Miata Parts Blowout! Turbo, Tony DP, misc...
Old 06-04-2008, 03:17 PM
sbrian2's Avatar
Default Miata Parts Blowout! Turbo, Tony DP, misc...
I have tons of parts to get rid of. I have pictures of most and can get pictures of the rest upon request. All prices are without shipping or can be picked up in Murfreesboro, TN.
Greddy Turbo Kit for 90-93 Miata - 15-20K miles on kit. Manifold has relief cuts, upgraded hardware with studs and copper nuts from ATP turbo and Nordlock locking washers, high temp silicone couplers, braided stainless oil drain line, Vortech FPR and K&N air filter. The only thing you will need is a -8 AN to NPT adapter to connect to your drain pan. Turbo has been clocked 90 degrees, but can be returned to the manufacturers position upon request - $750.00
Upgraded 2.5" downpipe made by TurboTony - 2 piece with flex, 2 O2 bungs and band clamp - $200.00
Upgraded TurboTony 2.5" catalytic converter - will need if using 2.5" downpipe since it will not mate to the OEM cat - $50.00
Bowser Greddy turbo heat shield - clearanced for TurboTony downpipe -$35.00
High flow catalytic converter for use with OEM downpipe - $40.00
A pillar w/ dual gage pod - 25.00
90-93 automatic throttle body w/ variable TPS and ISC valve - Includes wiring pigtail, great if using a standalone ECU - $50.00
94-97 1.8 injectors - a great upgrade when using the base Greddy kit - $35.00
89-91 RX-7 460cc injectors - 3K miles since cleaned and balanced by Witchunter, plug and play high impedance, great for use with standalone ECU - $100.00
94-97 Flywheel - a great upgrade for more holding power with the turbo kit - $35.00
94-97 Clutch pressure plate and disc - needed for use with above flywheel, used but in good shape - $20.00
(2) 90-93 Coil packs - $25.00 each
(2) 90-93 Manual throttle bodies w/ ISC valve - $20.00 each
(2) 90-93 Fuel rails - make your own dual feed - $10.00 each
90-97 Manual antenna base - $10.00
90-93 Valve cover - great for painting, powder coating or polishing - $35.00
90-93 Intake manifold - great for painting, powder coating or polishing, does not include throttle body - $35.00
90-93 Valve cover painted w/ crinkle black - $60.00
90-93 Intake manifold, recently cleaned and bead blasted - $45.00
90-93 AFM, recently replaced - $50.00
90-93 Glovebox w/ key - $10.00
90-97 Gas door / trunk lever - $10.00
90-97 Right tail light - small crack, hardly noticeable - $20.00
90-97 Mesh grill - $20.00 - SOLD
90-97 Red rear bumper - minor scratches - $100.00
90-97 Red left front fender - minor scratches - $100.00
90-93 Open differential - $50.00
Pair of 90-93 axles - $35.00
Pair of 94-97 1 piece axles frozen to spindles, some damage to threads from trying to remove - $20.00
90-93 Drive shaft - $25.00
90-97 Left headlight lid - Montego Blue, make your own NACA ducted headlight lid - $15.00
90-93 Injectors - $25.00
90-93 Clutch pressure plate and disc - used but in good shape - $20.00
(2) 90-93 Flywheels - have lightened or resurfaced before you drop your transmission so no waiting -$25.00
Brand new GM 2 BAR map sensor with wiring pigtail - $40.00
90-93 Engine block and head - runs, but was overheated and has low compression on #2 and #3 due to warped valve seats, bottom end is fine -$100.00
90-93 Alternator - $25.00
90-97 Complete A/C system - everything need except relays and dash button to ad A/C to your non A/C miata - $75.00
90-97 Automatic radiator - all steel construction - no plastic tanks to break - $50.00
90-93 Igniter module - does not work, but great for wiring a COP conversion - $5.00
sbrian2 is offline
Old 06-04-2008, 04:17 PM
cool, want to give me a total shipped for the 1.6 diff and the a/c system shipped to 30341 commercial please?
Old 06-04-2008, 04:23 PM
sbrian2's Avatar
I can save you or anyone else shipping to the ATL area since I will be down there at Atlanta Motor Speedway for the goodguys event on the 12th-14th if you are interested.
sbrian2 is offline
Old 06-04-2008, 04:28 PM
Rafa's Avatar
sbrian2, do you still have the mesh available?
Rafa is offline
Old 06-04-2008, 04:30 PM
sbrian2's Avatar
Yes, you want?
sbrian2 is offline
Old 06-04-2008, 04:42 PM
miataspeed1point6's Avatar
How much shipped for one 90-93 flywheel to 48237? Thanks.
miataspeed1point6 is offline
Old 06-04-2008, 04:51 PM
gompers's Avatar
How much for the "94-97 Flywheel - a great upgrade for more holding power with the turbo kit - $35.00" Shipped to 98683?
gompers is offline
Old 06-04-2008, 05:12 PM
Brian, Please bring down the diff and the a/c system then. COD work for you?
Old 06-04-2008, 05:17 PM
levnubhin's Avatar
can you get me a price shipped for the motor to 33487 please?
levnubhin is offline
Old 06-04-2008, 05:38 PM
sbrian2's Avatar
$42 shipped.
sbrian2 is offline
Old 06-04-2008, 05:40 PM
sbrian2's Avatar
$60 shipped.
sbrian2 is offline
Old 06-04-2008, 05:58 PM
sbrian2's Avatar
It is looking like $250-300 but I may not be getting quotes from the best places. If you can get it shipped cheaper, then I will palletize it and have it ready for pickup.
sbrian2 is offline
Old 06-04-2008, 06:36 PM
sbrian2's Avatar
For everyone sending payment, paypal addy is sbrian2@aol.com
Thanks.
sbrian2 is offline
Old 06-05-2008, 03:59 AM
skyline397's Avatar
interested in the greddy kit, how much is it to ship it to ca91755?
skyline397 is offline
Old 06-05-2008, 10:46 AM
sbrian2's Avatar
$795 shipped
sbrian2 is offline
Old 06-05-2008, 10:50 AM
sbrian2's Avatar
Originally Posted by miatamania
Do you have the neat little J-pipe and filter for sale that in this picture...
And if the heat shield isn't sold I'd like that too. Shipping to 28607, NC
I was going to possibly re-use it, but it may not work so I'll let it go. Filter, pipe, and heat shield shipped for $80.
sbrian2 is offline
Old 06-05-2008, 10:53 AM
miatamania's Avatar
EDIT: Paypal info is on the top of page two fellas.
miatamania is offline
Old 06-05-2008, 10:59 AM
Faded92mx5's Avatar
Shipping for auto radiator? 28677, NC
Faded92mx5 is offline
Old 06-05-2008, 12:18 PM
sbrian2's Avatar
I'll have to get the size and weight on this one tonight to get exact shipping, but $25 will probably cover it.
sbrian2 is offline
Old 06-05-2008, 12:23 PM
Faded92mx5's Avatar
No biggie, not in any rush. Thanks
Quick Reply: Miata Parts Blowout! Turbo, Tony DP, misc...
