Alignment numbers for turbod miatas
Old 06-07-2008, 10:02 AM
johndoe's Avatar
Default Alignment numbers for turbod miatas
Just wondering if any of you changed your alignment settings once you had more power in the car. I'm running 2.3/2.0 camber front to rear, 4 degrees of caster, zero toe up front and 1/16" in in the rear. My suspension setup is in my sig. With the 15x9 6ULs and the 225/45/15 RS2 I installed this week the car is go-kart sensetive now, follows every groove in the road and turns really quickly. It is very neutral in turns without but without any unpredictable oversteer, which I love. Still, I'm wondering if this will be too twitchy when I have ~250hp especially at 80mph+. So what specs are you guys using and how do you like it?
P.S. I'm glad there's finally a section for this stuff.
johndoe is offline
Old 06-07-2008, 10:11 AM
You'll definitely get more throttle-input oversteer all things being equal, but it's hard to say how your particular setup will react to more power.
do it, drive it, change as needed.
I could stand a little bit extra negative camber in the rear for the extra power.
but remember, the tradeoff for lots of negative camber is decreased straight line traction (braking for for the front wheels and acceleration for the rear wheels) because of the distorted contact patch with the wheels not-normal to the ground.
Old 06-07-2008, 10:15 AM
Mine's max caster, -1.8 camber front, -2 rear, zero toe front, 1/4" in rear. Works well enough.. but I have so little body roll that I think I can get away with dialing out some camber and save on tires/launch better.
kotomile is offline
Old 06-07-2008, 10:21 AM
johndoe's Avatar
1/4 toe in in the rear seems huge, no? What's your suspension setup like?
johndoe is offline
Old 06-07-2008, 10:47 AM
700F/325R
Bilstein HD w/ SM valving
RB enlinks
RB swaybar reinforcement
25mm solid front bar
15mm solid rear bar
FCM tophats
FCM 40mm bumpstops
kotomile is offline
Old 06-07-2008, 11:08 PM
Saml01's Avatar
Stock suspension = stock alignment.
Saml01 is offline
Old 06-08-2008, 01:47 AM
UrbanSoot's Avatar
Total Cats: 18
here are new alignment im proposing for my car when its done. im still not sure about camber up front...
-2.4 to -2.8 degrees camber front
-2 degrees camber rear
max caster
1/16 toe out front
0 toe rear
that is track setup though... my specs are in that "specs thread" if interested
UrbanSoot is offline
Old 06-08-2008, 02:10 AM
zzyx7's Avatar
max caster
1/16 toe out front
0 toe rear
Urban, that seems like a whole lot of camber. are you running soft springs? You may be sacrificing a lot of braking grip and even grip under power.
zzyx7 is offline
Old 06-08-2008, 03:28 AM
UrbanSoot's Avatar
Total Cats: 18
nah, thats about right where i want it to be for what i do
Old 06-08-2008, 04:04 AM
thesnowboarder's Avatar
MY settings are all out of wack, however i just got my car corner weighed today and have a 50% cross weight at a ride height of 11.75F and 12.3R ill be trying emilio's "race" allignment next
thesnowboarder is offline
Old 06-08-2008, 08:48 AM
Maybe he's running soft tires?
kotomile is offline
Old 06-08-2008, 10:29 AM
max caster
1/16 toe out front
0 toe rear
that smells like oversteer. most miatas run about a half degree more camber in the rear... but maybe it's driving style.
Old 06-08-2008, 11:32 AM
johndoe's Avatar
maybe it's drifto driving style...
johndoe is offline
Old 06-08-2008, 03:15 PM
UrbanSoot's Avatar
Total Cats: 18
no, thats just for soft tires im planning to run on track. also, there shouldnt be any oversteer with my setup and this alignment as 1.5-way diff adds understeer to my perfectly neutral suspension and i have to balance it out a bit.
Old 06-08-2008, 06:26 PM
i forget... you turbo?
incidentally, lifting mid-corner with that diff and setup = loop-de-loop
Old 06-08-2008, 06:34 PM
Total Cats: 2,100
Emilio recommends the exact opposite, 2.7-2.8 front and 2.3 rear. He says it adds mid-corner grip without sacrificing much on the exit.
Savington is offline
Old 06-08-2008, 08:02 PM
Originally Posted by urbansoot
thats Just For Soft Tires Im Planning To Run
kotomile is offline
Old 06-09-2008, 12:44 PM
UrbanSoot's Avatar
Total Cats: 18
i am turbo. well... waiting on package from begi.
Old 06-20-2008, 09:05 PM
bryantaylor's Avatar
this thread needs more specs. i need to re-do my alignment
bryantaylor is offline
Old 06-21-2008, 01:00 AM
paul's Avatar
Car weighs 2046lbs.
300 rwhp
50/50 cross bias
375/250 spring rates
stock front bar, swap between stock rear bar and none.
torsen of course
auto-xing last week with -2.5 degrees in the rear i had no grip out of turns on my Nitto 225/45/15 NT-01s. Car was last aligned before turbo.
Just had it aligned Tuesday to the following specs.
FRONT
-1.5 camber
4.0 caster (manual rack)
-1/8 total toe
REAR
-1.0
1/16 total
Will find out this Sunday how it does.
Btw, during the morning session it was pouring and the car was ******* awesome. Of course I was a bit more conservative with the throttle. In the dry when I'd drop the hammer it just couldn't hold.
paul is offline
Quick Reply: Alignment numbers for turbod miatas
