How much do motors rock?
Old 03-24-2008, 08:53 PM
Saml01's Avatar
Default How much do motors rock?
How much clearance does the compressor need between between it and the shelf?
Saml01 is offline
Old 03-24-2008, 09:13 PM
zoom2zoom's Avatar
depends on your mounts a little too.
zoom2zoom is offline
Old 03-24-2008, 09:21 PM
Saml01's Avatar
Well lets say bare minimum.
Saml01 is offline
Old 03-24-2008, 09:26 PM
samnavy's Avatar
Total Cats: 322
The engine rocks towards the passenger side under power... so I'd think probably 1/2" for good measure would be fine. There's a lot of material there on the fender seam to Dremel youself a little more clearance if needed.
samnavy is offline
Old 03-24-2008, 09:34 PM
Saml01's Avatar
My T25 is causing more problems then its worth. I already notched it, but with my stupid 90 degree straight down clocking(to bad I didnt know that was not a good idea) it leaves about 2 mm of clearance.
I'm going to try and grind off some more of the material at the notch, and also file down the stupid flange on the turbo to gain some clearance, as well as slightly clocking it inboard -which leads me to my next question. Does the waste gate rod have to be perfectly straight, or can it be on a slight angle?
Saml01 is offline
Old 03-24-2008, 09:53 PM
cjernigan's Avatar
Total Cats: 7
If it's not perfectly straight it can bind, which can lead to overboost, which can lead to *BOOM*. Good thing MS has an overboost feature.
cjernigan is offline
Old 03-24-2008, 10:00 PM
chucker's Avatar
Go to youtube and look at some turbo miata dyno runs. You'll get a good idea how much the engine leans over due to torque (as Samnavy indicated).
chucker is offline
Old 03-24-2008, 10:22 PM
Saml01's Avatar
Good idea. I just did.
It rocks into one direction when on power, but doesnt really rock into the opposite direction when off throttle. So I think a half inch will be plenty. I can do that pretty easily with what I plan to grind out.
Saml01 is offline
Old 03-24-2008, 11:37 PM
Arkmage's Avatar
a set of vice grips and a 3 lb sledge and you can easily gain 3/8 - 1/2" more clearance... that's how I got space for my compressor and downpipe.
Arkmage is offline
Old 03-25-2008, 01:05 AM
jayc72's Avatar
WTF are the vice grips for?
jayc72 is offline
Old 03-25-2008, 01:08 AM
Bryce's Avatar
Total Cats: 35
I assume you would latch them onto the shelf, and start hitting them with the hammer...
Bryce is offline
Old 03-25-2008, 09:17 AM
Saml01's Avatar
I guess thats if you want to bend down the rear shelf.
Saml01 is offline
Old 03-25-2008, 09:21 AM
mazda/nissan's Avatar
i gotta try that vice grip thing, i've used up all of my cutting/grinding wheels/stones on my dremel and really don't want to get in there with an angle grinder that close to my hardlines
mazda/nissan is offline
Old 03-25-2008, 10:31 PM
Arkmage's Avatar
you clamp on the vice grips and bend it down as far as you can... then you use the hammer to pound it flat up against the other metal (roughly 90* downward from it's original position)
Arkmage is offline
Old 03-27-2008, 10:14 PM
bryantaylor's Avatar
Total Cats: -1
get some MMR mounts and then you dont have to worry about the motor moving at all
bryantaylor is offline
Old 03-27-2008, 10:18 PM
mrtonyg's Avatar
Total Cats: -2
I have less than a 1/4 inch on mine...no problems.
mrtonyg is offline
elesjuan
11-14-2018 12:18 PM
09-30-2018 01:09 PM
Joe Perez
Current Events, News, Politics
8
09-30-2015 04:41 PM
viriiguy
General Miata Chat
09-28-2015 07:39 PM
itsMikey
Insert BS here
09-05-2015 02:56 PM
Quick Reply: How much do motors rock?
