Skunk2 BP intake manifold
Old 10-26-2017, 10:31 PM
  #41
99mx5's Avatar
Total Cats: 524
Needs moar soundclip.
99mx5 is offline
Old 10-27-2017, 06:13 PM
  #42
Total Cats: 2,378
Default stock NB2 comparison
First of several test we plan to run. These runs about an hour apart.
Optimum spark table didn't change at all. VVT table changed quite a bit but resulted in about the same power. Square top obviously wanted less fuel past 7k.
Ran out of time on dyno today so we didn't try the spacers. We'll go back next week and do that. As expected, a bit more power on top with the S2, no significant gains in midrange.
What is key to note for folks who set their redline at 7000 (stock redline) is that there are no gains below that. We don't yet know if it will make more power below 7k with the spacers.
More to come.
.31 SNR
emilio700 is offline
Leave a poscat 39 Leave a negcat
Old 10-27-2017, 06:17 PM
  #43
6speed's Avatar
Total Cats: -6
Did you retune for the new manifold or just swap and run?
6speed is offline
Old 10-27-2017, 06:28 PM
Total Cats: 2,378
One guess
.31 SNR
Old 10-27-2017, 06:32 PM
  #45
Ryan_G's Avatar
Total Cats: 217
So I'm not that versed in intake plenum theory but doesn't the physics change dramatically for boosted engines (kind of like exhaust scavenging)? I am just curious if this will show more gains on a boosted motor than an N/A where the engineering is more important instead of plenum volume and flow.
Ryan_G is offline
Old 10-27-2017, 06:33 PM
  #46
ooja3k's Avatar
Total Cats: 22
Need to re-read the post
ooja3k is offline
Old 10-27-2017, 06:34 PM
  #47
doward's Avatar
Total Cats: 754
Uh...
...Optimum spark table didn't change at all. VVT table changed quite a bit but resulted in about the same power. Square top obviously wanted less fuel past 7k.
doward is offline
Old 10-27-2017, 06:44 PM
  #48
NUMBERS! PLOTS!
You has a cat
Great job guys keep the info coming for science.
Old 10-27-2017, 07:05 PM
  #49
phocup's Avatar
It seems from that dyno that folks with stock red line should stay away. You lose more between 5-6 than you gain anywhere else in the rev range < 7.
Oh, and thanks for doing this. for you from me as well.
phocup is offline
Old 10-27-2017, 07:12 PM
  #50
DeerHunter's Avatar
Total Cats: 2,246
Looking forward to results on boosted engine. My redline is currently set at 7.7K but I generally shift, even when driving in anger, at just past 7K.
DeerHunter is offline
Old 10-27-2017, 07:13 PM
  #51
6speed's Avatar
Total Cats: -6
I don't think the blurb about the tune was in the post when I posted. But whatever.
6speed is offline
Old 10-27-2017, 07:27 PM
  #52
All-round "Good Guy"
Lokiel's Avatar
Total Cats: 245
CRAP - I've got a port-matched Flat-top and now have one of these because I was POSITIVE that the Skunk2 intake manifold would flow better due to the Flat-top's narrow channel to the plenum chamber behind the TB.
Wont spend much time beyond 7,200rpm so there's no point switching manifolds for me - at least I won't have to go through the manifold installation hassle again :P
Pos-cat added for Dyno results, looking forward to more.
Lokiel is offline
Old 10-27-2017, 07:47 PM
  #53
TheCarPassionChannel
1993z32's Avatar
Total Cats: 136
Awesome to see some real results. Now, I'm wondering if on a turbo car the gains will start once the engine is moving 150whp worth of air. Subbed
1993z32 is offline
  #54
vteckiller2000's Avatar
Total Cats: 64
Funny, this is exactly my experience with my home brew one. Sound increase and all. Thanks for the data, looking forward to spacer dynos!
vteckiller2000 is offline
Old 10-27-2017, 08:43 PM
  #55
phocup's Avatar
This is exactly what I'm waiting for as well. If results are good for boosted cars, 949 should start selling these.
phocup is offline
Old 10-27-2017, 09:02 PM
  #56
99mx5's Avatar
Total Cats: 524
Props! Thanks for sharing the info Emilio.
99mx5 is offline
Old 10-27-2017, 09:05 PM
  #57
Stealth97's Avatar
Total Cats: 66
Yes Thanks Emilio.
Stealth97 is offline
Old 10-27-2017, 09:16 PM
  #58
LukeG's Avatar
Total Cats: 166
Great info!
LukeG is offline
Old 10-27-2017, 09:23 PM
  #59
nitrodann's Avatar
I bet it makes more power everywhere on boost, when the outright airflow requirements are higher at all rpm above boost threshold.
Dann
nitrodann is offline
Old 10-28-2017, 12:12 AM
  #60
Mobius's Avatar
Total Cats: 365
∆ my thoughts as well.
Mobius is offline
