Head Gasket and what...?
I'm gonna pull the head this weekend. I want this job to be as simple as possible but I've got some questions. It really looks like a pretty easy deal.
When I pull the head-gasket off, can I expect it to come off cleanly, or will there be parts stuck to the block/head?
Do I have to have the head "decked" or should I expect it to still be flat?
If I have to have it decked, do I need to remove that valvetrain (REALLY WANT TO AVOID THIS)?
The water pump and timing belt were done 30k miles ago, so I won't need a new water pump... but DO I need a new timing belt or can I re-use the current one?
I've heard the stock OEM head gasket is suffiecient for my mild 12-14psi goals... anybody have other ideas?
Thanks all!
Thanks all!
I have not pulled a miata head myself, but it should go just like every other head. Disconnect the exhasut mani, wiring harnesses, fuel lines, coolant lines, timing belt, etc, unbolt and lift. It might take a great amount of effort to break the head free, or it may lift off easy. Helps to have 2 people, but you could do it yourself if you had to.
If you overheated, it's likely that the head has warped. Take it to a machine shop and have them plane it. Not deck it. Odds are the head would warp and not the block. Still you want to check the block for trueness with a straightedge and a feeler gauge. Spec calls for .1mm of gap or less.
Replace both the tb and wp while you're halfway there. You also might want to pick up some ARP headstuds. If you haven't touched them, here s your chance to replace the tb tensioner and guide. Also the cam seals and front crank seal. I'd rock with an oem headgasket, but if you want piece of mind, FM has a metal gasket for the low, low price of $100.
You'll need a 12 point 12mm socket if you don't have one, and you'll need a torque wrench for re-installation.
I cooked mine bad a few months back and the block was flat, so you shouldn't have to worry about that. Check the head with feeler gages and a straight edge. I think the max allowable is .008". If you are in spec, don't worry about having it resurfaced. If you do have to have it resurfaced, you do not have to remove the valves, but the machine shop may want you to remove the intake. If that is the case, you will need an intake manifold gasket as well.
You will need to take a razor blade and scrape all the rubbery gasket material from the block and head. Fill all the cavities in the block with rags so you are not directing that crap down in the oil and water passages. Make sure you get both surfaces clean and wipe them with mineral spirits before installing the new gasket.
It may also be a good idea to check the rubber cap on the back of the head and replace it as well while the head is off. Those are notorious for leaking and next to impossible to replace with the head on the car.
Thanks guys.
I've got an awesome local machine shop that I trust to tell me if it's flat or not. There's no chance of an overheat, so I'm hoping it's good and I don't have to have it worked on.
Rubber water cap was replaced w/clutch 8k miles ago.
Stock OEM headgasket is what I'm gonn ago with.
I need a final consensus on the TB. It's only about 20k miles old... and I'm pretty sure this engine isn't going to last another 50k no matter how well I take care of it. I'm looking to cheap out here. I've decide the WP is gonna stay... but do I have to buy a new timing belt or not?
From Finishline:
Headgasket: $39
TB: $45
From Finishline:
Headgasket: $39
TB: $45
Total Cats: 6,625
From Partsdinosaur:
TB = $26 http://www.store.partsdinosaur.com/product997.html
"Head Gasket Set" = $59, includes "all gaskets and seals from the head gasket up" (head gasket, cover gasket, intake and exhaust gaskets, cam seals, valve stem seals, etc) http://www.store.partsdinosaur.com/product1013.html
pulling the head is extremely easy. did you download the shop manual I linked you to?
pull the manifold off or the remove your downpipe. pop the intake pipes off, pop your TB of, pull all the harness, fuel lines and heater lines, pop the radiator hose off....boom, pop the cover off, pull the head bolts, boom lift.....
Total Cats: 6,625
Brainey, looking like I may be doing this myself at some point in the near future, and I do not have a boom lift.
Assuming the intake manifold, exhaust manifold and turbo are still attached, is it plausible for two men to remove the head by hand? I don't have a good feeling for whether the gasket is going to tend to cause the two to be stuck together.
Worst-case I suppose I can rig a compound block-and-tackle from the ceiling- that should be relatively inexpensive.
Here is what you do joe. After you remove the head bolts and before you take off the head. Use the IM as a lever and just yank up on the bitch, the head WILL come free. Then just lif it off, it will weight like 40lb ish. Cake for most grown males (at least if you were born on the east coast, and possibly not asian :P)
Total Cats: 6,625
Yeah, it's not the weight of it that concerned me, it was the possibility that after 16 years of being mated together, the gasket might be causing the head to stick to the block, verily, that neither by the hand of man the two shall be cleft in twain.
rock the boat, it will release.
and when i said boom lift, i meant "boom" lift. enter sound effect.
with the IM, EM & turbo still attached it's heavy but a real man like Sam could lift it. I sure as hell couldn't IM and head only shouldn't be a problem.
