Want to upgrade radiator from Koyo 55mm - Recommendations? Supermiata/ TSE?
Old 01-25-2018, 05:04 PM
nickt93's Avatar
Total Cats: 36
Default Want to upgrade radiator from Koyo 55mm - Recommendations? Supermiata/ TSE?
I've been a little "out of the loop" on all of the latest turbo stuff since I've been tracking my NA Eliminator for the past two years. Hoping you guys can help with a radiator recommendation.
I've been running a Koyo 55mm for the past 8 years and it seems to work fine, however it doesn't work well with my coolant reroute due to the placement of the water inlet. I've routed the hose from the back of the motor in kind of a goofy way to accommodate; I'd like to do something better.
The car is an occasional HPDE car that also sees some street usage. It has an FMII turbo kit at around 11psi/ 225hp. I live in Atlanta, so it gets hot - ambient temps can be 90-100 in the summer.
Does anybody have direct experience with moving from a Koyo to either the 949 Supermiata Crossflow or the Trackspeed Dual Core? I'm leaning towards the 949, as it sounds like Emilio's testing indicates it is equally as effective as the Koyo. The TSE is more capable/ more expensive/ and probably overkill for my needs?
Any input is appreciated.
nickt93 is offline
Old 01-25-2018, 05:26 PM
LukeG's Avatar
Total Cats: 166
Was in the exact same position with my Mishimoto and reroute and I'm also running a FMII. Went with the Supermiata/949 radiator and am very happy with it!
LukeG is offline
Old 01-25-2018, 05:53 PM
Total Cats: 1,681
TSE and never look back.
shuiend is offline
Old 01-25-2018, 08:54 PM
matrussell122's Avatar
Total Cats: 516
You can't go wrong with the TSE or Supermiata both are great products
matrussell122 is offline
Old 02-01-2018, 07:02 PM
fmcokc's Avatar
Total Cats: 50
Just use this hose...
fmcokc is offline
Old 02-05-2018, 04:26 PM
nickt93's Avatar
Total Cats: 36
There's nowhere near that much room in the NA. The radiator inlet is much closer to the throttle body.
Ordered the Supermiata radiator. Thanks guys.
nickt93 is offline
Old 02-05-2018, 05:44 PM
skylinecalvin's Avatar
Total Cats: 89
For anybody having the issue of the radiator inlet being blocked by IC piping, I'm using a Dayco 71519 and cutting off the excess.
skylinecalvin is offline
Smustang1234
03-12-2011 02:01 PM
mgeoffriau
08-26-2010 05:04 PM
Efini~FC3S
07-23-2010 10:07 AM
thesnowboarder
02-12-2010 02:45 PM
chuckerants
12-05-2007 12:16 PM
Quick Reply: Want to upgrade radiator from Koyo 55mm - Recommendations? Supermiata/ TSE?
