Old 05-24-2017, 02:36 PM
  #9741
I haven't put any new seals on. but couldn't find a straw that would fit yet. My new seals didn't come with one either. So I'll keep looking.
Chipotle didn't fit, neither did the bendy straws I have in the kitchen. Might try and grab a starbucks straw, or McDs. But I'm worried the McDonalds one will be too big, those are some monster straws.
Old 05-24-2017, 03:04 PM
  #9742
Total Cats: 856
codrus is offline
Old 05-24-2017, 03:07 PM
  #9743
bahurd's Avatar
Total Cats: 314
Maybe 7-11 or whatever the chain is there. Big Gulp cup size.
UPC Code: 041165060850
I have an email into Dart customer service asking for a chain that uses them. You never know 'till you ask.
bahurd is offline
Old 05-24-2017, 03:14 PM
  #9744
"Aidan uses seal 'issues' to go on fast food binge"
Old 05-24-2017, 03:37 PM
  #9745
bahurd's Avatar
Total Cats: 314
Or hit up your local Harbor Freight cylinder head repair shop for 6mm heat shrink tubing. All you're looking for is something to slip over the stem (5.9ish) to keep the seal lip from grabbing on the retainer groove. Then you pull it out once you "click" the seal into place.
bahurd is offline
Old 05-24-2017, 03:50 PM
  #9746
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
I just use a ziplock bag when the straw isnt included in the seal kit.
hi_im_sean is offline
Old 05-24-2017, 04:04 PM
  #9747
Total Cats: 1,899
Pay attention you goober, I posted that days ago.
EO2K is offline
Old 05-24-2017, 04:11 PM
  #9748
yank's Avatar
Total Cats: 32
I have a bag of your shims at the shop. I sent you a pic of them a few weeks ago..
yank is offline
Old 05-24-2017, 04:31 PM
  #9749
Woooo!
I didnt know what they were at that point. Thought they were washers. Thanks man. Hold onto them.
I don't need a reason to go on a fast food binge.
I have lots of heat shrink tubing. why the **** didnt i think of that.
Old 05-24-2017, 04:46 PM
  #9750
bahurd's Avatar
Total Cats: 314
Now that you've become a moderator no doubt you have the riff raff to keep your mind occupied...
bahurd is offline
Old 05-25-2017, 10:13 AM
  #9751
Got a better picture
Almost looks like a casting defect. No sharp edges or anything.
Half my seals were just sitting on the valve...this video was my first time touching the seal.
So PSA. Put your seals on tight.
Old 05-25-2017, 10:18 AM
  #9752
Total Cats: 2,201
Originally Posted by codrus
This is the stock shim:
OEM it's primarily there to keep the spring from wearing direction on the aluminum. With the Supertech springs, you're supposed to keep it, although now it's just a .005" spacer, because instead of the spring going on top you have this:
That's the ST spring seat. On top of that go the springs:
That's a set of the heavy doubles. On top of those go the top mount (not sure what that's called), and the two keepers go inside that. The valve stem sticks up through the hole in the center, and the grooves on the stem engage with ridges in the keepers to lock it all together.
The .005" shim doesn't sound like much, but it's adding preload to the spring. Preload is important -- I measured my exhaust manifold pressure at 350 kpa at one point. That's 50 psi pressing on the top of the exhaust valve, and since the valve has an area of a bit more than a square inch, it means that there's 50+ pounds of force trying to shove the valve open during the intake stroke. So you need a bunch of preload to keep the valve up against the seat.
(ack, stupid web site coughed up a hairball when I was editing this to add the bit about preload)
Shim goes under or over the ST thingymabobber?
concealer404 is offline
Old 05-25-2017, 10:19 AM
  #9753
Under
Old 05-25-2017, 10:30 AM
  #9754
bahurd's Avatar
Total Cats: 314
https://youtu.be/2JyXVxZGKbs
So you're now a fan of the ST seals? User error?
bahurd is offline
Old 05-25-2017, 10:44 AM
  #9755
Those are OEM seals.
Here is my guess.
Correctly installed supertechs leaked a little bit
Incorrectly installed OEMs leaked a lot
Once I get these felpros installed and running I'll know for sure. If it still smokes something else may be wrong.
Old 05-25-2017, 10:48 AM
  #9756
Total Cats: 857
What am I learning from this thread?
I should go ahead an buy and install a TSE oil cooler kit because I'm a whimp and I NEVER want to have to rebuild my engine.
Reminds me: @18psi, did your VVT engine ever run? I don't recall who bought it from you.
DNMakinson is offline
Old 05-25-2017, 10:49 AM
  #9757
Oil cooler? What?
Yes it did run. It's up here actually. Now out of the car again and going in an exocet.
Old 05-25-2017, 10:52 AM
  #9758
Total Cats: 857
Oil cooler? What?
Because oil cooler is the last item on Emilio's "official" list of things to do before one tracks a car. I think I did am doing everything else, but was going to skip that.
Sorry for the lack of context.
Old 05-25-2017, 10:55 AM
  #9759
Yes, Dopple bought it from me.
Apparently half of my shims were all out of whack. And I kept trying to troubleshoot the cam triggers and vvt.
He replaced some of them, and voila: engine has been running for years now.
Old 05-25-2017, 11:10 AM
  #9760
Total Cats: 857
Excellent! And I'm confident that Aidan will get this car running well, also.
