MKTurbo kit on a grenade motor
Old 08-11-2018, 11:55 AM
tehzack's Avatar
Total Cats: 43
Default MKTurbo kit on a grenade motor
So i've been driving my car around on Grenade Motor v.1.0 for a year and a half (BP4W dingle berry honed, ebay vvt pistons slammed in, head shaved .025). The car ran 9.1's @ 74.something in the 1/8th and around 150whp on bias ply slicks with the 6 speed and a 4.3 torsen. Seeing how luck was on my side for how poorly that engine was built I decided to tempt the fates again and build Grenade Motor v.2.0 with a turbo kit that is a blatant plagiarism of Sonofthehill. Please read my words with your sarcasm glasses on, I built this iteration in my driveway in 2 weeks to troll my friends who never finish their cars.
Grenade Motor v.2.0 specs:
  • BP4W: China forged h beams, cheapest ebay 94-97 pistons with sealed power chromoly rings, clevite rod bearings, new OEM vvt oil pump. Still has .025 head shave. It's been dingle berried twice now. Nothing was measured. Crank has never been out of it in two 'rebuilds' now so the mains are... probably good. I wouldn't build a motor this way if it wasn't for comedy.
  • Stock head with 94-97 valve springs. BP5A intake cam. Vics intake
  • Nb1 6 speed, 949 racing 4 Puck sprung clutch, 3.9 torsen
  • Turbokit: MKTurbo. I'm fairly certain i'm running the same turbo as Sonofthehill (.63a/r exhaust, .60a/r compressor with 3" inlet) ~218kpa
  • ECU: Rev built MS2, non-sequential
  • Fuel stuff: DW200 pump, FF640's, stock fpr, 93 pump gas
Set up has about 700 miles on it now. Made 285/225 tq this morning. We didn't use an ignition pick up on the dyno so the rpm's are a bit goofy (my rev limiter is 7400 but car makes peak hp at 7600 on graph). I'm seeing 17psi by ~4300rpm (will try to log soon to give spool data). Ran 2 12.9's last night @ 110. Be gentle on my timing map, I'm still learning!
tehzack is offline
Old 08-11-2018, 11:57 AM
tehzack's Avatar
Total Cats: 43
Videos from last night:
tehzack is offline
Old 08-11-2018, 12:19 PM
Total Cats: 553
Very nice, the best part is trolling your friends who never finish their cars
I would suggest that you could achieve the same power with the .48a/r turbine housing and have it on by 35 or 3600 rpm. I might be willing to part with my smaller housing since I don't think I am going back.
sonofthehill is offline
Old 08-11-2018, 12:33 PM
tehzack's Avatar
Total Cats: 43
The man himself! Would I have to swap exhaust wheels as well to run a .48 exhaust housing? Also, how far did you push your car on 91? 20 psi if memory serves?
tehzack is offline
Old 08-11-2018, 01:04 PM
Total Cats: 553
If the turbo is the same one I am currently running, the exhaust housing is interchangeable. Although the .48 housing is a restriction and will take more boost to make the same power.
I think you are pretty close to the max, I have run more boost on 91, but I have nice forged slugs.
Old 08-11-2018, 01:17 PM
tehzack's Avatar
Total Cats: 43
This is what I've got for reference:
https://www.ebay.com/itm/CXRacing-T3...item20ccf1da87
tehzack is offline
Old 08-11-2018, 01:21 PM
Total Cats: 553
That is what I am currently running. It makes more power with less boost than the .48 housing, but comes on lazier, 4300 or so, like you said.
Old 08-11-2018, 01:32 PM
tehzack's Avatar
Total Cats: 43
I honestly don't mind it. I celebrate the old school turbo powerband. It doesn't hit the tires as hard so this rig dead hooks from a roll (205/50-15 Federal 595 RS-RR). I dig it.
tehzack is offline
Old 08-13-2018, 12:39 AM
Total Cats: 553
Me too, I still get 5psi or so instantly in top gear on the freeway, which is plenty.
Old 08-16-2018, 11:30 PM
tehzack's Avatar
Total Cats: 43
Took the car out to the 1/8th mile tonight on my new set of Mickey Thompson ET Street R's (225/50-15).
Cliff notes: Best pass: 7.72 @ 89.11 with a 1.66 60'. (Car should do 11.999999999999 1/4's at this point)
I'm pretty sure Lars should start offering this turdbo that Sonofthehill and I are running with his kit (And for sure call it MKUltra) for those that want 11sec miatas.
Timeslips. I'm car # 05. 8.x passes trying to figure out how to launch the car
My collection of 7.x passes
tehzack is offline
Old 08-17-2018, 02:19 AM
Total Cats: 553
Good job! I am curious if those tires rub on anything at all?
I have been thinking about bending a couple of the hangers to eliminate my slight bump on hard launch, just haven't got around to it yet.
Old 08-17-2018, 05:23 AM
tehzack's Avatar
Total Cats: 43
It's a snug fit, but they fit with rolled fenders on 15x7 + 30 Kosei K1's. On 15x8 +25's that I originally test fit them on they rubbed the sidewalls on launches. I had the launch control set to 5800rpm and was basically leaving with a clutch dump and the exhaust wasn't hitting anything. Most of my hangers have hose clamps around them though to trap everything in place.
Your car would definitely do wonders with a sticky tire (you know it, I know it, everyone knows it lol).
tehzack is offline
Old 08-17-2018, 07:14 AM
Total Cats: 3,019
Probably 1.5 or less 60' with wrinkle walls. Very nice work, especially on a grenade, haha!
sixshooter is offline
Old 04-12-2019, 08:47 AM
tehzack's Avatar
Total Cats: 43
Car broke cylinder #1 piston in half last December. Bores didn't get injured during the failure so I dingle honed it (for the 3rd time now) and slammed some stock bore CP forged pistons in. All other stuff is the same.
20psi and 6000rpm dialed up on the launch control. I'm worried about leaning on it too much harder on pump gas. Still, it's solidly an 11sec car at this point.
Video of run:
tehzack is offline
Old 04-12-2019, 10:44 AM
Total Cats: 553
Good job! I have been thinking about trying that turbo, can't wait to run again.
Old 04-12-2019, 11:10 AM
tehzack's Avatar
Total Cats: 43
Do it! It goes right on, costs 230 or so bucks shipped. You put a sticky tire on your car yet? Or are you still sorting out transmission options?
tehzack is offline
Old 04-12-2019, 11:24 AM
Total Cats: 553
Still sorting tranny options, might have something to try in the next few weeks. Until then I don't want to make any big changes, basically driving gently, my last 5 speed is still pretty quiet.
Old 04-12-2019, 12:06 PM
IcantDo55's Avatar
Total Cats: 51
How is that torsen living through that wheel hop?? I had taken my 92 turbo car (made 220whp)to track once and third run the wheel hop split the torsen gears in half and stuck it through the case. Is yours braced?
IcantDo55 is offline
Old 04-12-2019, 12:15 PM
Total Cats: 3,019
Wheel hop doesn't happen on slicks. You should use slicks.
Old 04-12-2019, 12:44 PM
IcantDo55's Avatar
Total Cats: 51
Thats wheel hop.
Quick Reply: MKTurbo kit on a grenade motor
