to ship at buyer's cost. The muffler might take a day or two to prepare for shipping because I don't currently have any packing that will accommodate it.
FM hotside single piece silicone intercooler pipe - 2" inlet at the turbo, 2.5" outlet at the intercooler.
This pipe will only fit around 1.8L PS/AC accessories, if you don't have PS/AC, it will also fit on 1.6L cars.
SOLD
Enthuza XR Lightweight Turbo Muffler for NB exhausts only, 2.5" diameter. I bought it from the original owner and for whatever reason the tip was discolored. I have not tried polishing it because I was going to paint the tip black and run it like that. Drops about 9 lbs vs. other muffler options.
SOLD
GFB 1004 Blow-Off Valve - It was used when purchased and has some minor rub marks at the top from the prior install, depending on the orientation when mounted it won't be seen, pictured below.
SOLD
MSM Water Pipe - This has a provision for water return from the turbo, makes life a little simpler.
$25
Split Second Additional Injector Controller (AIC1-G4H) - Simple way to add probably 7-8 psi of boost to your car (low-boost turbo setup, M45 supercharger, etc.). Came off a supercharged NB which passed emissions with this, but can be wired into any Miata and fuel rate can be adjusted via internal controls. It has very few connections and uses an on-board MAP sensor for monitoring and fuel addition. Requires use of 4 high impedance injectors.
Typical installations put this box in the engine bay, previous installer cut the injector harnesses, ran the wires through the firewall, and reconnected them (2 wires per injector) so that the box was inside the cabin. Still worked fine when removed. Injector ends are still disconnected so that the next owner can decide how they want to install it.
$100
Attached Thumbnails FM Intercooler Pipe, NB Enthuza Muffler, BOV, & AIC-8411800265_7770c8bd08_c.jpg   FM Intercooler Pipe, NB Enthuza Muffler, BOV, & AIC-8411798419_4c011a229a_c.jpg   FM Intercooler Pipe, NB Enthuza Muffler, BOV, & AIC-8411798001_8e884ac4dc_c.jpg   FM Intercooler Pipe, NB Enthuza Muffler, BOV, & AIC-8411797891_75433995d2_c.jpg   FM Intercooler Pipe, NB Enthuza Muffler, BOV, & AIC-8411797747_c8c416526a_c.jpg
FM Intercooler Pipe, NB Enthuza Muffler, BOV, & AIC-8412895700_547778ecbb_c.jpg
Old Jan 26, 2013 | 08:52 PM
RedCarmel's Avatar
Total Cats: 21
PM sent
Old Jan 26, 2013 | 11:18 PM
Total Cats: 36
FM intercooler pipe sold.
Old Jan 27, 2013 | 02:12 AM
Mobius's Avatar
Total Cats: 365
For anyone considering the NB XR lightweight, do it, it's awesome. I love mine.
Edit - the tip discolors from normal heat cycling; mine has done this too.
Old Jan 27, 2013 | 12:29 PM
Total Cats: 36
Thanks for that info!
Old Jan 28, 2013 | 05:53 PM
Total Cats: 36
Got asked a couple times, so adding the info, BOV mount O.D. is 1 3/8".
Old Jan 28, 2013 | 10:13 PM
Total Cats: 36
BOV is sold.
Old Jan 29, 2013 | 02:23 PM
illiasfyntanidis's Avatar
Hi.I am interested about the exhaust...How can we get in touch?Low posts my side,any email address?
Old Jan 29, 2013 | 02:56 PM
Total Cats: 36
I'll send you a PM with contact information.
Old Jan 31, 2013 | 10:08 PM
Total Cats: 36
Muffler sold locally.
Old Feb 5, 2013 | 12:01 PM
EO2K's Avatar
Total Cats: 1,924
Interested in the MSM water pipe. Should fit any NB, yes?
Old Feb 5, 2013 | 01:32 PM
Total Cats: 36
Yep!
Trent
Oct 1, 2015 12:15 PM
The Gleas
Oct 1, 2015 09:30 AM
