Driveshaft Shop 400hp axles
Old 05-08-2018, 01:55 PM
Total Cats: 2,378
Default Driveshaft Shop 400hp axles
PSA: No dealer margin on these so we don't sell them, but we're using them in our high hp NA/NB builds using the 7" Miata diff.
Driveshaft Shop P/N RA6248L2, same left and right. Don't ask me tech questions, ask DSS. OEM shafts are all rebuilds. Failure mode is usually the bearing race brinelling which causes them to bind under load and pop out of the diff housing.
Takes lots of torque for that to happen. It's just a matter of time with OEM axles. Andrew shattered a tripod doing a 20mph clutch drop at 220whp during an outlap in his S1. Gordon's 450whp Rotrex build ate halfshafts like free chips and guac at taco tuesday.
interweb $359-399 (each) + 50 for ABS tone rings if you need them
.31 SNR
emilio700 is offline
Old 05-08-2018, 02:10 PM
jpreston's Avatar
Total Cats: 176
Any clue if these can be ordered with the high hp hubs as well?
jpreston is offline
Old 05-08-2018, 03:00 PM
UrbanSoot's Avatar
Total Cats: 18
Looks like I might need a set soon.
UrbanSoot is offline
Old 05-08-2018, 10:07 PM
miataman04's Avatar
They also have these for msm diffs now.
miataman04 is offline
Old 05-25-2018, 12:51 AM
Dietcoke's Avatar
Total Cats: -171
V8R makes a larger billet hub. I'm sure you can have the larger end put on, but it wouldnt be an off the shelf deal. I've still sheared one of those bigger ones in half, so there's that. YRMV.
Dietcoke is offline
TurboTim
11-16-2009 04:09 PM
manstretch
03-28-2008 03:21 PM
Zabac
10-03-2007 10:29 AM
big john
09-29-2007 07:36 AM
kotomile
08-26-2007 05:29 PM
Quick Reply: Driveshaft Shop 400hp axles
