92 Turbo Build Part Out
Old 01-19-2017, 04:47 AM
scarsofcarma's Avatar
Total Cats: 8
Default 92 Turbo Build Part Out
I am parting out a turbocharged 92 NA (Base Model, No AC or Power Steering) with 198,876 chassis miles and a fresh built motor before loss of oil pressure and bad crankcase noises. Haven't confirmed what's wrong with the engine yet but I will salvage what I can out of it and offer up what's useable. The Boss Frog double-diagonal rollbar and Flyin Miata Frame Rails are welded to the shell. Only thing NOT available for sale are the Kirkey Seats & GO PRO Camera Mount.This Miata dyno'd 243 whp and 207 ft/lb of torque.
All parts will have pictures provided before sale is finalized. Please note, all prices are OBO + shipping. PM me an offer w/ zip code for shipping quotes. (I will work as best I can with you on all items and shipping.) PayPal or Cash only please. I would prefer not to ship larger items, but I'll ship almost anything UPS Ground at buyers expense.
Shell/Exterior/Body
- Rolling Shell w/ hood, doors, trunk, finish-panel, fenders, subframes, manual steering rack, hubs (new bearings, ARP wheel studs) & control arms (Poly + Delrin bushings) SOLD!
- Hardtop (Defroster + Headliner) SOLD!
- Track Dog Front Splitter $80
Turbo System
BEGi S3 smog-legal Turbo kit SOLD!
Used Engine Block (Decked .006, honed .040 overbore) + Bottom End SOLD!
- Eagle H-Beam Connecting Rods w/ ARP Rod Bolts x3
- Wiseco Pistons (.040 overbore, 8.5 compression ratio) x3
- Ishihara Johnson Teflon Crank Scraper (Needs new teflon insert which I can order for $40)
- ARP Main Cap Studs
- ARP Head Studs
Damaged Cylinder Head (Shaved .005 & Rebuilt) SOLD!
- Stock camshafts
- Supertech Solid Lifters
- Supertech Black-Nitride Coated Stainless Valves (Part # MAEVN-1100 & MAIVN-1100)
- Supertech double valve springs (Part # SPR-TS1015-MI)
- Supertech Titanium Retainers (Part # RET-TS60/MA2)
- Supertech Valve Seals
- Bronze Valve Guides
Other Engine & Exhaust System
- TODA Adjustable Cam Gears (Pair) $300
- Supermiata Harmonic Balancer w/ crank angle sensor trigger wheel SOLD!
- MSD (Part# 8239) C.A.R.B.Ignition Coil w/custom miata bracket & Magnecore Ignition Wires SOLD!
- Precision-Cut Cam Gear Accessible Valve Cover SOLD!
- Enthuza Catback (Magnaflow-muffler, mandrel bent) SOLD!
- Magnaflow C.A.R.B. Catalytic Converter (Part # 332304) SOLD!
- MazdaComp Motor Mounts SOLD!
- Moroso Catch Can SOLD!
- Flyin Miata Setrab Oil Cooler Kit (nylon braided lines not stainless braided lines) SOLD!
Engine Management & Monitoring
- DIY Megasquirt II PNP SOLD!
- Innovate MTX-L Wideband SOLD!
- Flyin Miata Knock Sensor Kit SOLD!
- ProSport EGT Gauge SOLD!
- Autometer Boost Gauge SOLD!
- Walbro 255lph fuel pumpSOLD!
Powertrain
- 1.8 Torsen LSD w/ axles: SOLD!
- 5 speed transmission with new front and rear seals. SOLD!
- Supermiata driveshaft SOLD!
- Fidanza 8lb aluminum flywheel(Replaced friction plate; only 1,000 miles of use) SOLD!
- ACT XT Clutch kit (sprung 6 puck clutch)(Only 1,000 miles of use) SOLD!
Cooling System
- Flyin’ Miata Crossflow Radiator w/airflow fan kit SOLD!
- M-Tuned Coolant Re-Route Kit, (no thermostat) SOLD!
- Moroso Coolant Overflow Tank SOLD!
Suspension & Wheels
- GarageStar Fender Braces SOLD!
- FatCat Motorsports non-adjustable Monotube Coilovers w/ Spherical upper mounts SOLD!
- RacingBeat adjustable rear sway bar SOLD!
- RacingBeat Splined Racing Front Sway Bar w/ Reinforcement Kit SOLD!
- 949 Racing 6UL 15x8 Wheels (Excellent condition!) w/ Used BFG Rivals (4/32's tread depth) SOLD!
- 949 Racing lug nuts x17 SOLD!
- Supermiata Adjustable End Links x4 SOLD!
- RacingBeat Lower Front Subframe Brace SOLD!
- Flyin' Miata Aluminum rear subframe brace SOLD!
- Flyin' Miata Manual Steering Rack Bushings (NEW) SOLD!
- Flyin' Miata Manual Steering Rack Bushings (Used) SOLD!
Interior
- GarageStar Center consoledelete w/block off plate SOLD!
scarsofcarma is offline
Old 01-19-2017, 07:23 AM
soaps42's Avatar
Sending PM!
soaps42 is offline
Old 01-19-2017, 01:31 PM
Heitzke's Avatar
Interested in a few pieces actually. Bummer about the motor, looks like an awfully fun car.
What spring rates did you get for the FCM coilovers, and any idea of the current mileage on them? I'd have PM'd the question, but others may be interested in the rates as well. :shrug:
Heitzke is offline
Old 01-19-2017, 03:14 PM
Total Cats: 8
*Nods* I will be removing those today to take pics and give you exact specs. Mileage is unknown, but car was previously an auto-x competition car so I don't think they saw much road use. They feel great, incredibly smooth. I wouldn't have been able to tolerate road driving with aluminum kirkey seats if they weren't lol.
Old 01-19-2017, 10:41 PM
Total Cats: 8
Default FCM Coilovers
Spring Rates are 550lbs for the Front, 450lbs for the Rear. Front springs are not labeled so I am not sure what brand they are. Spherical top mounts are in great condition, they all move freely, no notchiness or other issues to worry about.
Old 01-19-2017, 11:00 PM
sharkycarlos's Avatar
Interested in Moroso coolant tank. Sending PM
Correction:
Oh well
sharkycarlos is offline
Old 01-20-2017, 12:49 PM
capitalcrew's Avatar
Total Cats: 39
Willing to sell just the shifter housing off of the transmission? Didn't see any mention of the tranny in your post
capitalcrew is offline
Old 01-20-2017, 08:03 PM
Total Cats: 8
Default 5 speed transmission.
Ah yes, thank you for pointing out that oversight. I'll sell the whole transmission for $250. Works good, it'd be a shame to take parts off it. But if you need a shfter extension housing I have other parts-transmissions I can get one off for you. $40 + shipping.
Old 01-20-2017, 08:05 PM
Total Cats: 39
Thanks! My buddy sent me a message on Facebook today though and he has one for me. Glws
Old 01-20-2017, 11:32 PM
Heitzke's Avatar
Nice! Thanks for the additional pictures as well. Do you know who made the top mounts? So many companies making miata parts these days. Either way, i'm totally set on the setup.
Heitzke is offline
Old 01-21-2017, 12:21 PM
Total Cats: 8
Thumbs up FCM Coilovers
Great well they are yours if you want them, I can ship no problem. I was told the top mounts are also made by Fat Cat, but not something they often make.
Old 01-21-2017, 12:55 PM
Total Cats: 8
Default UPDATE + Oil Cooler
Engine is pulled last night. Turbo kit remains in perfect condition for whomever gets it. I will have more details about the engine internals soon! Also I forgot to mention it has an oil cooler. Essentially a Flyin Miata Setrab kit with nylon braided oil cooler lines instead of stainless braided lines. I'm asking $275 for that.
Old 01-21-2017, 01:05 PM
Total Cats: 8
double-post
Old 01-21-2017, 08:17 PM
Total Cats: 8
Default RacingBeat Splined Racing Front Sway bar
So after removing this front bar and cleaning it up a bit I should probably ask more for this monster because it's easy to see how massive and well made this bar actually is. This is a splined, fully adjustable, racing sway bar that I've never seen advertised by RacingBeat before? I will stick to my original advertised price, for now. Someone who does a lot of track or auto-x should really pick this up!
Old 01-21-2017, 11:48 PM
astral's Avatar
Total Cats: 33
Sad to see this car go, but lots of funds on to something new
astral is offline
Old 01-22-2017, 11:22 AM
racerX_244's Avatar
I'm very interested in that front bar setup. Do you happen to know what size the center bar is? 1.25"?
racerX_244 is offline
Old 01-22-2017, 11:56 AM
Total Cats: 8
It is 30mm or 1-1/8"
Old 01-22-2017, 01:59 PM
PSI
PSI's Avatar
Total Cats: 18
Is the exhaust 2.5 or 3 inch?
PSI is offline
Old 01-23-2017, 05:26 AM
Total Cats: 8
The exhaust system is 2.5"
Old 01-23-2017, 05:36 AM
Total Cats: 8
