F/S 460cc Low Ohm Injectors 60 shipped.
Old 10-01-2008, 11:26 PM
patsmx5's Avatar
Total Cats: 477
Default F/S 460cc Low Ohm Injectors 60 shipped.
460cc fuel injectors from a 87 RX-7. Low ohm measured at 2.2 ohms on all 4 injectors. Part number 195500-1350. Red tops. No idea if they're PNP, but I think they are. Guy that sold them to me said they were, but I can not verify. Two of the pintle caps are cracked. They probably work fine (were supposedly removed from a running motor, but who knows), but I would recommend sending them out to sexy nurse for a rebuild. I can send them there if you prefer. 60 shipped.
patsmx5 is offline
Old 10-09-2008, 08:23 AM
patsmx5's Avatar
Total Cats: 477
No wonder I get no interest, I forgot to post pics!
patsmx5 is offline
Old 10-22-2008, 07:32 PM
9671111's Avatar
Total Cats: 18
What's the reason behind getting rid of them?
9671111 is offline
Old 10-22-2008, 08:03 PM
patsmx5's Avatar
Total Cats: 477
I bought some 550cc RC injectors so I used them instead. You have PM.
patsmx5 is offline
Old 10-22-2008, 11:31 PM
Not PNP but useful.
From the FAQ:
The Miata uses high ohm injectors. Also know as saturated injectors.
Complete list of Miata plug and play replacement injectors (“F” connector):
HTML Code:
Year Make/Model Engine Size/Color Part #
    87-88 Toyota MR2 4AGE NA 213cc – Beige Top #23250-16080
    89-91 B2220 Truck 224cc - Yellow Top? #23250-74040?
    99-00 Mazda Miata 240cc - Thin Red Body #195500-4430
    Toyota 4AGE 250cc – Green Top
    Toyota 4AGE 250cc – Violet Top
    94-97 Mazda Miata 254cc - Tan Top #195500-2180
    01-05 Mazda Miata NA & TURBO 265cc - Thin Lt. Prple #195500-4060
    Toyota 3SGE 295cc – Green Top
    89-92 Toyota Supra 7MGE NA 305cc – Light Green Top #23250-70080
    93-95 Toyota Supra 3.0L 312cc - Maroon Top #23250-46030
    Toyota 3SGE 315cc – Pink Top
    90-92 MX6/626/Probe Turbo 326cc - Gray Top #195500-2150
    89-91 B2600 Truck 326cc - Gray Top #195500-2150
    Mazda 323 GTX TURBO 360cc - Black Top #195500-2130
    Celica/MR2 3SGE NA 370cc - Green Top #23250-74160
    Mazda RX8 420cc - Yellow Body #195500-4450
    Subaru WRX 425cc - Lt. Blue Body #3920
    89-92 Toyota Supra 7MGE TURBO 430cc – Black Top
    89-92 Mazda RX-7 NA 440cc - Blue Top #195500-5740
    89-91 RX-7 NA 460cc - Red Top #195500-2010
    Subaru STi 540cc - Thin Pink Body #3910
    89-91 RX-7 TURBO 550cc - purple top #195500-2020
The same connector shape can be found on low ohm injectors, but they require wiring in resistors to increase the resistance and filing down the tabs on the sides of the injectors.
Direct fit LOW OHM injectors (“E” connector):
kotomile is offline
Old 10-23-2008, 04:01 PM
zoom2zoom's Avatar
The pNp s5 460's and 550's can be had on the cheap on the rx7 forums, try http://www.rx7club.com/ I got my 550's for $65 shipped on there.
zoom2zoom is offline
90 Turbo
19
10-19-2015 03:23 PM
Trent
10-01-2015 12:15 PM
The Gleas
10-01-2015 09:30 AM
FrankB
09-30-2015 11:48 AM
Quick Reply: F/S 460cc Low Ohm Injectors 60 shipped.
