Old 05-29-2017, 02:25 PM
  #301
Lexzar's Avatar
Total Cats: 41
Went to a local car show for pre-73 cars, entered my girlfriend's 1956 big window, fordamatic. Had to do some last minute work on it to get it to stop pissing oil.
Also, got to talk to a friend about his Z. Then went into a spirling depression about how much I could have put into a Z instead of a miata.
Lexzar is offline
Old 05-29-2017, 11:44 PM
  #302
But then you wouldn't be here making fun of me!
Sounds boring.
Old 05-30-2017, 02:23 AM
  #303
Lexzar's Avatar
Total Cats: 41
You're right. going to continue the build for you
Lexzar is offline
Old 05-30-2017, 02:49 AM
  #304
Lexzar's Avatar
Total Cats: 41
I want some approval on my timing map, specifically pertaining to CA 91oct "knock special" gas before I go into boost.
Paging 18psi
I did compression/leak down.
Cyl1 - 178psi Cyl2-4 - ~170psi
And about ~10% leak down on all cylinders.
So the motor is mostly good.
This timing map
AFR map
Any suggestions?
Inb4 it takes another 6 months to actually be in boost.
Lexzar is offline
Old 05-30-2017, 10:46 AM
  #305
So you want me to tune your car for you, but with suggestions instead of hands-on?
el oh el
But sure, whatever:
you should be able to run 27 at 100kpa, and higher below that, yours is too retarded for no reason.
After that taper it about 2* per psi for really conservative
no idea why you have that high timing hump below 2900, might see knock there if you lug the car
no need to run fatter than 11.6afr at full boost
Old 05-30-2017, 01:32 PM
  #306
Lexzar's Avatar
Total Cats: 41
Thanks I didn't mean any offense. Just didn't want to blow my **** up immediately because of something stupid. I appreciate it.
Lexzar is offline
Old 05-30-2017, 01:50 PM
  #307
s'all good. and you might want to re-review your idle area because the way you have it scaled, I'd expect some oscillations
Old 05-30-2017, 02:02 PM
  #308
Lexzar's Avatar
Total Cats: 41
Will do, I'll iron that out too.
The reason I ask for your help specifically is because you have a lot of experience with it; a lot of guys have way better gas, so the second I run a DIY/brain's basemap, it starts pinging when it is hot outside and has some odd knocking in the higher rpm. Stupid ******* CA gas. Knocking at 90kpa is a lot less stressful than at like 140kpa.
Lexzar is offline
Old 05-30-2017, 02:03 PM
  #309
Total Cats: 1,899
Originally Posted by 18psi
poor **** has been getting pounded all week
Some people don't see this as a problem
EO2K is offline
Old 05-30-2017, 02:06 PM
  #310
Total Cats: 553
sonofthehill is offline
Old 05-31-2017, 12:35 AM
  #311
Lexzar's Avatar
Total Cats: 41
If pounding mr. **** is your only trick, you have to step up your game
Lexzar is offline
Old 06-01-2017, 07:49 PM
  #312
Lexzar's Avatar
Total Cats: 41
Because what's the point of wasting money.
that datsun. it made me feel so warm and fuzzy
I just learned of some interesting but sad news, I will have the chance to buy a 240z this year from a neighbor...my mind wanders from the miata project to pursue what I consider my favorite car ever made. **** is a rough decision for me. Inb4 "tell me what car to buy, 240z or miata" thread
Lexzar is offline
Old 06-01-2017, 07:55 PM
  #313
Total Cats: 1,899
My cousin has a "forever project" 240z Series 1 sitting in his garage. Its been there for at least 25 years and its like a damn time capsule. So pretty. If that was offered to me, and I could only keep one, I'd struggle too.
EO2K is offline
Old 06-01-2017, 08:06 PM
  #314
You can always buy another miata down the line. What are the odds that another Z will pop up in that condition?
Old 06-01-2017, 10:42 PM
  #315
Chilicharger665's Avatar
Total Cats: 57
Yeah, miatas are everywhere and cheap. A non-rusty 240z is VERY rare and will only go up in value unless you do retarded things with it.
Chilicharger665 is offline
Old 06-02-2017, 10:16 AM
  #316
NBoost's Avatar
Total Cats: -84
Originally Posted by yossi126
I have 2-5% leakdown to two cylinders. I recall Andrew calling it a good running engine.
Could be my valve stem seals, but probably rings.
Engine's with worn oil-control rings most certainly will.
NBoost is offline
Old 06-02-2017, 03:10 PM
  #317
Lexzar's Avatar
Total Cats: 41
I don't know why I didn't think of it that way. Something to think about.
Abe's work is giving me many excites.
Lexzar is offline
Old 06-03-2017, 01:14 AM
  #318
Lexzar's Avatar
Total Cats: 41
Shiiiit. In socal it is getting into the 90* and my car is going up into the 230* range after cruising on the freeway at ~65mph. Now I can put off buying a splash pan and ducting everything. Or I can just build a splitter/undertray.
lazy
also, this fab9 stage2 intercooler is insanely big looking back at it. Regret. Want for precision 350hp.
Lexzar is offline
Old 06-03-2017, 01:30 AM
  #319
That's why I got a stage 1. And also because I like AC...
Old 06-03-2017, 01:46 AM
  #320
Lexzar's Avatar
Total Cats: 41
I didn't buy new. I don't buy anything new. I am way too cheap. Just a good deal, but I want to redo it already. Someone will want this massive core.
Or I will keep it and get a ******* undertray on the car and stop being a lazy ********.
Lexzar is offline
Quick Reply: EFR6258 vs stock rods, round 1: DATSUN wins
