ITT we discuss why not to turbo your daily bent rod
Old 05-09-2017, 09:06 PM
  #521
Schuyler's Avatar
Total Cats: 87
Originally Posted by HHammerly
I have the ac condenser, an oem rad core for my w/a ic and a 55mm koyo and run 210deg on 90deg track days 180 to 190 on 100deg days with the ac on.
i think that many of the problems people have are due to having air in the system with the coolant re-route system that just dont burp it out
Reading online now about proper burping procedure. It appears there is a strong probability I have done that wrong every time I've added coolant.
Schuyler is offline
Old 05-09-2017, 09:23 PM
  #522
patsmx5's Avatar
Total Cats: 490
On my car with a reroute, I leave the car level. I pop the radiator cap off and fill it as much as possible. Then pull a heater hose and fill it till the air is out of that end. Then a turbo coolant hose and do the same. Then reconnect, top of radiator once more, and there is no air.
patsmx5 is offline
Old 05-10-2017, 12:05 AM
  #523
Total Cats: 857
@HHammerly
What kind of front ducting? I didn't find any pics in your build thread.
Speaking of that, is your Turbo heat shield same stuff as your tunnel shield, but double layer: adhesive sides stuck together?
DNMakinson is offline
Old 05-11-2017, 07:07 AM
  #524
HHammerly's Avatar
Total Cats: 63
I have the oem ducting, i do have a large and a small spall fans on it, it may be wrong but i belive that the reason it does not overheat is that i have a small line with a 1/16" hole between the head front water neck and the line going into the radiator , it allways beeds any air at the top of the coong system into the rad where it can ho to the expansion tank ( i will get some photos when i get back home on Friday)
the turbo blanket is a dei aluminum ceramic aluminum material that i stiched together with safety whire.
HHammerly is offline
Old 05-11-2017, 08:13 PM
  #525
HHammerly's Avatar
Total Cats: 63
Head front water/ burp return
Where it goes back into the radiator inlet line
Old 05-11-2017, 08:14 PM
  #526
HHammerly's Avatar
Total Cats: 63
Stock ducting
Old 05-11-2017, 08:16 PM
  #527
HHammerly's Avatar
Total Cats: 63
Turbo heat shield
Old 05-11-2017, 08:50 PM
  #528
That's awesome! Solid posts.
Cats incoming when I get to a computer!
Old 05-13-2017, 09:50 AM
  #529
Schuyler's Avatar
Total Cats: 87
That's very interesting on the coolant setup, I may have to consider something similar if a standard burping does not help.
Also appreciate the heatshield info.
Schuyler is offline
Old 05-13-2017, 10:31 AM
  #530
HHammerly's Avatar
Total Cats: 63
Here is a flow diagram, i put this on Sahabs turbo car to solve the traped air on his coolant rr system and it sotopped having overheating issues, also put it on two of my cars with FI and coolant rr systems and neither would overheat on the street with ac or in the track.
No guarantee but it has worked for me
Old 05-14-2017, 05:39 PM
  #531
Scaxx's Avatar
Total Cats: 884
It was great meeting you today man! Hope your flight home goes well!
Scaxx is offline
Old 05-15-2017, 12:02 PM
  #532
Schuyler's Avatar
Total Cats: 87
Very nice meeting you as well! Looking forward to seeing more about your car in the comings months.
Schuyler is offline
Old 06-17-2017, 04:48 PM
  #533
Schuyler's Avatar
Total Cats: 87
So as those of you who followed the "almost running out of e85 on the interstate" saga in the chat, I have had to drive the miata this past week due to the electric water pump going out on the 335i. I believe I have found the culprit. Found pieces stuck in the blades of the turbine on the pump.
(Should look like this)
Schuyler is offline
Old 06-17-2017, 07:01 PM
  #534
Mobius's Avatar
Total Cats: 365
So ... it dissolved? Dried out and crumbled? What happened to that hose?
Mobius is offline
Old 06-18-2017, 04:48 PM
  #535
Schuyler's Avatar
Total Cats: 87
It has some sort of hard rubber/plastic adapter with an O-Ring that actually attached to the block with two bolts. It appears that broke. I ordered a billet replacement for that portion, and then you can use the same hose with a clamp.
Schuyler is offline
08-30-2017 09:50 PM
Corky Bell
Prefabbed Turbo Kits
11-22-2016 09:01 PM
Dparks7
09-28-2015 09:49 AM
Voltwings
Cars for sale/trade
09-27-2015 06:40 PM
Quick Reply: ITT we discuss why not to turbo your daily bent rod
