Suspension, Brakes, Drivetrain discuss the wondrous effects of boost and your miata...
93LE Tie Rod Ends
Old 01-20-2010, 01:57 PM
Ben
Supporting Vendor
Ben's Avatar
Total Cats: 134
Default 93LE Tie Rod Ends
Anyone retro 93LE/94R tie rod ends? Did it help minimize bump steer?
__________________
Chief of Floor Sweeping, DIYAutoTune.com & AMP EFI
Crew Chief, Car Owner & Least Valuable Driver, HongNorrthRacing
91 Turbo | 10AE Turbo | 01 Track Rat | #323 Mazda Champcar
Originally Posted by concealer404
Buy an MSPNP Pro, you'll feel better.
Ben is offline
Old 01-20-2010, 02:13 PM
Ben
Supporting Vendor
Ben's Avatar
Total Cats: 134
Originally Posted by emilio700
The [bump steer] effect is greatly mimimized by the taller tie rod ends.
I'm too lazy/cheap to buy bump steer gauges and measure everything, I'm a SOTP guy. It was bad before, almost perfect after. Good enough for me.
It's quite common for purpose built race cars with full spherical bearing suspension to have adjustable height tie rod ends, shims/washers usually.
Works for me. Part number is 8AN2-32-280 for anyone interested. Should allow sub 12" ride height in an NB.
__________________
Ben is offline
Old 01-20-2010, 05:05 PM
mkturbo.com
shuiend's Avatar
Total Cats: 1,681
I put them on when I convert to manual steering last year. Installation was easy and I believe Finish Line Performance had the best prices on them. I have not noticed a big difference. That probably has to do with me getting used to manual steering at the same time.
shuiend is offline
04-12-2021 04:21 PM
10-03-2015 11:04 AM
interestedofold
09-29-2015 01:42 PM
Quick Reply: 93LE Tie Rod Ends
