Xidas rubbing on FUCA! HELP!
Old 07-07-2018, 04:07 PM
icantlearn's Avatar
Total Cats: 117
Default Xidas rubbing on FUCA! HELP!
How does this happen? Anyone else have this issue? its on both sides.
icantlearn is offline
Old 07-07-2018, 05:59 PM
iDizzle's Avatar
Total Cats: 10
iDizzle is offline
Old 07-07-2018, 06:56 PM
icantlearn's Avatar
Total Cats: 117
You sir, are a mufuggin savage. Thank you.
Old 07-07-2018, 10:03 PM
iDizzle's Avatar
Total Cats: 10
Had the same problem with the msm when installing my coilovers.
iDizzle is offline
Old 07-07-2018, 11:57 PM
thumpetto007's Avatar
Total Cats: -117
Same issue for me. They clearanced themselves, lol
thumpetto007 is offline
Old 07-08-2018, 01:21 AM
doward's Avatar
Total Cats: 754
NB2 arms have the extra brace, as noted above.
However, that alone is not normally an issue. By chance, do you also have ELBJs or offset bushings installed and are running less than -3* camber?
doward is offline
Old 07-08-2018, 02:01 PM
icantlearn's Avatar
Total Cats: 117
I have ELBJs. No offset bushings. -3* front camber.
This is a new issue. I think it started happening after the ELBJs were installed but im not sure.
I have not seen/heard of this issue before with cars running ELBJs. So if there is a bigger problem then I dont want to order new shock bodies just for them to get gouged as well.
How thick are the shock bodies? I feel like there is barely anything left.
Old 07-08-2018, 02:12 PM
icantlearn's Avatar
Total Cats: 117
You realize that there is probably 1mm left in the shock body right? Self clearancing is not the solution.
Old 07-08-2018, 03:10 PM
Total Cats: -117
Im riding on blown out zidas anyways
ill be grinding the tab down on the control arm, but mine isnt as bad.
Old 07-09-2018, 08:55 PM
icantlearn's Avatar
Total Cats: 117
I will be grinding mine down as well but im not sure that is the whole issue.
Old 07-09-2018, 09:40 PM
99mx5's Avatar
Total Cats: 524
Sometimes you just gotta grind a FUCA.
99mx5 is offline
Old 07-10-2018, 10:22 PM
Total Cats: 2,378
.31 SNR
emilio700 is offline
Old 07-10-2018, 10:51 PM
icantlearn's Avatar
Total Cats: 117
So are you saying that is the reason why its rubbing Emilio?
Old 07-11-2018, 12:35 AM
doward's Avatar
Total Cats: 754
Like I mentioned on the phone, the issue is a combination of
- NB2 UCA gusset takes away precious few mm of clearance.
- ELBJs that add too much camber for your current usage/height/whatever, so you've:
- Minimized camber with the cam bolts, which pulls the lower shock mount, and therefore shock body, inward towards the UCA gusset.
The very few cases I've seen have been NB2 only. This does not seem to happen on 90-00 suspensions, but Mazda has superseded the early arms with the NB2 part number. We will only see more of this going forward.
Adding back some camber with the LCA cam bolts will move the LCA and lower shock mount out away from the gusset, but may not give you enough clearance by itself.
Grinding away part of that gusset will make some room, but may not give you enough clearance by itself.
doward is offline
Old 07-11-2018, 12:46 AM
icantlearn's Avatar
Total Cats: 117
Ok so heres the thing, I was not able to achieve my current camber targets with stock lbj. Also, if this is something you have seen before, its really, REALLY important to state this on the site or something so the customer knows about this issue. How am I supposed to know that this would happen? Its completely unreasonable to expect a customer to disassemble a shock and stick it in the car and do a stroke pass when there is no documentation of an issue such as this. So now im stuck with an $800 bill for new dampers. I will call tomorrow and see if we can come to a reasonable solution.
Old 07-11-2018, 11:00 AM
borka's Avatar
Total Cats: 196
Originally Posted by MiataMan00
Ok so heres the thing, my camber eccentric bolts are nearly maxed out, so that cant be the issue from a physical standpoint. I was not able to achieve my current camber targets with stock lbj. Also, if this is something you have seen before, its really, REALLY important to state this on the site or something so the customer knows about this issue. How am I supposed to know that this would happen? Its completely unreasonable to expect a customer to disassemble a shock and stick it in the car and do a stroke pass when there is no documentation of an issue such as this. So now im stuck with an $800 bill for new dampers. I will call tomorrow and see if we can come to a reasonable solution.
why new shocks? Did you grind a hole all the way through?
borka is offline
Old 07-11-2018, 12:29 PM
icantlearn's Avatar
Total Cats: 117
its too close for comfort.
Old 07-11-2018, 12:30 PM
Total Cats: 2,201
Yep. No way would i run that.
concealer404 is offline
Old 07-11-2018, 12:32 PM
icantlearn's Avatar
Total Cats: 117
If I push on the center of the damaged area, I can feel the metal flexing. Its paper thin.
Old 07-11-2018, 12:43 PM
icantlearn's Avatar
Total Cats: 117
Also, for what its worth, the bump stops dont really do anything.
this is *Just* before the wheel starts to make contact with the fender well. Already well into bump stop.
And this is where the bump stop is maxed out. So a 1/2" of extra wheel travel that is not needed/supposed to be there/"safe".
And this is where you just start to touch the bump stop. So there is a whole inch of bump stop travel. This would have been fine if the bump stop was firmer and progressive to keep the bump stop from compressing all the way but still not be harsh. But its way too soft.
Quick Reply: Xidas rubbing on FUCA! HELP!
