Old 02-02-2018, 01:15 AM
  #381
nigelt's Avatar
Total Cats: 388
Originally Posted by doward
do sweeps on your commutes
nigelt is offline
Old 02-03-2018, 11:32 PM
  #382
nigelt's Avatar
Total Cats: 388
1.9ConeKiller and I swapped in a 3.6 ring and pinion. Well, if I'm honest, he did it. I, like, held stuff when asked.
Next up I'll throw the diff back in the car, put the gasket on the exhaust manifold, finish cleaning the oil out of the exhaust, and I should be back on the road!
nigelt is offline
Old 02-06-2018, 02:16 AM
  #383
nigelt's Avatar
Total Cats: 388
Posting this here because a) I'm stoked about it and b) a set of these will eventually end up in my car.
This is a prototype Flow Force 960. Sonofthehill is going to test out a set and if I can get my car running reasonably well I'll run a set too. All the Flow Force goodness, with ID1050ish flow rates for 20% less money.
nigelt is offline
Old 02-06-2018, 02:33 AM
  #384
icantlearn's Avatar
Total Cats: 117
OOOOooooo. Im intrigued
icantlearn is offline
Old 02-06-2018, 10:55 AM
  #385
Total Cats: 553
Ok, ok, I am going to Napa for super long vacuum line in a little while. Nice job, do you think I can use my MT pink top adapters?
sonofthehill is offline
Old 02-06-2018, 11:00 AM
  #386
nigelt's Avatar
Total Cats: 388
You can use your OG limited-edition pink tops with these, for glory.
nigelt is offline
Old 02-06-2018, 11:27 AM
  #387
Total Cats: 553
Old 02-06-2018, 11:29 AM
  #388
is that an ev1 connector?
Old 02-06-2018, 12:19 PM
  #389
nigelt's Avatar
Total Cats: 388
Good eyes, it is indeed! It's a bit of a frankenjector. It uses an EV14 valve in a short body with a long nose and an EV1 connector. It's an OEM injector for a Peugeot V6 engine.
nigelt is offline
Old 02-07-2018, 09:27 AM
  #390
Total Cats: 857
Well, well, well. True PNP. Should be able to mount without the rail isolation spacers.
Conical spray pattern?
My FF are working great, by the way.
DNMakinson is offline
Old 02-07-2018, 09:57 AM
  #391
nigelt's Avatar
Total Cats: 388
Single cone spray pattern, and these ones don't need the fuel rail spacers
nigelt is offline
Old 02-12-2018, 10:27 AM
  #392
nigelt's Avatar
Total Cats: 388
Got the car back on the road yesterday. It pretty heavily smoked for a while even though I thoroughly cleaned all the exhaust pieces. I checked everything to make sure it wasn't something serious, and then after 45 minutes or so it was smoke-free.
The new 3.6 is running great. It feels like what a turbo 6 speed should feel like. I still have the 3.9 sender in the transmission, but it's surprisingly close to accurate. 60mph on my speedo is 62 on GPS. My tire size adds 3% and the 3.6 should add 7%, so presumably it would be 66 on GPS. I have a 3.6 sender to put in.
nigelt is offline
Old 02-13-2018, 12:30 AM
  #393
nigelt's Avatar
Total Cats: 388
I tried to add a little more polish to the hole in my hood. I think it came out alright!
nigelt is offline
Old 06-27-2018, 01:32 AM
  #394
nigelt's Avatar
Total Cats: 388
Even though I started another thread about my engine swap, which is sadly delayed, I'm going to continue to post here. And in the spirit of this hack job build, I bent my steering pinion when welding it. Too much heat, too big a bead. Good thing I bought a low miles rack and pinion to depower, so I've got the pinion in my car still that I'll use. Next time I'll just do 4 spot welds and let it cool in between.
So overkill I killed it
I'm also recognizing the need for a different seatbelt clip. I'm using the NA6 receiver, but it's too long and puts the buckle in position to do some kidney damage in a serious crash. The NB receiver is way too short and I can't reach it beside the Kirkey seats. I need something in between that matches up.
nigelt is offline
Old 06-27-2018, 01:51 AM
  #395
wackbards's Avatar
Total Cats: 266
Emilio has a shop hooked up to do the pinning process for $40. IIRC, the consensus is that it's safer than welding
https://www.miataturbo.net/suspensio...depower-96524/
wackbards is offline
Old 06-27-2018, 02:24 PM
  #396
nigelt's Avatar
Total Cats: 388
I thought I was being so damn clever and could ply my newfound welding prowess (or lack thereof) to do it myself. As it turns out, rather than saving $50, I ruined a pinion that I only seem to be able to replace by buying a complete assembly for $100.
nigelt is offline
Old 06-27-2018, 03:26 PM
  #397
cmcgregor's Avatar
Total Cats: 37
I just bought a set of belts from seatbeltplanet.com and had them web the receivers like 4" shorter, because I had the same problem.
I wouldn't buy another set from them because their anchors aren't drilled for the right size bolt, so I had to grind them out, but I'm sure any of the places online that reweb belts could do it.
cmcgregor is offline
Old 08-05-2018, 11:39 AM
  #398
nigelt's Avatar
Total Cats: 388
This happened. Explains the increase in volume coming from the exhaust.
I patched it up with some mediocre Tig welding.
Attached Thumbnails Back From the Dead Build Thread-img_20180801_202917.jpg   Back From the Dead Build Thread-img_20180801_212754.jpg
nigelt is offline
Old 08-06-2018, 10:21 PM
  #399
Total Cats: 553
Only needs to last a few months
Old 08-06-2018, 10:28 PM
  #400
nigelt's Avatar
Total Cats: 388
Yup! Car sounds stock again. I'm soooooo tired of 90whp.
nigelt is offline
Quick Reply: Back From the Dead Build Thread
