SM Weekend of Failure (wheel hubs)
Old 11-22-2016, 03:37 PM
  #101
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Lol, they're perfectly acceptable ball bearings im sure. Being that they are highly polished steel spheres, I don't think it would be a stretch (its fuking obvious) that those are reflections.
hi_im_sean is offline
Old 11-22-2016, 03:38 PM
  #102
MetalMuffins's Avatar
Total Cats: 34
Originally Posted by phocup
I wasn't until I saw SADfab BALL SACK. Where's my safety pin ..
So its probably reflection / ect but I'm seeing what looks to be a bunch of little weld spots on each ball ..
As for buying these off ebay .. they're cheap enough to try but what's the chances that' they're as good as / better than OEM ? Maybe there's obvious answers in the listing, but I'm a noob without $150 of tools to QC.
Yea, that's just a reflection. These things tend to happen when you have so many shiny ***** crammed together...
MetalMuffins is offline
Old 11-22-2016, 03:39 PM
  #103
phocup's Avatar
Hah, it does say "Deep Groove" so I thought perhaps they're not normal perfectly spherical bearings. As I said, noob to this stuff.
phocup is offline
Old 11-22-2016, 04:45 PM
  #104
z31maniac's Avatar
Total Cats: 222
Have you been able to go back out with the replacement hub ? Curious as to how that held up.
No that was a few years ago, and the engine was down on power and pissing oil everywhere so that car got parted after it ate the 3rd engine.
z31maniac is offline
Old 11-26-2016, 01:12 AM
  #105
phocup's Avatar
New ***** came today. Bought from the seller that Shuiend linked. The exact ones I bought are these, unfortunately either stock are not 13/32 or the ones I was sent were not.
I knew it right when I popped the first new bearing into the plastic retainer. It fell out whereas the old bearing remained in place. Will head to Harbor Freight tomorrow to get some calipers so I can determine the size I was sent. Hopefully can return.
Here's a pic to show the difference. 10 OEM ***** on top. 10 eBay 13/32 ***** on the bottom.
Night wasn't a complete bust though, the repacked hub with CV2 was pretty smooth. Can't wait to test it out in the car tomorrow.
phocup is offline
Old 11-26-2016, 01:35 PM
  #106
Total Cats: 1,681
I will say I bought the ***** completely based on some measurements I saw on here. It is very possible that I bought the wrong size originally. I have yet to repack bearings so I have yet to actually measure them myself.
shuiend is offline
Old 11-26-2016, 02:19 PM
  #107
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Im gonna go measure a ball for yall
Old 11-26-2016, 04:10 PM
  #108
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
This mic reads about 3-4 tenths big. So pretty much dead on 13/32".
Taken from the inside race of a timken hub.
Old 11-26-2016, 04:26 PM
  #109
Total Cats: 1,899
The assumption here is of course that all hubs by all manufacturers all use the same bearings
EO2K is offline
Old 11-26-2016, 05:07 PM
  #110
phocup's Avatar
Originally Posted by shuiend
I will say I bought the ***** completely based on some measurements I saw on here. It is very possible that I bought the wrong size.
It happens, I did the same thing without due diligence and double checking ..
Thanks for measuring that off Sean. I guess your Timken is 13/32. Now that I think about it, there's no guarantee that even different year OEM have same bearing size. Definitely measure your own before buying if going this route. Unfortunately this will add to downtime in many cases as most won't have spare hubs.
phocup is offline
Old 11-26-2016, 05:55 PM
  #111
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
That is correct, Gordon.
Old 11-29-2016, 01:16 PM
  #112
Midtenn's Avatar
Total Cats: 267
Some hubs don't even use the same number of *****. Some of the earlier cars used 11 or 12 ***** per race. They are apparently gold to SM players.
Midtenn is offline
Old 11-29-2016, 02:39 PM
  #113
hornetball's Avatar
Total Cats: 696
Originally Posted by hornetball
So far so good on my Mazdaspeed HDs. 1 track day at MSR-C (1.7CCW) and 2 at Hallett (1 CW and 1 CCW).
Lost a Mazdaspeed HD. It lasted a total of 11 track days (about 20 hours). So, no advantage there that I can discern. I slapped on a repacked China hub with OK machining.
hornetball is offline
Old 11-29-2016, 02:41 PM
  #114
Lincoln Logs's Avatar
Total Cats: 64
Given how long these hubs last I've given up on the idea of repacking. I just going to for the best quality I can within reason and running them until they go (I always keep two spares with me).
Lincoln Logs is offline
Old 11-29-2016, 02:48 PM
  #115
hornetball's Avatar
Total Cats: 696
If I don't see a significant durability increase out of the one I just slapped on (I don't have high hopes), I will do exactly the same. I'm really fast at swapping hubs these days.
Old 11-29-2016, 02:50 PM
  #116
Total Cats: 64
Yup, I can swap a hub in much less time than the time it would take me to repack...also less messy too.
Old 01-16-2017, 06:37 PM
  #117
HHammerly's Avatar
Total Cats: 63
I made a tool to re-pack my front hubs , it rakes about 3 minutes to pump some fresh grease between track days, is anyone interested in one? My cost is $75 a picece when having 10 made.
i will make a batch if there are takers.
HHammerly is offline
Old 01-16-2017, 06:40 PM
  #118
How does it work? Definitely interested.
Old 01-16-2017, 06:54 PM
  #119
HHammerly's Avatar
Total Cats: 63
You isert the tool from the wheel side and it provides a seal between the front of the hub and the back bearing inner bore forcing the grease through the ***** and races, all the old grease comes out the upright side, i was not about to disassemble the bearings every time i re pack them. Let me see if this link works
Old 01-16-2017, 09:26 PM
  #120
Total Cats: 3,019
Kinda like this?
sixshooter is offline
Quick Reply: SM Weekend of Failure (wheel hubs)
