99 1.8 - TD04 MS2
Old 11-05-2017, 04:31 PM
  #41
Total Cats: 857
Missing your point.
1) Run 1 should be displayed on the left, unless you are in Asia.
2) Max HP and Torque are the same between the 2 runs.
3) Largest difference is that run 1 made torque at 3K: run 2 at 4K
4) Tuner changed scales, making run 2 look much weaker.
DNMakinson is offline
Old 11-05-2017, 04:36 PM
  #42
phil21191's Avatar
Total Cats: 12
Originally Posted by DNMakinson
Missing your point.
1) that was just my stupidity when I screenshotted the two PDFs side by side
2 ) correct, this confuses me
3) Yep, 80ft/lbs is a big difference I need to double check the datalog to confirm boost was equal on both
4) I was with the dyno operator in the car, ramp rate was not changed at all.
There was another pull made after these two with the same power/torque/torque curve as run 2, the car was loaded back on the dyno 4 hours later and another 2 pulls made (With a lower ramp rate) and the power/torque/power curve were exactly the sane
phil21191 is offline
Old 02-12-2018, 05:48 AM
  #43
phil21191's Avatar
Total Cats: 12
Pulled the head on saturday
Rods on 2 and 3 confirmed bent .
Looks like what we call 260ft-lbs flywheel is enough
Old 02-12-2018, 09:03 AM
Efini~FC3S's Avatar
Total Cats: 98
Props...bending OEM rods seems to be a right of passage for a lot of folks on this site...
Efini~FC3S is offline
Old 09-26-2018, 11:55 AM
  #45
phil21191's Avatar
Total Cats: 12
Long overdue update on this one. 12 months since the original damage and back to the strip. Cold day (14c/57f) and no wind
One decent pass, followed by an awful 60ft and a missed 2-3 shift then rained out for the day
Old 09-26-2018, 02:55 PM
  #46
Total Cats: 857
What did you find to be the issue?
Old 09-27-2018, 04:58 PM
  #47
phil21191's Avatar
Total Cats: 12
Pulled the head, dropped a DTI on the block and measured piston heights at TDC, 2 and 3 were about 1.5mm lower in the bore. Very very minimal bend to the rods when I pulled them out.
Swapped in a used NB long block, retuned in on a Dyno to make a bit less torque and called it a day
Old 09-27-2018, 05:05 PM
  #48
So you're trapping 109 on another stock block? that's really good congrats
Old 09-28-2018, 09:59 AM
  #49
phil21191's Avatar
Total Cats: 12
Yep I guess enough power to trap 109-110mph is as much as reliably possible on a stock block
Old 03-08-2019, 07:37 AM
  #50
phil21191's Avatar
Total Cats: 12
Revisited the tune on this as I swapped to MS3 after the last time at the strip and have also swapped over to a MAF
First up comparison vs last time the car was on the same dyno, Red trace is the latest tune
And a Wastegate boost (~145kpa MAP) vs Max effort tune
Old 03-08-2019, 09:30 AM
  #51
Total Cats: 857
Nice to see you back.
Old 03-09-2019, 05:37 AM
  #52
phil21191's Avatar
Total Cats: 12
I've been lurking. Started a new job back in November which eats up a lot of time
Tuning the MS3 on a MAF highlights really well how this "little" TD04 is right on the limit of its flow capability
Old 03-30-2019, 07:42 PM
  #53
phil21191's Avatar
Total Cats: 12
Hit the strip today with a sole focus on the launch. So spent the day messing with a few things.
The two 2.0x 60fts were leaving at 3200RPM with the car making close to 7psi on 2 step.
Missed a shift on the 4th pass, the two 2.6s the car bogged trying to use timed retard after launch on MS3. Boost was around 10-12kpa down compared to normal over 5500rpm
Old 03-31-2019, 12:43 PM
  #54
Total Cats: 553
Not bad. It takes more EBC duty to maintain boost up top. I am typically between 4 and 4500 rpm on a launch under 2 seconds, but there are a lot of variables. Your car is pretty quick, probably eat most street driven cars.
sonofthehill is offline
Old 03-31-2019, 12:53 PM
  #55
phil21191's Avatar
Total Cats: 12
I'd dampened the closed loop response a little a tame some overshoot using flat shift and hadn't gotten around to getting the bias table corrected to suit.
Just checked your thread and it looks like you seem to carry a lot more pace through the back half of the track
Old 03-31-2019, 01:00 PM
  #56
Total Cats: 553
I understand.
Yeah, my car is fast as hell, but I'm on really crappy tires. It messes with people during elimination sometimes. They slow down because they think I am far enough behind. My car is fast at the top of the track. My bottom end is forged, so I can push it a ton.
Old 06-01-2019, 06:40 AM
  #57
phil21191's Avatar
Total Cats: 12
60ft was *****. ET not so much
Old 06-01-2019, 08:59 PM
  #58
great work
Old 06-01-2019, 09:52 PM
  #59
Total Cats: 857
What boost were you running on the strip? And the rods seem intact this time? I’m hoping for similar numbers, if I ever get set up.
Old 06-02-2019, 07:08 AM
  #60
phil21191's Avatar
Total Cats: 12
14.5psi peak boost. Rods seem to be holding up absolutely fine, I've put 25 passes on the engine at this power level, trap speeds haven't changed at all. Its making a hair under 8psi on a 4k RPM launch
I don't think you'll realistically see the same power numbers on pump fuel.
Here's an MLV plot of manifold pressure vs RPM and TPS
Quick Reply: 99 1.8 - TD04 MS2
