94 Miata Schematic?
AFM Crusader
Total Cats: 337
94 Miata Schematic?
Started setting up an Emanage Blue for a '94 Miata and found that the ECU wiring does not agree with the Instruction Manual. Does anyone have a correct diagram?
Edit: Steelrat has provided one below.
OG, If you find the PDF I posted for my EM-B install, the 94/95 should have the same wiring diagrams.....
You basically will have 4 injector wires + the other feeds going into the EM..... Settings will be for the hotwire MAF -- so 3-a-0
Here's the thread with the PDF included:
https://www.miataturbo.net/forums/sh...ght=95+install
I can email it to you if you still need another copy of it, or can't see the attachment.
Dave,
Dave,
Last edited by olderguy; 08-07-2007 at 07:46 AM. Reason: Attachment was corrupted, see below post 16.
AFM Crusader
Total Cats: 337
Thanks. I was looking for that thread, but couldn't find it. I remembered that you had done such a nice job on it, but couldn't locate it. And the file I saved on my computer got lost. Getting older
I doped it out and wired it earlier, and now confirmed it with your diagram.
Reading the old thread, I saw that I left a word out that would have confused others. " It is NOT the same as the 1.6 ECU pinout." is what it should have read.
Thanks for the diagram and the chance to correct my error.
Total Cats: 6,630
Complete wiring diagrams for all '90 to '00 Miatae: http://www.madracki.com/miata/wiring.html
(That really oughta be a sticky in the archives. I don't have permission to post there...)
These are not the official Mazda diagrams, but I've found the '92 schematic to be fairly accurate. The only discreps I've come across related to wires that are absent in some cars, present in others (VSS for instance) not being properly notated as such.
Since the original thread got nuked. Here's the documentation again.....
If the mods want, it can go into a new thread to be archived properly this time.
NOTE: on my car the RPM wire was not in location 2O, instead it was with the blank @ 1F.... so if you have a late build '95.
Dave,
Dave,
